Drivetrain BSH catch can and dual boost port install
Old Mar 14, 2011 | 02:55 PM
  #376
Dwight Walhood's Avatar
Dwight Walhood
It ain't under vacuum when the turbo's at full boost and the crankcase pressurizes! I use spring clamps and have had no leaks after 23K and 20psi boost. BTW, that "slight" vacuum is at 14.7psi. You don't want a vacuum leak anywhere or the ECU will go nuts.
Old Mar 14, 2011 | 03:08 PM
  #377
Bigprfed22's Avatar
Bigprfed22
Originally Posted by chakraj
No Fishbert only has a can on the Throttle Body side and no can on the turbo side for now.
Old Mar 14, 2011 | 04:35 PM
  #378
oldcracker's Avatar
oldcracker
just put mine in yesterday
47e24454.jpg?t=1300139746
lol I'm still thinking if the hose would to get too hot so close to the coolant tank
Old Mar 14, 2011 | 04:57 PM
  #379
Dwight Walhood
If you're really worried about heat from the coolant tank, you might consider what I did. I put a 90deg. hose fitting where the PCV hose exits the cam cover. It also gets it even farther away from the turbo!
Old Mar 14, 2011 | 05:12 PM
  #380
Rixter's Avatar
Rixter
I beat you by a week.
Attached Thumbnails BSH catch can and dual boost port install-enginebaywocc.jpg
Old Mar 14, 2011 | 05:37 PM
  #381
fishbert's Avatar
fishbert
Originally Posted by Bigprfed22
Its under vacuum, technically that will prevent "leaks" alone.
Yet the neck of the "in" port on my catch can has a coating of oil on its exterior up to right around where the clamp sits. Not sure if the clamp is keeping it from seeping or not, but the oil seems to want to go that way (my guess is that small quantities of oil are pooling where the hose meets the mouth of the "in" port, and capillary action is pulling it down that crack between the hose and the exterior surface of the port... but that's just a guess).
If its blocked there is no airflow going through there so theres nothing to worry about.
I don't know what you're talking about.
Why would I block hoses attached to my catch can?
I've flexed my extreme artistic prowess to illustrate what I was theorizing above...
You have 2 cans though correct?
That's the aim... but at the moment, just the one.
Old Mar 14, 2011 | 05:48 PM
  #382
Rixter's Avatar
Rixter
Steve that's probably a valid theory. What about the fact that the connectors that come out of the OCC have a ridge on them to seal things tight.
I know when I was putting mine on, I had to remove it a couple of times until I got just the right length of tube. Wow it was an effort getting the hoses off the connection points. I figure with the hoses just long enough to push towards each connection there's no way it could ever come off.
Old Mar 14, 2011 | 07:30 PM
  #383
fishbert's Avatar
fishbert
Steve?
I didn't show a ridge on my catch can, though one is present. The presence of ridges (and their size/slope/etc.) probably varies quite widely, depending on which can one is talking about. My 42dd can has ridges, but it's fairly easy to work the hose over them; I wouldn't call it sufficient as a seal. (the elbow joint, on the other hand... the ridge on that thing cut a chunk out of the inner surface of a hose I pulled off of that!)
In any case, clamps... no clamps... they're a dollar or two at most and weigh next to nothing. Why not just throw them on and forget about it? They might help, and they might not... but they certainly aren't going to hurt anything.
Old Mar 14, 2011 | 07:42 PM
  #384
minimini482's Avatar
minimini482
Ok, so I couldnt wait and just finished the install.
Like rixter said, the hardest part was fitting the right length of hose. Getting the hose off is a PITA! I put hose clamps for piece of mind, but I doubt these connections could come undone on their own....
I have just over 4300 miles on my JCW and there was already some oily deposits on every connection (the intake and sensor, and both the driver and passenger side PCV). Only time will confirm how much I (hopefully) am saving my engine?
A few questions for those that installed this with the stock airbox:
1)What is this line? Should I be worried the hose from the intake to the OCC is pushing this up higher than it was before the install? Or that it is touching the hose to the OCC?
2)Should I zip tie this area (where there was a zip tie I cut off) again? Or will it be ok without one?
Thanks for everyone's help!
Old Mar 14, 2011 | 08:06 PM
  #385
Maugre's Avatar
Maugre
I'm thinking it might be a vacuum connection for the brakes, not positive, but I think it has enough give so you don't have to worry. Nice work.
I didn't put a zip tie there.
Old Mar 14, 2011 | 08:15 PM
  #386
Dwight Walhood
Yup, that's the vacuum line for the brakes. See RealOEM.
