Drivetrain PCV hose delete.
Old Sep 13, 2017 | 03:17 PM
  #201
DneprDave's Avatar
DneprDave
I didn't say down draft, I said draft tube, not the same thing.
Old Sep 14, 2017 | 08:32 AM
  #202
Neal3000's Avatar
Neal3000
Sorry, i mis-wrote that
Old Feb 13, 2019 | 03:27 PM
  #203
Ahmed Hisham's Avatar
Ahmed Hisham
So have you tried it?
Old Mar 19, 2019 | 05:02 PM
  #204
jjcsnlynn's Avatar
jjcsnlynn
I've read this thread with great interest. I also read a thread recently to NOT do the passenger side block off but can't find it.
I have recently removed and cleaned my head and valves (bought it with bent valves) so I am completely clean inside and want to keep it that way and will probably blank off the passenger side.
I am only 250 miles into my 'new to me car' and now getting a P1497 code. If I blank off the passenger side, will this code go away?
Old Mar 19, 2019 | 05:28 PM
  #205
DneprDave's Avatar
DneprDave
P1497 means that you have an air leak between the turbocharger and the throttle body.
I've been running my MINI with the PCV line to the throttle body blocked off and an oil catch can on the PCV line to the turbocharger for nine years with no problems.
Old Mar 19, 2019 | 05:33 PM
  #206
Lex2008's Avatar
Lex2008
​​​​​​...I bet your intake valves are gummed up nonetheless. Have you checked them?
Old Mar 19, 2019 | 05:55 PM
  #207
jjcsnlynn's Avatar
jjcsnlynn
I have no intake gunk. Just had the head off and cleaned them (bought it non-running)
so the P1497 is usually a bad valve cover/ head cover. How is that between turbo and throttle body?
Old Mar 20, 2019 | 08:44 AM
  #208
DneprDave's Avatar
DneprDave
The head cover is between the turbocharger suction and the throttle body, if you haven't blocked off the PCV line to the throttle body.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
micromini234
Sep 30, 2015 07:36 PM
