Drivetrain Aquamist HFS Methanol Injection Systems
Old May 12, 2015 | 02:14 PM
  #426
ridinDirty's Avatar
ridinDirty
correct, but if the box or wiring was to fail ( circuit board toast etc) you will have an open circuit. I know the chance is probably low but you don't know my luck....lolol
Old May 13, 2015 | 07:28 AM
  #427
dez's Avatar
dez
Joining the ranks of "meth-head." Subscribing to this thread so I'm in the know
Old May 14, 2015 | 08:04 AM
  #428
dez's Avatar
dez
Does anyone know what type of connectors are used for the Gauge, ECU, & Trunk cables connecting to the control box? They look like rj45 or similar, but I know at least the Trunk cable is smaller. I bought the kit second had and a few of the tabs are broken
I was hoping to pick up something like this to fix them
Old May 14, 2015 | 11:19 AM
  #429
c0op3r's Avatar
c0op3r
Anything New in the W/M world
So nothing new from anyone?
Old May 14, 2015 | 12:17 PM
  #430
cerenkov's Avatar
cerenkov
You're right there is a smaller one. You should be able to count the number of possible contacts (some might be empty). They will be either 4 (RJ9) ,6 (RJ11) or 8 (RJ45).
Old May 21, 2015 | 12:24 AM
  #431
meental's Avatar
meental
6 slots with 4 pin is RJ11, 6 slot with 6 pin is RJ12
Old Jul 26, 2015 | 06:06 PM
  #432
Ovrclck's Avatar
Ovrclck
Hey guys, there's another group buy going on. Pm me for details.
Old Aug 20, 2015 | 01:02 PM
  #433
ridinDirty's Avatar
ridinDirty
Down and dirty LED light hook up
Old Jun 3, 2016 | 07:12 AM
  #434
MiniMoic's Avatar
MiniMoic
Resurrecting this thread from the dead as I’m joining the select group. I’ve been reading the full thread and I’m a little confused about the statements about the cooling effects of water/met mixes. Most of them say one mix cools more than the other mix, but what I see is been taken as a reference for this is the IATs. What I understand is what should be considered is the mix once inside the cylinder. So the more water the mix has, the more heat it takes. I wonder if then the EGT´s should be considered to see what mix is best, rather than IATs – from a cooling perspective-.
Old Jun 3, 2016 | 04:32 PM
  #435
ridinDirty's Avatar
ridinDirty
Correct. Watching your IAT is just showing you that the meth is spraying in my eyes. It's a wet bulb at that point.
I spray 100% meth for a octane boost due to my tune so I don't really have a dog in this fight.
If your wanting to spray for means of keeping the valves clean then you can play around with mixing different ratios.
I have a post turbo egt gauge on my car, not sure if that would be fair to use since the turbo is hot. Pre turbo egt would give a better reading
Old Jun 6, 2016 | 02:51 PM
  #436
MiniMoic's Avatar
MiniMoic
Yeah, the guage pre turbo for EGT will be somehow more representative of the cooling properties of the w/m combo, as the gases loose heat when they go through the turbo.
Old Jun 26, 2016 | 10:47 AM
  #437
mp5999's Avatar
mp5999
Any ideas?
Well I noticed my system wasn't working, checked and noticed the pump was not kicking on. If I put power straight to pump it works fine. So I jumper the PRK to SYS, then put power to pump kicks on and system works fine and flows as usual. So figuring it was the relay I put a new one from Howerton in today but still have the same results. I see on the website that Jeff is closed until after 4th of July, any one have any ideas here?
Thanks guys
Old Jun 27, 2016 | 06:29 AM
  #438
MiniMoic's Avatar
MiniMoic
Try Aquamist. They build the system, should be able to help.
Old Jul 1, 2016 | 10:02 PM
  #439
scubbysnacks's Avatar
scubbysnacks
Thanks guys
When you put the jumper to SYS do you hear the FAV clicking. I had the same problem as you replaced the relay and fixed it however a short time later the pump kept running even after the car was turned off turned out the new relay was sticking maybe there's a bad batch of replacement relays being sent out.
Lucky for me it only happened twice and has been fine since. Emailing Richard about the problem turned out to be a waste of time his final response was because it was an intermittent problem he could help and his final words were "I have to end this dialogue". Not maybe I've sent you a dodgy relay.
Old Jul 1, 2016 | 10:45 PM
  #440
ridinDirty's Avatar
ridinDirty
Ouch ..... He has to end the dialogue. Man that's a slap huh. Makes me wonder now .......
