Drivetrain My next mod....GRS Intercooler or RMW Street Header?
Old Jul 15, 2009 | 07:14 PM
cpayne's Avatar
cpayne
Help me choose
Old Jul 15, 2009 | 07:25 PM
Hippie's Avatar
Hippie
GRS is backed up by about three weeks right now - ask me how I know
Old Jul 15, 2009 | 07:45 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Header, as long as you can get a tune for it.
cartar452's Avatar
cartar452
How do you know?
Old Jul 15, 2009 | 08:10 PM
drsilvermini's Avatar
drsilvermini
Theres really no need for a tune with a header is there? I vote for header, I have it and love it
Old Jul 15, 2009 | 08:11 PM
ThumperMCS's Avatar
ThumperMCS
Header!
Intercoolers on the R53 are a waste
Unless you're talking water-to-air's...then you're onto somethin...
Old Jul 15, 2009 | 10:27 PM
Nazrin's Avatar
Nazrin
I agree if you talking bout any other IC out there...
but this is the GRS! it out performs every ICs out there...
and why RMW shorties if you dont mind me asking?
Old Jul 15, 2009 | 10:30 PM
drsilvermini
Why do you say that the GRS outperforms every IC?
Old Jul 15, 2009 | 10:44 PM
Nazrin's Avatar
Nazrin
loads of test done already my good Doctor...and shows that the GRS is the best topmount IC out there (best cooling/best boost/best mph/best 1/4 mile times/best recovering times from heat sink).
I cant remember were ive read it and I think you've got to search for it...and coupled with a meth kit..then I bet it'll out perform any IC out there (incl water to air)
Old Jul 16, 2009 | 12:55 AM
blue al's Avatar
blue al
i think jan recomends a tune for the header,
so cost wise you would be looking at a grs charge cooler on a like for like basis...
Old Jul 16, 2009 | 04:55 AM
BlimeyCabrio
In my experience - the OEM header is so much more restrictive than the RMW shorty that it can make a significant difference in flow. If you were on a stock tune, then probably no worries - but if you're already tuned for your current mods, the addition of the header can "break the envelope" for flow and AFRs with your current tune. I've experienced this personally.
I'm not a "Jan can do no wrong" kinda guy - but I DO love my RMW shorty. Equal-length primaries and that collector design FTW. It's loud without being "stupid loud" like some other options.
I've also heard very good things about the GRS intercooler - that's probably what I'd go with IF I was going to replace the IC - but, frankly, after monitoring IATs with my setup and with the ambient conditions in my area, I don't see where I'm going to get significant gains from any aftermarket IC - I went water/meth instead and that seems to have a bigger impact on temps.
Old Jul 16, 2009 | 06:44 AM
Hippie's Avatar
Hippie
Originally Posted by cartar452
How do you know?
Because I am waitting for mine to be shipped and Graham told me on Monday he is 3 weeks out
Old Jul 16, 2009 | 07:17 AM
Bigshot's Avatar
Bigshot
Lots and lots and even more lots of testing has shown very minor if any improvement in performance with any air to air IC.
Get the header to go with the exhaust you have now. And dump the unichip and get a custom tune.
Old Jul 16, 2009 | 08:12 AM
Nazrin's Avatar
Nazrin
to be honest, I would go for a header too!!! Mine is the Janspeed decat and it rocks!!!
Old Jul 16, 2009 | 12:19 PM
M3NTAL's Avatar
M3NTAL
Header before IC, but choose your header wisely. Don't get one that is too small or too big for your planned modifications.
Old Jul 16, 2009 | 12:55 PM
ThumperMCS's Avatar
ThumperMCS
If its better than anything, its probably only marginally better than stock...and not worth the money. The gains are not worth the money, when stock works nearly as good.
And sure with a meth kit it will outperform any IC....so will stock.
Old Jul 16, 2009 | 03:25 PM
Hippie's Avatar
Hippie
[Hyjack on] I agree but how useful/realistic is a Meth kit for everyday driving ? How often do you have to fill RMW's kit or anyother kit out there if you tune for everyday use ? - is it still worth it ? Hyjack off]
Old Jul 16, 2009 | 03:43 PM
mini_racer's Avatar
mini_racer
+1 on the RMW shorty. It is top notch hrdw, and allows you to experiment with cat back systems. A tune is not required, but sure it would help.
Old Jul 16, 2009 | 04:10 PM
howsoonisnow1985's Avatar
howsoonisnow1985
header
Old Jul 16, 2009 | 04:23 PM
BlimeyCabrio
Depends on how you set it and how much boost you use.... Mine starts spraying at about 5psi and ramps up to full spray at about 11-12psi. I use the headlight washer tank, about 2.3L. Typically a tank of water/meth lasts through 1-2 tanks of gas depending on how I'm driving. If I drive conservatively (rare) it will last much longer.
I have an on/off switch so I can turn off the system for interstate cruising - since at the speeds I drive much of that is under boost but I don't need the meth then. Otherwise cruising at highish speeds and continuous boost will eat a tank pretty quickly.
From my point of view - it's plenty practical with the above caveats. I go through a $2 gallon jug of fluid every couple of weeks.
P
Old Jul 16, 2009 | 04:44 PM
Bahamabart's Avatar
Bahamabart
While GRS is a very nice intercooler - the testing I have seen does not support your comments. Please provide thread.
Old Jul 16, 2009 | 05:04 PM
Nazrin's Avatar
Nazrin
tests from the UK Bahambart....
Old Jul 16, 2009 | 05:09 PM
JIMINNI's Avatar
JIMINNI
Since I will be in the market for a IC one of these days, could you provide a link to the testing you have seen? And I might be mistaken but I think the GRS as gone thru a change? Think I read that on Mini Torque.
Old Jul 16, 2009 | 05:12 PM
JIMINNI's Avatar
JIMINNI
I have had the same questions, in my own mind, as you. How fast can you burn thru a tank of meth on a 107 deg. day? I imagine it can get pretty expensive?
Old Jul 16, 2009 | 05:18 PM
Nazrin's Avatar
Nazrin
Well, its actually the same IC apart from the new one wont have the divertor plate...it still rocks
