Drivetrain PCV hose delete.
Old Feb 8, 2012 | 12:29 PM
  #151
czar's Avatar
czar
Have you checked the whereabouts of your parcel, from your tracking code ?
I will check right now too.
Old Feb 8, 2012 | 12:34 PM
  #152
czar's Avatar
czar
According to the tracking records I have, your parcel is in the USA, with your postal service for local delivery.
Old Feb 8, 2012 | 02:51 PM
  #153
mamut's Avatar
mamut
Czar, did you get to send my caps?
Old Feb 8, 2012 | 03:17 PM
  #154
czar's Avatar
czar
Yes yours and porthos were posted the same day, I have just checked the tracking on both parcels, and both parcels are in the USA with your local postal service, you can keep a track on your parcel, with the tracking code I supplied to you.
Old Feb 8, 2012 | 04:47 PM
  #155
mamut's Avatar
mamut
Thank you
Old Feb 10, 2012 | 05:33 PM
  #156
mamut's Avatar
mamut
got it today, thanks again.
Old Feb 10, 2012 | 08:32 PM
  #157
Porthos's Avatar
Porthos
Thanks meng. No caps yet probably tomorrow though. Me asking earlier was a joke. Because it was like 2 days after I paid for them. Hell I thought it was going to take a lot longer.
Old Feb 10, 2012 | 09:03 PM
  #158
mamut's Avatar
mamut
Hell yea, I thought its gonna take like 2 weeks.
Old Feb 14, 2012 | 03:34 PM
  #159
Porthos's Avatar
Porthos
Got my block of caps today. Thanx Czar
Old Feb 15, 2012 | 09:16 AM
  #160
quality_sound's Avatar
quality_sound
Originally Posted by Sacred Disorder
I have been swamped at work this week. Havent had a chance to drop by the dealer. I will try to get it done today.
Damn I wish I'd have checked this thread sooner. I need a set.
Old Feb 15, 2012 | 10:56 AM
  #161
luis_villarruel's Avatar
luis_villarruel
i'm on mexico, i can get it for you!
Old Feb 16, 2012 | 04:55 PM
  #162
Porthos's Avatar
Porthos
I just did the block off tonight. The top one was super easy. The bottom one on the other hand, that is a pain. Though it only took me like 10 minutes total. I will see how the car runs and if it starts filling up my CC any faster.
Old Feb 18, 2012 | 07:13 AM
  #163
killerfox's Avatar
killerfox
I'm not sure of the part number but I just looked at my 2012 Audi S5 with the 4.2L motor and on the passenger side,top, rear of the motor I found a cap that looks identical to these, I wonder if you can get them from AUDI?
Old Feb 18, 2012 | 08:28 PM
  #164
Porthos's Avatar
Porthos
Take one off and see if it fits on your MINI.
Old Feb 20, 2012 | 11:50 AM
  #165
killerfox's Avatar
killerfox
CONFIRMED!!! the Audi and MINI parts are the same. I swapped the two parts and they fit perfectly.
Old Feb 20, 2012 | 07:05 PM
  #166
Porthos's Avatar
Porthos
There you go. Which is cheaper though? I would lean toward the MINI one, well the Peugeot one.
Old Feb 20, 2012 | 07:39 PM
  #167
killerfox's Avatar
killerfox
I would say price may be the same since the Peugeot cap is not available in the U.S., after shipping the cost might be close. I already have a set from CZAR (Roger) but just in case someone else is looking into this they can get them from Audi.
Old Feb 21, 2012 | 06:14 PM
  #168
Porthos's Avatar
Porthos
I was reading a few pages back about the blocking off and it was stated that if you were to push the car hard that you would vent the top one just to let the pressure out. What about the 2011+ engines deleted that side of the PCV system. How would that be any different then us with the 07-10 engines?
Old Feb 22, 2012 | 07:57 AM
  #169
killerfox's Avatar
killerfox
MINI redesigned the valve cover on the new 2011+ cars.
Old Feb 22, 2012 | 08:02 AM
  #170
Porthos's Avatar
Porthos
So is it still venting on that side or is it venting just to one side now? I have onlyy looked at the 11+ engine once and don't remember seeing what they did.
Old Feb 22, 2012 | 08:11 AM
  #171
DneprDave's Avatar
DneprDave
The new head has internal passages that connect the camshaft space directly to the intake ports via the PCV valve in the head cover. This eliminates the external hose from the back of the head cover to the intake manifold.
Dave
Old Feb 22, 2012 | 08:29 AM
  #172
czar's Avatar
czar
It's more than a cam cover re-design, the N18 engine has a completely different cylinder head, and "allegedly" (I can't 100% confirm this) it's got an internal PCV tract, into each inlet runner in the cylinder head! So although the external rear PCV line to the inlet manifold from the cam cover is now gone, it seems it has simply moved inside, divide into the 4 inlet runner tracts, and if this is true, it will still carbon up, like it's predecessor the N14.
Here is a cut away view, of the rear of the N18 engine, and you can see what look like, internal passages in the inlet runners, that said, I would need to have a closer look, or a better image, to be 100% sure/accurate.
Old Feb 22, 2012 | 11:24 AM
  #173
Porthos's Avatar
Porthos
I forgot about the fact that they added Vanos to the engine and that replaced the head to the new engine. I think I had asked it would be possible to retrofit the new head and Vanos to the older engine. N18 Head to N14 head? And I wish engines were that clean so I didn't have to get so dirty working on one.
Old Mar 14, 2012 | 01:47 PM
  #174
killerfox's Avatar
killerfox
I found the Audi Part number: 036131510
http://www.ecstuning.com/Search/036131510/ES274329/
Old Mar 16, 2012 | 09:25 AM
  #175
countryboyshane's Avatar
countryboyshane
That's a great picture Roger! Now I can actually tell how the common rail is bolted to the head in case I ever have to service an injector.