Old Sep 2, 2016 | 06:37 PM
  #441
smarsha11's Avatar
smarsha11
I need some direction and maybe a translator. I have a Howerton HSF4 kit for my R56 and after being an idiot and damaging the original controller I had a replacement sent directly from Aquamist. I compared the 2 controllers and changed the IDC pre-scaler jumper to x2.50 for DI engines but was not getting the low fail safe WL pot adjusted per the instructions here. I could only see 1 bar of flow at about 6000 RPM. After emailing Jeff I found I need to solder the 1-2 tabs of the flow sensor on the back of the controller. After doing this I saw no change. Emailed Jeff again and his response is below. Can anyone translate? What exactly do I need to adjust? All the pot settings are at the 12 o'clock setting. The jet is spraying per spec. Which way do I need to adjust the thres? Does this control at what boost PSI the spray comes on? Should I make a change to the gain or P/I-R? Not really sure how to proceed and don't want to muck it up.
Me:
I have soldered the 1-2 connection as specified in the manual but I see no change. Could it be anything else?
Jeff:
Put the jet in a container and make sure it's spraying per spec.
Adjust the thres to the right cut in point.
Some trigger on MPS and spray at 3-5psi.
That should be it.
Old Sep 2, 2016 | 07:30 PM
  #442
oldbrokenwind's Avatar
oldbrokenwind
Me:
Jeff:
That should be it.
Don't be afraid to "muck it up". Once you're convinced the connections are correct, try adjusting things just a little bit, maybe 1 hour intervals, and one at a time. If the results aren't to your liking, adjust it the other direction. Do this with threshold, gain and P/I-R. Eventually, you'll learn how each control affects your system. It's very difficult to "muck things up" as you can always return pots to 12 o'clock.
I can't help with fail-safe as I didn't connect mine.
Old Sep 3, 2016 | 08:41 AM
  #443
smarsha11's Avatar
smarsha11
You were right. After dialing the threshold down to about 9 o'clock everything seems to be working as expected. The spray comes on about 9 PSI and quickly ramps to 5 bars with a .8mm jet. I may need to readjust the sensor calibration to show a full 6 bars at full spray. I will drive it a few days and monitor. Thanks.
Old Sep 3, 2016 | 08:50 AM
  #444
MiniMoic's Avatar
MiniMoic
So what restrictor and injector is everyone using? Im tuned for meth and I dont want to inject less than I should
Old Sep 3, 2016 | 10:29 AM
  #445
oldbrokenwind
Talk with your tuner --- he should be able to recommend the proper setup for you. I started with a 50 - 50 WMI mix, and restrictor / injector combo chosen from the installation instructions. Ran fine 'til the Manic tune. He changed it to an 80 - 20 mix and changed the injector to the "black" one (don't remember the size, just the color ID) --- same restrictor (if I used one at all --- its been 3 - 4 years). Awesome results --- no comparison to my last AP custom tune! I don't recommend you copy anyone else's setup --- do what's best for you and yours, per your tuner. That's one reason there were options included in the kit.
Old Sep 3, 2016 | 10:35 AM
  #446
ridinDirty's Avatar
ridinDirty
Just make sure you measure the amount your spraying for a minute and confirm with your tuner that your spraying enough.(im spraying 400cc per min through a .8 jet) Then you can talk about the mix with him .
Old Sep 10, 2016 | 03:20 PM
  #447
MiniMoic's Avatar
MiniMoic
I remember I can do something to force the pump to spray meth, but do I have to open the ECU?
Old Sep 10, 2016 | 04:00 PM
  #448
cerenkov's Avatar
cerenkov
You need to open the controller and move the jumper from PRK to SYS. This will give full spray.
Obviously never do this when the jet is installed in the car.
Old Sep 10, 2016 | 05:33 PM
  #449
MiniMoic's Avatar
MiniMoic
Ahhhh perfect. And thats the flow I have to measure for the 500 - I think- Manic told me was recommended for map C
Old Sep 11, 2016 | 10:38 PM
  #450
Tigger2011's Avatar
Tigger2011
Alliance Member
The 1.0mm nozzle will flow 500cc. I installed mine without the restrictor and recorded 538cc. Subtract your boost pressure from the 160 psi line on Jeff's flow diagram here to get actual flow.
http://howertonengineering.com/calculating-jetting/
For tunes where map C requires meth you will find map B also operates well with it. Map A tends to bog a bit however with this amount meth. Ditto on what ridinDirty said. Ensure your getting the correct flow thru the system.
Even great products that are well made occasionally leave the factory with flaws so... "Trust but verify"
