Drivetrain Cam it or add meth injection?
Old Jan 20, 2015 | 03:37 PM
Escape_Artist's Avatar
Escape_Artist
Like the title says I am stuck with what to do for my next mod. I currently have 15%, intake, header, exhuast, 550cc, and tune. Eventually I want to have meth, cam and head done. I'm looking at the Aquamist HSF-3 so that I can tune for meth and have the failsafes verses just using a AEM that goes off of boost. For cam I am going to get the NS1 and the adjustable cam gear. Head with eventually be TPR-2.
What would you guys go with first? The cam or meth? Both would require a retune and would cost about the same (750 for meth kit and ~600 for cam and gear) I think meth would give me more power but will cost a bit more. Would it be best to hold off on the cam until I change out the head?
Old Jan 20, 2015 | 04:25 PM
ZippyNH's Avatar
ZippyNH
Meth now...you can run it no tune fine...do more research on the cam... Then do the cam/head at the same time and THEN retune.
Sure, the gains will be minimal pretune, but still noticeable.
Disclaimer...I don't have meth...but if you find daveO (MOSTLY on the other mini site) he will tell you all about it. IMO, your choice of meth systems is good!!
Old Jan 20, 2015 | 04:33 PM
bavmotors's Avatar
bavmotors
Pretty sure you won't be seeing Dave.0 on here again after his last temper tantrum. Zippys right though, go with the meth before adding more power.
Old Jan 20, 2015 | 06:48 PM
Da_Ghost's Avatar
Da_Ghost
I'm not 100% I'd tune for the meth. If you are tuned to run with meth, you can't run out, otherwise you'll be too lean and risk problems. Someone doing tunes might chime in and tell me that they do a safer tune for it, who knows. Personally I plan on running meth more as a safety, while not being tuned for it.
Old Jan 20, 2015 | 07:17 PM
Escape_Artist
Thanks for the input guys
Zippy - You said do more research on the cam, why is that? I chose the NS1 because of it mid range power and because I like the thumpr head so I felt they would complement each other.
Da_Ghost - I chose the Aquamist system because it hooks up the the ECU and if it detects a problem (no meth, pump failure, etc) it go to a failsafe mode to not harm the engine.
Old Jan 20, 2015 | 10:12 PM
BlwnAway's Avatar
BlwnAway
Yes, Meth first, then Cam & Head, add the Meth, don't worry about tuning, the difference will be the same as driving on a hot day, compared to a cool crisp day. Then do the Cam and Head at the same time, tune it once....done.
As far as Cam choice, if your planning on using one of Thumpers Heads, ask him, your choice of which Head may decide things so you get the right combination for what your looking for.
Old Jan 21, 2015 | 02:51 AM
bavmotors's Avatar
bavmotors
Just know that with a head and cam there will be powerband and trade offs. Don't expect a linear powerband anymore, my buddy had a thumper head and cam setup and ended up with a flat spot from about 3-4k RPMs.
Old Jan 21, 2015 | 09:37 AM
Escape_Artist
Looks like I'll be getting meth first. Thanks for the input
Blwnaway - I have already talked to Thumper about their head and cams and that is what he recommended, NS1, TPR-2, and cam gear.
bay - Yeah I understand it won't be linear anymore but any head cam combo is going to change the powerband
Old Jan 22, 2015 | 10:09 AM
Saltysalt's Avatar
Saltysalt
definitely go meth first especially since your in texas. your intake temps will drop atleaste 40deg and you don't need a tune for it. As for the cam, youll feel something, but just easier to do it when you get your BVH. excellent choice in head, that's what im sure ill end up doing, thumper is a good guy, talk to him on the phone he wont let ya down. im looking at that combo myself, just haven't had time to do a swap, I was thinking last summer, but had no time, now its winter and its my DD, so springtime =)
Old Jan 22, 2015 | 11:33 AM
ZippyNH's Avatar
ZippyNH
One more thought....
You do a header yet...
A good one like a RMW shorty, with the OEM cat welded to it works well (no codes, folks go over 250+ hp fine).....
I would hate to hear you try to run a bvh with a stock header....
Chatting with you head maker/tuner is important...much debate over the years based on cams...just sounded like a bvh with a mid range cam was an mismatch, but is the folks doing it says it runs well, then go for it!!
Old Jan 22, 2015 | 03:33 PM
Escape_Artist
Salty - I've talked to thumpr over email but have not called him yet. Waiting to see what my tax return is and might do all 3 at once!
Zippy - I do have a header, I have the Megan Racing header and I am catless but pulled the secondary o2 out of the way so it isn't throwing a code. Talking to thumpr he said by using the ns1 with the cam gear he can adjust the cam timing to switch it more towards the high end and still get the midrange.
Old Jan 27, 2015 | 05:28 AM
TheBigChill's Avatar
TheBigChill
Methanol first if you live somewhere consistently hot. Don't tune for the meth, add the cam, tune for the cam.
IQRaceworks
53
Jun 28, 2024 07:29 AM
milkrun49
Sep 28, 2015 12:03 PM
Sep 25, 2015 12:32 PM
Nicefeet
Sep 24, 2015 06:53 PM
