Drivetrain Operation Hot Air Intake
Old Jul 27, 2004 | 01:17 PM
  #201
Bisch's Avatar
Bisch
About 1200 miles without any issue...
Old Jul 27, 2004 | 02:20 PM
  #202
sfjames2's Avatar
sfjames2
as far as water and HAI goes, it does not seem to be an issue for anyone yet. About the Alta CAI though, you don't have to cut anything when installing the system, you just remove the piece. It can be returned to stock if you wanted. take care.
Old Jul 27, 2004 | 02:36 PM
  #203
JCIP's Avatar
JCIP
If you want to return to stock, nothing could be easier. I did ask this thread if there was anything to be gained / lost from removing the lower part of the stock airbox, and I have just left it in place. No cuts or damage done to the original system, just taking up garage shelf space!
As for the water issue, my experience was like Andy's , dry until I opened the hood to check, and even then it didn't drip onto the filter.
Old Jul 27, 2004 | 03:09 PM
  #204
olYeller's Avatar
olYeller
no H2O issues at all. DO THIS MOD you will not regret it. all the benefits of a CAI without the cost. not quite the same sucking sound from the louvers under the wipers, but you can hear the SC whine like no man's business!!
Old Jul 27, 2004 | 04:50 PM
  #205
Snappermini's Avatar
Snappermini
I made this intake back in 2002 right after buying my first MCS. Makes me want to take the BMP intake off and put this one back on.
Old Jul 27, 2004 | 05:30 PM
  #206
kapps's Avatar
kapps
Can you leave that first part of the intake tube in (the part that's on Snappermini's 2nd pic) or does it block the K&N?
Old Jul 27, 2004 | 05:56 PM
  #207
BlueMCS's Avatar
BlueMCS
No it isn't
Old Jul 28, 2004 | 05:28 PM
  #208
RLmini's Avatar
RLmini
HAI is Awsome!
I have had the RU-1520 on since just after this thread started and I LOVE IT. I have drivein in hard Texas thunderstorms and no water on the filter. I am begining to think that the best intake on the market is also the least expensive. I also have a pulley and zip tie mod. The car runs pefect and more smoothly than when it was new.
Old Jul 29, 2004 | 11:48 AM
  #209
JCIP's Avatar
JCIP
zip-tie?
RLMini - Sorry, but what's the zip-tie mod?
I used the 1550. Previously, I have had some choppyness in the throttle, which seems to be subsiding as the ECU is 'learning' that there is more air available. Very pleased.
Old Jul 29, 2004 | 11:58 AM
  #210
RLmini's Avatar
RLmini
The zip tie mod gets rid of any YoYo you might experience under light acceration at around 3,000 rpm. There is a huge thread about this with pictures called: The YOYO chronicles. Threre are a couple of ways to deal with this but the zip tie mod is considered the performance oriented fix. This fix keeps the bypass valve shut all the time so you are not bypassing the super charger under light throttle. Response is instant and smooth!
Old Jul 29, 2004 | 12:05 PM
  #211
JCIP's Avatar
JCIP
Many Thanks RLmini! I will look up that thread. That could be the choppy throttle I referred to in my post. I had one dealer software upgrade, but haven't gone back for more. (I have to ship the car to the dealer). It wasn't so pronounced until I got the 19% pulley, but was annoying. I thought the better airflow would help, and I think it has. The zip-tie (I love this thread!) sounds like another cost effective solution! Thanks!
Jim
Old Aug 1, 2004 | 04:18 AM
  #212
JCIP's Avatar
JCIP
Midnight ride!
Just got home from a beautiful midnight ride under the full moon (blue moon, second this month). Fantastic response from my 19% pullied + HAI Mini S. No hesitation / Yo-yo. Just the delectiable sweetness of fast cruising, punctuated by the quick blasts to pass the occassional back-marker. No drama, just pure performance!
Old Aug 5, 2004 | 09:41 PM
  #213
FF2-EMTB's Avatar
FF2-EMTB
Hmmmmm...that chrome piece looks remarkably similar to the uptube from the intercooler to the throttle body on a Grand National....
T.
