Drivetrain Mods for '12 MCS 6spd
Old Feb 4, 2012 | 02:58 PM
pvillarraga's Avatar
pvillarraga
I need some ideas. I want my turbo blow off much louder. What will do the trick, looking for inexpensive also.
Also what intakes, blow off valves are compatible with '12 MCS
Thank You
Old Feb 5, 2012 | 07:42 AM
killerfox's Avatar
killerfox
Forget about the blow off valve, they don't add any power. An open intake will gain you more sound and more air flow.
Old Feb 5, 2012 | 07:54 AM
pvillarraga
What intake do you recommend
Old Feb 5, 2012 | 08:04 AM
killerfox's Avatar
killerfox
All the intakes are basically the same, all cost $300-400 and do very little exept for a bit more sound. I have an M7 intake but there is a lot of people here who love the DOS intake. I would just find the cheepest one you can get because they don't add much in the way of performance. It really is personal preference.
I don't think you have too many options for a 2012 either.
Old Feb 5, 2012 | 08:24 AM
Drobinson1692's Avatar
Drobinson1692
Fox, i'm pretty sure it's determined the DoS intake would add a bit of torque over the stock intake. I'm pretty sure that it is JCW Stage 1= DOS > stock > all others (actually take in warmer air)
Old Feb 5, 2012 | 08:28 AM
killerfox's Avatar
killerfox
Yes, aftermarket intakes do add some, but not enough to justify the expense. I would say that the warm air intake is not really an issue with a turbo since the air is heated inside the turbo, that is why we have an intercooler.
Old Feb 5, 2012 | 06:18 PM
turtle343's Avatar
turtle343
if you're not concerned with gains, get the cheapest you can find.
Old Feb 7, 2012 | 06:16 AM
oxspeed's Avatar
oxspeed
Their correct. For the most part intakes do the job of making sound. But they do an important job of eliminating vacuum around the filter. It's been proven that a stock intake box has enough restriction to create a vacuum which will rob power. So simply keeping the filter element exposed picks up the extra horsepower. As for noise, the farther down the intake stream you run hard pipes the louder the intake noise will be (I prefer as much intake noise as possible I love the sound of spool) If your looking for a cheap intake. I would recommend the DDM works street intake, its the cheapest intake on the market but is backed by a reputable company with decent warranty.
hope this helps
Old Feb 14, 2012 | 01:01 AM
NY_R56's Avatar
NY_R56
If you just want the blow off noise. I got a cheap mod for you then. A cone filter and some zip ties. I use a cone filter on mine and does a pretty good job. Cost me about 20 bucks for the cone filter from autozone and 1 buck for a couple of zip ties. I directly bolt the cone filter on the MAF sensor.
Old Feb 14, 2012 | 09:59 AM
pvillarraga
Cone filter
Is this easy to do? any cutting or customizing? Instruction/pictures if you have them
Old Feb 14, 2012 | 01:22 PM
NY_R56's Avatar
NY_R56
Its actually very simple. No cutting or anything. All you need I think is a flat head screwdriver and a tool to get the MAF sensor off the stock airbox. It takes about 20 minutes. Most of that time is trying to get the old airbox out. Get a cone filter that can fit the sensor (I think its 3 inches) and bolt it straight on and zip tie it down. The one on mine is a cheap Spectre p4 cone filter, I got at autozone for around $20.
Moddedmafia
Sep 1, 2015 09:52 AM
jesterofatlas
Aug 31, 2015 12:14 PM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
massmini03
Aug 12, 2015 11:19 AM
