Drivetrain Aquamist HFS Methanol Injection Systems
Old May 18, 2014 | 09:43 AM
  #76
johntotah94's Avatar
johntotah94
Originally Posted by wzabrouski
Has anyone done the install on an R60/Countryman? Finally got around to the final step of making the ECU connections and the instructions from the R56 seemed different.
Step 3 is the MAP sensor. On the top connector, the instructions on page 23 stated the middle connector? But the diagram shows the connection on the X60232 connector. Also, why does it look like pin 31 has a plug/blank in it and not a wire?
Any help would be appreciated. I stopped once I saw this to make sure I was making the correct connections.
When I was reading this link. On #19 they said they confirmed you don't tap pin 31 but tap pin 40. Not sure if that's correct or not.
http://www.aquamist.co.uk/vbulletin/...ead.php?t=2002
Old May 18, 2014 | 10:46 AM
  #77
cerenkov's Avatar
cerenkov
Not sure about the actual pin#s but using the diagram I just counted and used the colors and everything matched up.
Old May 18, 2014 | 11:07 AM
  #78
wzabrouski's Avatar
wzabrouski
Originally Posted by cerenkov
My install was on a R56 but I think they are the same connectors as the R60. I followed the diagram in the back of the manual exactly and only used the photos as "guidance". There are no connections to be made in the middle connector. Only the first and third connectors. Here's a photo of my connector: Note that the connector has more rows on it then shown in the diagram. I just counted from the end where #1 starts and all the colors matched up perfectly with what is shown in the diagram. Make sure that you are counting and identifying #31 correctly (use the colors as reference - they should match up exactly as shown in the diagram). Triple check everything.
Why do you have the yellow connected?
Old May 18, 2014 | 11:09 AM
  #79
wzabrouski's Avatar
wzabrouski
For some reason I have power at the controller and gauge with no key in the ignition?
Old May 18, 2014 | 11:27 AM
  #80
wzabrouski's Avatar
wzabrouski
I followed the steps in the beginning which mentioned nothin about the yellow. Just connected it.
Old May 18, 2014 | 11:30 AM
  #81
cerenkov's Avatar
cerenkov
So do I. It's contrary to what's described inthe manual but it has worked ok so far.
Old May 18, 2014 | 11:46 AM
  #82
wzabrouski's Avatar
wzabrouski
Here are my connections.
Attached Thumbnails Aquamist HFS Methanol Injection Systems-image-2667830705.jpg
Old May 18, 2014 | 12:49 PM
  #83
wzabrouski's Avatar
wzabrouski
All connections made, nothing out of the ordinary at start up. Went to prime, no flow despite pump running. Tried alternate method, still no flow.
Old May 18, 2014 | 01:19 PM
  #84
cerenkov's Avatar
cerenkov
You have the FAV and the check valve installed in the correct direction?
Old May 18, 2014 | 01:21 PM
  #85
wzabrouski's Avatar
wzabrouski
I do. I actually put a leftover piece of tubing directly on the output and I am still getting nothing. The pumps are not self priming and I have read it could take some time.
Old May 18, 2014 | 07:00 PM
  #86
wzabrouski's Avatar
wzabrouski
I want to start by saying that Jeff at Howerton is awesome! We were emailing back and forth trying to figure out why I was not getting any flow and it turns out there is a missing piece inside the tank. Jeff walked me through the steps to troubleshoot the issue before he realized what it was. He is also overnighting me the missing piece and I should have it by Tuesday. Considering it was Sunday we traded about 15-20 emails throughout the day.
Old May 18, 2014 | 07:05 PM
  #87
cerenkov's Avatar
cerenkov
The yellow wire is the fuel rail pressure, IIRC it is used in conjunction with the injector signals to come up with an injector "duty cycle" for DI engines.
Old May 18, 2014 | 07:33 PM
  #88
wzabrouski's Avatar
wzabrouski
For some reason that was not mentioned in the steps earlier in the document. I connected that one.
Old May 18, 2014 | 07:37 PM
  #89
cerenkov's Avatar
cerenkov
Did you get the pump primed?
Old May 18, 2014 | 07:41 PM
  #90
wzabrouski's Avatar
wzabrouski
No. The hose with the filter was never installed in the tank before it shipped. It must have been overlooked. Jeff is overnighting me one and I should be good to go.
Old May 21, 2014 | 01:54 PM
  #91
johntotah94
Water won't go through the FAV. Any ideas? Help
Old May 21, 2014 | 02:15 PM
  #92
cerenkov's Avatar
cerenkov
If you disconnect the line before the FAV, will water then flow? If so then the FAV could be clogged or bad.
Old May 21, 2014 | 02:21 PM
  #93
johntotah94
All good. Caps were on the wrong spot on the controller.
Old May 21, 2014 | 08:29 PM
  #94
johntotah94
I got a problem where the flow gauge shows random flow during idle. Bounces up and down sometimes. But it is not flowing when it does.
Old May 21, 2014 | 08:55 PM
  #95
NewCooperFanatic's Avatar
NewCooperFanatic
Wire noise....play with the c-clip on the FAV.
Old May 22, 2014 | 01:03 AM
  #96
johntotah94
You guys notice your IAT's going down at all?
Well like below ambient?
Old May 22, 2014 | 04:06 AM
  #97
scubbysnacks's Avatar
scubbysnacks
Are you running 100% Meth?. That's when you'll see below ambient.
Old May 22, 2014 | 04:13 AM
  #98
cerenkov's Avatar
cerenkov
You guys notice your IAT's going down at all? Well like below ambient?
I've always run at least 80% methanol (currently at 100%) and depending on temperature and humidity I see between 10F to 30F below ambient.
Old May 22, 2014 | 10:11 AM
  #99
johntotah94
What do u use to read IAT? Scan Gauge?
Old May 22, 2014 | 12:02 PM
  #100
cerenkov's Avatar
cerenkov
I use DashCommand, ScanXL and the P3Car gauge all of which are OBD2 readers.
