Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
Old Jul 9, 2013 | 06:01 PM
  #1576
NewCooperFanatic's Avatar
NewCooperFanatic
Originally Posted by Terry @ BMS
I see you're local! Drop me an email. I'll be looking for a few local BETA testers in a week or two.
Local myself....I put 100+ miles a day on the car. I'm almost certain I'd run the piggyback through it's paces lol
Old Jul 9, 2013 | 06:54 PM
  #1577
jomama's Avatar
jomama
Originally Posted by wzabrouski
Hate to be the slow one of the bunch but I could not see anything in the video. lol
look at the large analog speedo - that needle shows the A/F ratio (which i don't know how to read) as opposed to the speed of the car, unless Terry's driving north of 150mph.
Old Jul 9, 2013 | 07:19 PM
  #1578
yesti's Avatar
yesti
Terry, can you also hijack the factory JCW gauges? I have the H2O temp and relative torque gauges installed on my 12 S and that would blow my mind.
Old Jul 9, 2013 | 07:23 PM
  #1579
Terry @ BMS's Avatar
Terry @ BMS
Probably. One step in the process will be to determine what dash types exist and what changes there are between them. If anyone knows (or has photos of the various types) it would be appreciated!
Old Jul 9, 2013 | 08:30 PM
  #1580
wzabrouski's Avatar
wzabrouski
Terry, any plans to soon try out the JB on an auto N18?
Old Jul 9, 2013 | 08:31 PM
  #1581
wzabrouski's Avatar
wzabrouski
Took me a couple of views.
Old Jul 9, 2013 | 09:13 PM
  #1582
Terry @ BMS
Pumped in some ethanol to test out an E30 fuel mix. Fun stuff. Unfortunately a local sheriff didn't think so. Ticketed for 79 in a 50 zone. Time to hardwire a V1.
Attached Thumbnails The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs-20130709_201421.jpg
Old Jul 9, 2013 | 09:19 PM
  #1583
wzabrouski's Avatar
wzabrouski
That sucks. Love my V1
Old Jul 9, 2013 | 10:42 PM
  #1584
jomama's Avatar
jomama
did you need to change some of the fuel lines to run ethanol?
Old Jul 10, 2013 | 03:24 AM
  #1585
pidge1114's Avatar
pidge1114
Old Jul 10, 2013 | 05:26 AM
  #1586
bmx045's Avatar
bmx045
looks great Terry! I love how you guys tap into the can system for functional purposes.... my money is certainly ready to be sent. One question, looking at your install video, how does this setup adjust fueling if it's mainly altering MAP harnesses? I'm just trying to think how the ECU will know to spray more fuel when this device is mainly fiddling with what seems like boost target(and therefore wastegate duty cycle compensation)
Old Jul 10, 2013 | 07:57 AM
  #1587
Terry @ BMS
The key to making it all work is with the MAF control and the nature of the closed loop fueling system this motor runs. Of course with the Stage1 there are certain constraints we are working between but I'm confident we'll have a safe and reliable 20-30rw bump with it. For Stage2 where we plan to add E85 support, etc, then of course additional sensors, CAN access, etc, will need to be brought in to the mix to accommodate the additional gains.
Old Jul 10, 2013 | 08:00 AM
  #1588
Terry @ BMS
Testing it on a 100% stock system. Need to get up to speed on the platform. Does anyone run E85 on their R56 currently? It not, why not?
Old Jul 10, 2013 | 08:08 AM
  #1589
Mindspin311's Avatar
Mindspin311
I dont think many do, since on other tuners offer an option. As far as I am aware.
Old Jul 10, 2013 | 08:13 AM
  #1590
Azminispeedin's Avatar
Azminispeedin
It will be great to see what a ton of timing will give in the power department in this motor without mbt. Terry, do u have comp fuel table tables that lay over standard tables to adjust for e85, so the user can adjust simply for a 30, 50 or 100% E85? FYI for those of u that are going to run e85 in cars with higher mileage, run a lower mix like 30% for a while, the alcohol in e85 cleans all the gunk out of the high pressure plunger in the pump.
Old Jul 10, 2013 | 11:19 AM
  #1591
bmwr606's Avatar
bmwr606
both mini and bmw say not to run E85
Old Jul 10, 2013 | 11:23 AM
  #1592
minimechusa's Avatar
minimechusa
Mini and BMW also say you don't half to change the oil but every 15k. They advise and as long as Terry's testing comes out ok ill run it
Old Jul 10, 2013 | 11:24 AM
  #1593
chrunck's Avatar
chrunck
MINI also says not to tune your car, so why do we even have this thread?
Old Jul 10, 2013 | 12:47 PM
  #1594
Terry @ BMS
BMW's absolutely love E85 mixtures. We'll see how the MINI takes it. More for R&D than anything else at this point.
Old Jul 10, 2013 | 01:31 PM
  #1595
Azminispeedin
All cars since the late 90's are built to handle the natural tendency of alcohol to dry out and break down material. The REASON they do not want higher levels of e85 to be run is the ecu's inability to compensate higher fuel loads greater than 15%. E85 has a lower density, thus it takes more fuel to burn at the same rate as gas. A good programmer will compensate fuel tables to run levels of e85. Chrysler and Chevrolet have built in sensors that detect the current level if e85 and adjust the ecu on the fly.
Old Jul 10, 2013 | 05:22 PM
  #1596
jet127's Avatar
jet127
Hi Terry,
I had my N18 engine tuned but I would definitely want to try this if there will be no negative effect on the ECU if I use your option to override my current tune. Do you think it will be an issue?
Old Jul 10, 2013 | 06:26 PM
  #1597
yesti's Avatar
yesti
Here's a link to motoringfile. The picture appears to have relative torque on the left and G meter on the right. At the end of the article is an install PDF. The PDF says no coding is required, so does that mean the gauges are totally passive? Would that disallow them being hijacked?
http://www.motoringfile.com/2009/03/...retro-fit-kit/
Old Jul 10, 2013 | 07:12 PM
  #1598
wzabrouski's Avatar
wzabrouski
Originally Posted by jet127
Hi Terry,
I am in the same boat and asked the same question. I believe he suggested going stock before using.
Old Jul 10, 2013 | 08:05 PM
  #1599
Terry @ BMS
The short answer is I don't yet know.
With Stage1, I'd assume it won't work, or at least will be too much trouble to figure out. I don't expect Stage1 to be much better than any other N18 tune out there. Just similar performance in an easy to install/remove at home format. On Stage2, that will be another story all together.
But either way I'll do the CAN Tool programming so it can be used with our tune or any other tune for in dash boost display, AFR, knock, shift light, downpipe light delete, etc. Finally got control of the fuel LEDs tonight. I'll throw together a little demo video when I get a couple more bugs worked out.
Old Jul 10, 2013 | 08:07 PM
  #1600
wzabrouski's Avatar
wzabrouski
Terry are there any issues with tuning the auto BMW's? Still trying to figure out why the auto mini's are so special...