Old Mar 14, 2011 | 09:02 PM
  #387
minimini482
YIKES!
ill have to keep an eye on this...
Old Mar 14, 2011 | 09:29 PM
  #388
onefish2's Avatar
onefish2
I have had the catch can on for almost a year now. Here is a picture of my engine bay.
And a picture from the first time I removed the contents of the catch can with a straw in a syringe.
Old Mar 15, 2011 | 07:56 AM
  #389
Bigprfed22's Avatar
Bigprfed22
I had to place mine next to the washer bottle, NM intake takes up too much space
Old Mar 15, 2011 | 01:12 PM
  #390
oldcracker's Avatar
oldcracker
nice! anymore pics?
Old Mar 15, 2011 | 01:25 PM
  #391
Bigprfed22's Avatar
Bigprfed22
nice! anymore pics?
This is the only other one i have i will take more after my wknd detail
Old Mar 15, 2011 | 05:13 PM
  #392
oldcracker's Avatar
oldcracker
I mean pics of the catch can, cus I'm just wondering how u mounted it there? isnt the stock air pipe in that location?
Old Mar 16, 2011 | 10:17 AM
  #393
Bigprfed22's Avatar
Bigprfed22
I have the nm so there was no need for the extra piping which i removed, i used the included bracket to mount it to the right sub rail which passes by the washer bottle. Just a nut washer and bolt and theres alread an existing hole to mount it on. The angle gives it the slight lean back which i wanted.
Old Mar 18, 2011 | 12:07 PM
  #394
thevelourfog's Avatar
thevelourfog
Quick question: I'm picking up my car from the dealer tomorrow after having the timing chain tensioner and a few other things fixed and apparently the head tech there wants to talk to me about my catch can set up. I'm guessing about the boost port block off. The phone message I got said they were concerned this could cause future oil leaks and I'm sure they want to hold it against me somehow, like it's hurting the car. Of course I think this is without merit. Any advice on how I should handle this?
Old Mar 18, 2011 | 12:18 PM
  #395
Rixter's Avatar
Rixter
I don't have a technical answer, but somewhere in the conversation you might want to ask them, isnt that essentially the design of the N18 engine for the 2011 models? There is not a passenger side PCV hose
Old Mar 18, 2011 | 01:07 PM
  #396
DneprDave's Avatar
DneprDave
The N18 has passages in the head, from the head cover to the intake ports. These replace the hose connection on the passenger side-rear of the head cover on the N14 engine. It was done because there was a problem with oil pooling at the throttle body on the N14 engines.
The connection from the other side of the head cover to the turbo intake, via the oil catch can, would prevent pressure from building up in the engine and causing leaks.
I talked about this with the shop Foreman at my MINI dealer. His concern was that the addition of an oil catch can and dual boost port block off is an unapproved (by the EPA) alteration of the PCV system. Though he has seen quite a few, he hasn't seen any problems caused by it.
Dave
Old Mar 18, 2011 | 01:21 PM
  #397
Rixter's Avatar
Rixter
So is a (less desirable) solution simply to install just the OCC w/o boost port?
Old Mar 18, 2011 | 01:30 PM
  #398
DneprDave's Avatar
DneprDave
That would defeat most of the reason for the oil catch can on a MINI, unless you put the catch can on the passenger/aft side hose, instead of on the turbo side hose, like Fishbert did. Though you would then still get oil in the turbo and aftercooler.
Really, the main advantage of the dual boost tap/block off is that with it, you don't need to install two catch cans.
Dave
Old Mar 18, 2011 | 02:28 PM
  #399
djdraddy's Avatar
djdraddy
I have heard about these internal passages in the head/cover of the new N18 engine a few times now. These are the passages that do away with the passenger side PVC valve/hose arrangement as on the N14 engine.
I have a couple of questions about this. 1) Where did this information come from? 2) Has anyone actually seen them? and 3) how does this system work? I mean, do they really exist or is this just something someone was told?
One big problem I see with internal passages is... Where do you install the valve to close the system when the system is under "Boost" pressure? I have to say this idea seems a bit complicated even for BMW.
Any thoughts? Is there anything I can read that has been published on this?
Old Mar 18, 2011 | 07:00 PM
  #400
Gil-galad's Avatar
Gil-galad
+1 across the board. I agree with dj, there's no hard evidence to support the claims of these "magic passages" on the N18. I asked the same question over in the OCC on a 2011 thread regarding the obvious problem of the boost over-pressurizing the crankcase through these unchecked passages and no one has been able to come up with an answer.
