Drivetrain Burger Motorsports (BMS) Tune(s)
Old Oct 8, 2013 | 09:28 AM
  #476
Terry @ BMS's Avatar
Terry @ BMS
Originally Posted by bmx045
Quick question. Other ECU's have a timing map(s) that the ecu will run off of as long as there isn't knock detected, but it won't run any higher than the table specifies, I'm assuming by simply adding higher octane that the ECU won't run higher timing than what's called for in the ecu right? I figure the car just...won't knock and the ecu will be able to run the timing that's predefined without having to pull any.
I'm not entirely familiar with BMW DME's and it's timing advance logic, one would think if you put a theoretical 200 octane in a stock car that it won't run 20* at full load just because it doesn't knock..lol
It has an "advance limiter", of course. But stock tuning on pump gas runs well below the upper limit. There is a short term "knock" adaption and a long term "octane" adaption.
Old Oct 8, 2013 | 09:29 AM
  #477
Terry @ BMS
PS. I'm not sure how many are left in the batch if any. Eric & Edwin and busy processing the morning orders and I'll go take an inventory once they are caught up to see where we are at.
Old Oct 8, 2013 | 09:32 AM
  #478
cerenkov's Avatar
cerenkov
Darn, I wish someone would offer a seminar/workshop on the theory of operation, etc. of today's systems.
Old Oct 8, 2013 | 09:38 AM
  #479
UnminiSCAll4's Avatar
UnminiSCAll4
Ack, I don't use that email address from paypal, are you able to forward me a copy to my other email?
Old Oct 8, 2013 | 09:45 AM
  #480
UnminiSCAll4
Never mind I got access to the email! Found it and it's shipped! Thanks!
Old Oct 8, 2013 | 09:49 AM
  #481
UnminiSCAll4
Never mind I got into my email, thanks!
Old Oct 8, 2013 | 10:08 AM
  #482
bmx045's Avatar
bmx045
nice, thanks. sucks to know it's not even running optimal timing on 93.
Old Oct 8, 2013 | 10:23 AM
  #483
ayk07's Avatar
ayk07
i missed the batch to order one, can someone post a video of the jb+ before and after? i am sold on it just want to see videos, BMS youtube site has some too.
Old Oct 8, 2013 | 10:37 AM
  #484
Terry @ BMS
To the contrary it's always running "optimal" timing for the conditions. Just not "maximum" timing.
Old Oct 8, 2013 | 10:39 AM
  #485
bmx045's Avatar
bmx045
Old Oct 8, 2013 | 11:02 AM
  #486
carhopper's Avatar
carhopper
Terry, I would buy the can tool in a second if you could hijack the stupid OEM Openometer and compensate for the piggyback. Any plans to do that?
Old Oct 8, 2013 | 12:04 PM
  #487
HorizonBLueN18's Avatar
HorizonBLueN18
a few quick questions Terry. If the jb+ is so close to the threshold that the n18 can safely run, What's different between this and the stage 1? how much more of a gain are we going to see over a JB+ when it seems that this is at the pinnacle of performance safely. Also the dyno posted on your website looks to be crank horsepower. Is that bone stock with only the JB+ set at 50%?
Old Oct 8, 2013 | 12:06 PM
  #488
RobMuntean's Avatar
RobMuntean
I believe it's to the wheels when I read it on N18 tune thread.
Old Oct 8, 2013 | 12:11 PM
  #489
MINI4LYF's Avatar
MINI4LYF
Missed out on this again... Now to wait another month -__-
Old Oct 8, 2013 | 12:15 PM
  #490
HorizonBLueN18
193whp seems a lot stock. Is that maybe with jb+ on a stock car and then the other runs are with supporting mods that's a pretty big jump in torque... who knows.
Old Oct 8, 2013 | 12:24 PM
  #491
MINI4LYF's Avatar
MINI4LYF
Dynos are weird and unreliable sometimes, what a person should REALLY take into consideration is the difference in power/torque not an estimation that a dyno gives you. They are good for seeing a baseline and testing whatever you did to see if it worked and what the difference was.
Old Oct 8, 2013 | 12:29 PM
  #492
NewCooperFanatic's Avatar
NewCooperFanatic
Don't look at the numbers guys....look at the deltas from the baseline and then the JB+ added.
Those are the gains. The numbers are inflated, so take it with a grain of salt. Also keep in mind it was using 93 octane.
Old Oct 8, 2013 | 12:58 PM
  #493
demon510's Avatar
demon510
Damn, I was waiting on buying one then this stupid government shut down happened. I have to save all my pennies since I am a 100% disabled veteran and my medical payments will stop on 11/1 if those fools dont get a grip.
Old Oct 8, 2013 | 01:31 PM
  #494
Tigger2011's Avatar
Tigger2011
Alliance Member
Originally Posted by Notnormal
I live on long island in NY which is close to sea level .yesterday using my torque app i was at 14psi and was not pushing it all the way .
Saw some traffic about CAI's causing lower boost and I run a DDMWorks RIS but that wasnt the culprit. Found a small leak on the hot side of the FMIC. Hose was a little crooked. Now I'm getting 13.93. My car is Happy now. Carbon cleaning this weekend followed by base dyno next week.
Old Oct 8, 2013 | 02:11 PM
  #495
UnminiSCAll4
Anyone have specific instructions on how to install the JB+? I don't want to mess anything up, I know there's instructions here and there in this thread but what is the exact procedure? Thanks!
Old Oct 8, 2013 | 02:12 PM
  #496
InjectedGT's Avatar
InjectedGT
Yeah pretty lame how you, who has done your job and earned it, don't get paid because the boneheads in congress can't figure out how much of the money we don't have they can spend.
Old Oct 8, 2013 | 03:12 PM
  #497
jomama's Avatar
jomama
pop the hood latch, lock your doors (to put the ecu to sleep), go back in 15 mins. pull the connector off the MAF, connect the male side of JB+ to female side of MAF connector, and the female side of JB+ to male side of connector. close your hood, fire the car up, drive the car a bit, enjoy!
if you ever need to remove the JB+, make sure you use the same procedures, otherwise it might trigger a CEL.
Old Oct 8, 2013 | 07:04 PM
  #498
yesti's Avatar
yesti
Everything is a bell curve, just cause you wont knock advancing timing more doesnt mean you'll get more power.
Old Oct 8, 2013 | 07:15 PM
  #499
UnminiSCAll4
Thanks! That will help a lot when I get it tmr!
Old Oct 8, 2013 | 07:20 PM
  #500
Azminispeedin's Avatar
Azminispeedin
Ya, the top of that bell curve is called MBT... It's very likely that there would be 10-15 degrees more total timing that could be added with either meth or E85. Around 30-40 more hp, that's what a E85 map would look like. Would also like to see boost to come in earlier and harder around 3k rpm. Problem is we would most likely lose transmissions and or half shafts.
