Drivetrain Oil Cooler Question
Old Dec 25, 2009 | 10:30 AM
  #126
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
i think they are 10 AN on the plate, and 8 AN on the cooler.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Dec 25, 2009 | 02:34 PM
  #127
//MZero's Avatar
//MZero
PM me if you want info on my setup...I've posted about it here on NAM before also.
Old Dec 26, 2009 | 12:22 AM
  #128
yellowbritishrocket's Avatar
yellowbritishrocket
sounds good....has anyone used the small ports above the inlet and outlet holes for temp and pressure guages?do the ports work as advertised...was thinkin bout getting a temp and pressure guage set and the pod that goes under the stereo and switches....id like to have more of an indication of whats going on than just an idiot light
Old Dec 26, 2009 | 09:25 AM
  #129
//MZero's Avatar
//MZero
Bumping this thread as yellowbritishrocket is inquiring about oil coolers again. This thread has a lot of good info in it...
Now in relation to my "low" temps. I completely removed the oil cooler core from the setup both for winter as well as to get a small weep repaired. Driving without the cooler, guess what my temps are....180, the oil gets up to temp no more quickly (as I would expect) and it stays at 180 degrees which is the temperature of the engine coolant, and yes I have an OE thermostat for the coolant.
Old Dec 26, 2009 | 11:30 PM
  #130
Professor's Avatar
Professor
Very great info here! Deff going to use this when I do a cooler install!
Old Dec 27, 2009 | 05:08 AM
  #131
yellowbritishrocket
ive been looking at different types of coolers and they all seem to have the same type of mounting holes....is there a special type of bracket to secure it...the problem being in the middle east right now is that i cant look at my car or the instructions that come with the cooler kit so i cant tell very well...thinkin bout going with a larger setrab...though i dont wanna go with one thats too big...thinking either Setrab/B&M/Fluidyne/Flex-a-Lite
Old Mar 20, 2010 | 05:19 PM
  #132
jcaimbeul's Avatar
jcaimbeul
Engine Oile cooler help
Any tips on replacing an oil cooler on a 2004 S?
I'm not able to get the right angle to access the bolts.
Can anyone suggest a tool?
J
Old Mar 20, 2010 | 05:24 PM
  #133
jcaimbeul's Avatar
jcaimbeul
J
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
silence2-38554
Nov 12, 2015 09:39 AM
ShadyCoop
Aug 24, 2015 06:05 AM
danraabe
Aug 18, 2015 09:32 AM
Aug 11, 2015 09:01 AM