Old Aug 6, 2004 | 12:35 PM
  #214
Revolver's Avatar
Revolver
Originally Posted by JCIP
I installed the KN 1550 last night. What is everyones opinion on leaving the bottom of the original airbox in place? It looks like Andy has left his in place, and it would seem that it might shield some heat from the exhaust by being left in place. Any thoughts?My initial feeling is that this set-up works just fine. I drove through some rain on my initial test drive, and, just like Andy, had no water under the hood until I opened it up to look! I need to fit a better breather, the wal-mart $2.17 one was the wrong size, and it popped off.
Intstall was pretty straight forward, I refered to Randy Webb's how to on the Alta intake to take things apart - many thanks. Having someone's prior experience to go by saves time and angst when pulling on plastic bits. The K&N almost went on by itself, and fit right down over the throttle body. Just need to be sure that the clamp (supplied with the filter) is positioned to grip the mouth of the throttle body. With the snorkel scoop removed, tightening the clamp is easy.
I was losing traction in the rain, so a little hard to tell, but response seemed improved ( I had the stock airbox, no CAI), it felt very strong. More testing today.
Could anyone provide a link to the how-to on removing the stock intake? I want to see if it's bonehead enough for me to do...Thanks! :smile:
Edit - I found it...thanks anyway!
Old Aug 9, 2004 | 01:52 PM
  #215
Revolver's Avatar
Revolver
Could someone peovide a brand name and part number for an oil breather that fits well? I am not sure if they are all the same size or whatever...Thanks!
Old Aug 9, 2004 | 02:44 PM
  #216
Bisch's Avatar
Bisch
I don't have part#'s, but just look in Auto Zone's Tacky-Cheezball-Import-Tuner section. This is the same section they have the LED exhaust tips, colored light bulb covers, blacklight dash lights, Naws shifter *****.
They look like this blue one:
Old Aug 9, 2004 | 02:47 PM
  #217
meanboy's Avatar
meanboy
joining the club
Just ordered a ru-1550..gonna give it a shot. Tim, your former CAI might be removed soon and be on sale at e-bay.
Question: The battery cable hanging unattached, any problems with that?
Old Aug 10, 2004 | 07:38 AM
  #218
Revolver's Avatar
Revolver
Thanks Bisch, great pic, that will help a lot.
Old Aug 10, 2004 | 08:00 AM
  #219
ZAKdog's Avatar
ZAKdog
didn't remove stock airbox?
or is it your old Alta?
Old Aug 10, 2004 | 08:53 AM
  #220
meanboy's Avatar
meanboy
I was looking over the front of the airbox and I am wondering how it unclips? I don't want to break anything since it's new.
Old Aug 11, 2004 | 10:10 AM
  #221
olYeller's Avatar
olYeller
meanboy,
it unscrews. two on the top. then pulls up. i believe there is a small tab -like hinge at the back if i recall correctly.
Old Aug 11, 2004 | 02:22 PM
  #222
meanboy's Avatar
meanboy
Thanks...I'll have to look it over. I have to get a couple more hose clamps first just in case I can't figure things out.
Old Aug 12, 2004 | 06:37 PM
  #223
kapps's Avatar
kapps
With the possibility of rubbing on the hood liner, has anyone tried using the ru-1540 instead of the ru-1550? It has the same dimensions except that it's 6 inches tall instead of 7. It'll probably reduce the airlfow slightly but you won't have to worry about it making skuff marks in your liner.
Old Aug 13, 2004 | 09:45 AM
  #224
olYeller's Avatar
olYeller
i almost went that route myself, but.... 1. -slightly less airflow -maybe, but still a TON better compared to stock 2. the 1550 touching the liner actually helps hold the filter onto my throttle body and keeps it from wiggling too much.
i think a little scuff on the headliner is worth that!!!
when you put one of these on and tighten down the hose clamp you'll see what i mean. - it can be a little precarious there on the TB-the flange needs to be about 3/4" longer all around to make it down all the way on the TB. i think you'll be happy you went with the longer filter.
wait till you take the stock parts off and see how convoluted the air pathway was!! it's a wonder these things breathe at all
as a side bonus you save about 7 lbs.! and you'll have a nice pile of tubing and parts.
BTW--like Bisch said, go to autozone's Big Pimpin' section and get a breather. it's a ***** to fit onto the connector tubing, but sure isn't going anywhere once you do.
Old Aug 13, 2004 | 11:25 AM
  #225
Bisch's Avatar
Bisch
FYI, I'll have something really cool to show everyone with this mod by the end of next week. I just need to work a couple kinks out....Andy, I may need you to test this thing to "get the numbers". I'll PM you soon.
