Drivetrain BSH catch can and dual boost port install
Old Mar 24, 2011 | 07:10 AM
  #426
Dwight Walhood's Avatar
Dwight Walhood
Originally Posted by MattyKHZ
Quick question for those running the 42 Draft Design Stealth OCC. What else is needed to fit this to the Mini. I know some use the BSH Dual Tap, but from a connections POV the BSH seems to come with everything and teh 42 Draft Designs I guess is OCC only.
Reason being I can only get the 42 Draft Designs Stealth can here in the UK straight away and shipped it costs £87.60. The BSH item is £181 shipped !!!! And surely the only difference is some hoses and connectors (and a dipstick on the BSH).
I am going to need the OCC quite soon before I fit my new JCW Turbo and Evolve FMIC.
I put my own OCC system together over a year ago using the 42 DD can before BSH came out with their "complete" kit. IMO the 42 DD has a much better baffle design and in/out port arrangement. BSH's dual boost port was the final key to the puzzle making all crankcase crud go through the can. BTW, the BSH kit does not include the boost port. Had to make my own mounting bracket of sheet aluminum and used plastic hose fittings to make the connections. You don't need a dip stick to check the can. Just tap the can with a screwdriver to see how full it is. I put 42 DD's valve on the drain plug and drain the gack into a cup under the car. FYI: No OCC will completely stop the carbon fouling, just slow it way down. 24K down the hatch and it's working fine, but I still do a single Seafoam treatment about every 8K. Good Luck!
PS: That new FMIC is gonna love not being bathed in oil!
Old Mar 24, 2011 | 10:17 AM
  #427
MattyKHZ's Avatar
MattyKHZ
So any idea what universal accessories from 42D would be required to get it to fit and guess I need a fitment plate making up?
http://store.42draftdesigns.com/Univ...ries_c_79.html
If the baffle design is better I like the idea of that but the BSH seems a ready made solution, just at a premium over here in the UK. The BSH stuff is the same price in £ as it is in $ for some reason where as the 42 DD stuff is not. Something if wrong there !!!
I may end up having to get everything from the US anyway.
Old Mar 30, 2011 | 10:16 AM
  #428
Mini2na's Avatar
Mini2na
Access to back side of plastic firewall?
Just purchased a BSH CC, but have the factory alarm. I see that the can can be mounted on the plastic firewall near the bonnet alarm switch, but I can not see a way to get my hand behind it to attach a nut to a bolt to hold a bracket.
Can anyone point me to directions or provide advice on attaching a bracket to this area.
Thanks!
Old Mar 30, 2011 | 11:05 AM
  #429
vader's Avatar
vader
I mounted mine to the same location as the alarm switch and it works just fine. I did have to get a longer bolt.
Old Mar 30, 2011 | 12:30 PM
  #430
Bigprfed22's Avatar
Bigprfed22
to get behind the plastic wall you need to remove the wiper arms(make sure you mark their at rest location w tape) and then the plastic cowls. Then you will have clear access.
Old Mar 30, 2011 | 05:37 PM
  #431
Gil-galad's Avatar
Gil-galad
That's exactly what I plan to do. Is there a trick to getting the bolt off?
Old Mar 31, 2011 | 03:59 AM
  #432
vader's Avatar
vader
To remove the sensor:
unclip the wire
carefully release the clip on each side of the sensor that holds it into the bracket and lift the sensor straight up. I used a jewelers screwdriver between the switch and bracket.
You now have full access to the screw holding the switch bracket.
I had to enlarge the hole in the bracket to fit the bolt.
Old Mar 31, 2011 | 04:47 AM
  #433
Gil-galad's Avatar
Gil-galad
unclip the wire
Much appreciated...thanks.
Old Apr 13, 2011 | 07:12 PM
  #434
AZblackOUT's Avatar
AZblackOUT
Nice install!
Old Apr 14, 2011 | 10:04 AM
  #435
Bigprfed22's Avatar
Bigprfed22
http://etuners.gr/index.php?s=12&t=299 greek write up on how peugot and citroen/mini owners do what we do with the complete block off
Old May 3, 2011 | 02:44 AM
  #436
donuttang's Avatar
donuttang
i dropped the clip on the boost port, is it really necessary?
Old May 3, 2011 | 08:56 AM
  #437
Mini'mon's Avatar
Mini'mon
I would use it. It's simple peace of mind.
If you lost it, simply contact Justin at BSH to see if he can hook you up.
Best,
-Clint
Old May 10, 2011 | 09:21 AM
  #438
gjn25's Avatar
gjn25
check this out Link
Old May 10, 2011 | 09:20 PM
  #439
cenobyt's Avatar
cenobyt
Originally Posted by gjn25
check this out Link
What's the link? NAM is claiming insufficient privileges...
Old May 11, 2011 | 12:00 AM
  #440
djdraddy's Avatar
djdraddy
You mean you can't activate the link? Well, if that's the case you have insufficient privileges and we can't tell you anything more...
Old May 13, 2011 | 10:12 PM
  #441
tedbone72P's Avatar
tedbone72P
Excellent thread. I wish I read this last year. Have about 95K an had a cleaning done at the dealership, ~$750...Huge difference...drives like new. Did seafoam treatments but to no avail.
So this is a must mod for all!!!
Old May 26, 2011 | 08:47 PM
  #442
AZblackOUT's Avatar
AZblackOUT
Did you wind up putting a catch can on after your cleaning?
Old May 26, 2011 | 09:02 PM
  #443
cenobyt's Avatar
cenobyt
Thanks that helped a whole bunch
Old May 26, 2011 | 09:30 PM
  #444
Rixter's Avatar
Rixter
I believe it was a thread that was blocked. You might be able to find a cached copy doing a Google search
Old May 26, 2011 | 10:10 PM
  #445
cenobyt's Avatar
cenobyt
Thanks, gjn25 hooked me up. Original link is blocked but I now know what he was linking to and was able to read it through.
Old May 28, 2011 | 12:47 PM
  #446
tedbone72P's Avatar
tedbone72P
Will be on before the end of the month
Old Jun 27, 2011 | 04:17 PM
  #447
Sush@BSH's Avatar
Sush@BSH
Anyone have any pictures of the gunk their catch cans have caught?
Old Jun 27, 2011 | 04:55 PM
  #448
Gil-galad's Avatar
Gil-galad
Someday maybe -- if you guys ever offer a fitment for the N18...
Old Jun 27, 2011 | 05:16 PM
  #449
TheCheatOSX's Avatar
TheCheatOSX
Catch Can with Boost Port block installed 4/4/11 @ 25,500 miles after dealership carbon blasting with walnut media.
Currently 6/27/11 @ 29,000.
This is a small pint jar, not a normal quart mason.
http://www.flickr.com/photos/cnorrick/5879247368/http://www.flickr.com/photos/cnorrick/5879247368/
Old Jun 27, 2011 | 09:08 PM
  #450
DneprDave's Avatar
DneprDave
After about four months, 16 ounce bottle.
Dave
