Drivetrain DoS CAI Installed. Truly Impressed!
Old May 13, 2012 | 06:59 PM
  #126
teamrubixcube's Avatar
teamrubixcube
Originally Posted by JPMM
installed the DOS today, it doesn't fit well with the Alta hard pipe. Kind of a funny noise , might have to get used to it.
Mine was a hard fit with the alta hard pipe but once you get everything settled and worked out it's perfect. Now it's a better fit than my stock pipe was.
I don't think you'll have any problem getting used to the noise
Old May 13, 2012 | 07:03 PM
  #127
oldcracker's Avatar
oldcracker
did you have any problems with the stock inlet constantly slipping off with the DOS intake before you got the alta hard pipe?
Old May 14, 2012 | 12:51 AM
  #128
sooper_cooper's Avatar
sooper_cooper
I was wondering if anyone had tried that yet. Seems like it wouldn't bend enough (or at all since it's metal). I like the idea of the hard pipe though.
Got any pics?
Old May 14, 2012 | 03:14 AM
  #129
JPMM's Avatar
JPMM
I used the the hoses to make up the misalignment, not a good solution really. I'll probably have to remove/exchange something and/or go back to the original setup. I'll get some photos.
Got any pics?
Old May 14, 2012 | 11:36 AM
  #130
teamrubixcube
My original tube was slipping quite a bit and went to the hard pipe...haven't had to worry about it since. My alignment really isn't THAT bad. A little bend at one of the silicon joints but I can't complain. I'll take some pics as well and post them up later.
Old May 14, 2012 | 01:51 PM
  #131
JPMM's Avatar
JPMM
I couldn't get the Alta turbo inlet hard pipe to fit flush on the turbo spigot ,but the set screws did have bite.
Thinking about a Samco Inlet hose to replace the hard pipe, because I'm getting addicted to the great big sucking sound and the blow off
Old May 14, 2012 | 04:02 PM
  #132
TheFunnyguy's Avatar
TheFunnyguy
When I first installed my DOS CAI, i had the stock MCS inlet which tore and needed to be replaced. When I replaced it I returned everything, except the pre-cut bulk head panel, to stock. After conversing with Clint from DOS, he advised to either go with the JCW hard inlet or a SAMCO hose. I ultimately decided to do the JCW hard inlet and the narrow t-bolt clamp and have not had any issues since.
Old May 14, 2012 | 04:04 PM
  #133
JPMM's Avatar
JPMM
whats a JCW hard inlet ?
Is that a Alta hard pipe? Did you buy the DOS all over again?
Old May 15, 2012 | 06:02 AM
  #134
TheFunnyguy
No I did not buy a new CAI. The Alta inlet was one I was considering, however I talked to Clint and told him the brands I was considering (Alta, Samco, and stock JCW), he told me he would go with either the stock JCW hard inlet or the Samco inlet.
I know the question was originally asked about the Alta inlet, I just wanted to chime in regarding what DOS advised when I was faced with misalignment and subsequent tearing of my stock MCS inlet.
Maybe consider selling the Alta in the marketplace and then purchasing an inlet with better fitment for the DOS CAI??
Old May 15, 2012 | 10:59 AM
  #135
oldcracker's Avatar
oldcracker
I'm deciding between the alta hard tube and the samco tube because my inlet tubes have all been slipping off after installing the DOS intake, even with the t-bolt clamp
I have tried oem tube, oem jcw tube, and alta silicone tube
tried everything Clint suggested, no luck
Old May 15, 2012 | 11:30 AM
  #136
JPMM's Avatar
JPMM
maybe your engine is rockin' too much, and pullin' stuff apart. Do you have NM inserts or a BSH motor mount?
Old May 15, 2012 | 03:01 PM
  #137
oldcracker's Avatar
oldcracker
I do have the Mini Madness inserts
But it was fine with stock intake and even when I was just running a slap on k&n cone filter off the oem inlet
Old May 15, 2012 | 03:49 PM
  #138
teamrubixcube
Here are some pics with the Alta hard pipe. It's really a good fit for my car.
Old May 15, 2012 | 06:51 PM
  #139
JPMM's Avatar
JPMM
I might have to try reproduce that alignment, loosen everything up and try to get that nice!
[IMG][/IMG]
[IMG][/IMG]
Old May 23, 2012 | 03:09 PM
  #140
cesar418's Avatar
cesar418
update on the filter?
Old May 23, 2012 | 03:31 PM
  #141
iamwiz82's Avatar
iamwiz82
[IMG][/IMG]
[IMG][/IMG]
Thats about what mine looks like, I have the Alta inlet and DoS intake. I was nervous about the fit at first, but then loosened everything and straightened it more, then we tightened. Nothing has loosened or fallen off yet.
Old May 23, 2012 | 04:55 PM
  #142
JPMM's Avatar
JPMM
I don't have the flexiblty like you do there
Attached Thumbnails DoS CAI Installed. Truly Impressed!-alta-with-the-dos-the-bulge.jpg
Old May 23, 2012 | 07:21 PM
  #143
teamrubixcube
Did your hard pipe come with a silicon connector like that? The bubble is built in to give you flexibility...I slid it pretty far back on the tube to make sure the bubble would be between the tube and the intake allowing me to have the flexibility. I actually have two hard pipes from Alta (long story) but they both came with the connector.
Old May 23, 2012 | 07:23 PM
  #144
JPMM's Avatar
JPMM
the car came with the Alta hard pipe installed so....?
Old May 25, 2012 | 03:40 PM
  #145
JPMM's Avatar
JPMM
I think the JCW prefactory JCW intake(the good one ) allows the engine to rev freeier than the DOS. Just a seat of the pants observation, I hope to do some data logging with my AP soon.Maybe I need a tune tweak .
Old May 25, 2012 | 08:13 PM
  #146
TerminalVelocity's Avatar
TerminalVelocity
I honestly didn't think there was a Gen 2 JCW intake available.
Old May 25, 2012 | 08:26 PM
  #147
JPMM's Avatar
JPMM
2007-2008 R56 JCW intake ( big cylinder shaped filter, the same filter or just like the gen 1JCW's but the housing is without the goofy flap and no cowl intake
Old May 25, 2012 | 11:33 PM
  #148
TerminalVelocity
Ahh yes thanks, I have run across that in my quest for a new CAI but I think I was confusing that with the older Gen 1 version. Brain fart on my part.
Old May 30, 2012 | 08:33 PM
  #149
teebo7's Avatar
teebo7
Originally Posted by Mini'mon
Hi Jerry,
You and Larry were the instigators that kicked DoS's butt into gear and started us out on the long and torturous road of getting the filters made.
We don't need help with testing, but I will make sure that Larry and yourself get a "thank-you gift" from DoS for your prodding.
-Clint
Any updates?
Old Jun 1, 2012 | 10:11 AM
  #150
Mini'mon's Avatar
Mini'mon
Originally Posted by teebo7
Any updates?
Our manufacturer shipped out the first batch of 25 filters yesterday. We will start putting flanges on the filters next week.
Initially the dry filter will only be available as a separate retrofit part for our CAI kits. We will offer a dry filter version of the CAI in June.
DoS will have the dry filters up on the website starting the week of 6/11/12!
Thanks for checking-in and have a great weekend.
-Clint
