Drivetrain Alta CAI R53 only $118!!
Old Jan 27, 2010 | 10:39 AM
burley's Avatar
burley
The Alta CAI for R53 are only $118 right now. Its $139 and w/ 15% off comes to $118. Type in code "1RESOLUTION5" for the discount. Its the blue hose instead of red/black. If you want it enclosed its only $20 more for the lid. I think I'll wait to see how it sounds before ordering the lid.
Most other CAI are $199-250, enclosed, but w/out the silicone inlet hose.
Old Jan 27, 2010 | 11:21 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Even with the lid the sound is awesome and felt it was more or less, to provided a cleaner look to the system.
That's a great deal
Old Jan 27, 2010 | 03:18 PM
Bigshot's Avatar
Bigshot
Yep, the lid is for the looks only as the box seals up against the hood when closed.
Old Jan 27, 2010 | 03:51 PM
burley's Avatar
burley
Is it really a tight seal though? Isn't it pressed against the firewall which is pretty porous?
Old Jan 27, 2010 | 05:39 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've got a couple of the lids on closeout I need to get rid of.
http://www.waymotorworks.com/cold-ai...r-box-top.html
Old Jan 27, 2010 | 08:07 PM
herbie hind's Avatar
herbie hind
what kinda lids you californians talkin' bout lol ?
seriously i thought it was pretty well proved that the factory box or a similar material box was superior at heat reflection ? due to it's materials insulating qualities as opposed to a metal box . just slap a filter on the throttle body and be on with it .
Old Jan 27, 2010 | 08:08 PM
herbie hind
i got hai and a big hole in firewall and when on the move the heat gets pulled right out the hole baby .
Old Jan 28, 2010 | 07:01 AM
Bigshot's Avatar
Bigshot
Not sure what you mean........Alta has you remove the cowl panel during installation. So not only are you getting air from the stock grill location/tube but also from the cowl area.
The box itself has a rubber gasket that installs on the new box and seals against the hood/bonnet.
Old Jan 29, 2010 | 08:47 AM
travis2's Avatar
travis2
Hmm, when I look at the Alta site, I see the airbox only (no silicone inlet pipe) for $139. Am I missing something?
thanks.
--travis
Old Jan 29, 2010 | 09:52 AM
burley's Avatar
burley
http://www.altaperformance.com/products/show/670
Looks like its got a hose to me.
Old Jan 29, 2010 | 10:47 AM
travis2's Avatar
travis2
Duh, I was not looking at the clearance page - my bad. And thanks for the pointer. I was thinking DDMworks, but I think this deal is too good to pass up!
--travis
Old Feb 2, 2010 | 08:45 AM
burley's Avatar
burley
Should come in the mail today! Cant wait till it stops snowing so I can install it. I also want to do a before / after videos so from inside the cabin / outside on a few onramps so I can compare the sound.
Quick question about the filter, are the foam filters as good at filtering as a K&N style? I want performance, but dont want to feed my engine dirty oily air.
Old Feb 2, 2010 | 09:49 AM
ALTA_Jarid's Avatar
ALTA_Jarid
The foam filters are excellent for filtering dirt. Offroad motorcycles and race trucks have been using them for years. Just make sure you do NOT used K&N cleaner on the foam filter. Only use foam filter cleaner. Suuuuper good read about our foam filters can be found HERE
Old Feb 2, 2010 | 12:31 PM
chilimac's Avatar
chilimac
where can I get this foam filter cleaner? Any specific brands?
Old Feb 2, 2010 | 12:39 PM
ECHO-313's Avatar
ECHO-313
+1
Local auto parts only have K+N.
Any web links.
Also a question for ALTA_Jarid, do you guys sell just the foam filter and how much. Didn't see a replacement on your site.
Old Feb 2, 2010 | 01:55 PM
burley's Avatar
burley
Originally Posted by ECHO-313
+1
Any web links.
I thought it was a lifetime filter. Why would you need a replacement?
Old Feb 2, 2010 | 01:58 PM
ALTA_Jarid's Avatar
ALTA_Jarid
We sell the cleaning kit HERE
We do sell a replacement filter (if you damaged your old one OR cleaned it with solvent/gas/K&N cleanerand destroyed it) but you need to call us. 503-693-1702. Thanks!
Old Feb 2, 2010 | 02:47 PM
Bigshot's Avatar
Bigshot
You can also find the cleaners and oil at most motorcycles shops.
Old Feb 2, 2010 | 02:53 PM
ALTA_Jarid's Avatar
ALTA_Jarid
/\ what he said!
Teh
Aug 22, 2022 04:37 AM
AWOL
Mar 28, 2016 10:51 AM
Mini7
Feb 2, 2016 07:52 PM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
