Drivetrain Correcting MPG readout after installing larger injectors?
Old Jun 3, 2009 | 12:31 AM
ScottRiqui's Avatar
ScottRiqui
Another NAM'er brought up this question, and I thought it might make for a good thread.
If you install larger injectors without re-tuning the ECU, the average MPG readout in the OBC will be overly-optimistic (too high), because the OBC will be underestimating the amount of fuel being fed to the engine. This is because the OBC measures fuel consumption by multiplying the injectors' flow rate by their duty cycle (the percentage of the time the injectors are "on and spraying").
I'm sure that the factory can fix the discrepancy with ECU tuning, because the JCW cars have larger fuel injectors, and presumably their OBC MPG readout isn't any less accurate than the readout on a stock 'S'.
But does an aftermarket ECU tune like one you would get from someone like Jan correct the OBC MPG readout as well?
Old Jun 3, 2009 | 08:15 AM
Mike S's Avatar
Mike S
Mine is pretty accurate, my MPG went up as the injector sizes went up and so far has been quite accurate.
Old Jun 4, 2009 | 05:17 AM
MOTORN's Avatar
MOTORN
This will fix the problem
http://www.seattlecircuit.com/fuel_signal.htm
Old Jun 8, 2009 | 09:19 PM
O.C.abrio's Avatar
O.C.abrio
I have this problem after larger injectors and tune. Last fill-up showed 515 mile range and 36 MPG avg on the OBC! Manual calculation shows my mpg is about the same as bone stock (24.5 mpg).
I haven't contacted the tuner yet...maybe they have a way to correct this.
Is the method below a means of correcting the fuel consumption readout?
Originally Posted by thecigarman
The IKE has 21 test functions you can access by holding the trip button down while turning the ignition key. Press briefly to advance through menu options, press and hold to access that option. Tests 1&2 are always unlocked, Tests 3-21 are locked. Test number 19 is the "Unlock" function for getting to the rest of them.
Try subtest 2.0 (hold trip button, turn on key, press repeatedly to scroll up to 2.0, then hold). It runs a test that activates all gauges, LED's, and indicators.
A complete list of functions is below, this example is how to get into the menu number '7'.[/FONT]
1. With the key in the ignition, but in the off position, press and hold down the odometer reset button, while holding the button down, switch the key in the ignition to position 1.
2. The screen will say 'Test' and a number.
3. Scroll through, (pressing reset button) through to test 19 and wait a moment.
4. Wait and the message will say "log i-off" then "log i-on" and back to "log i-off" again. When "log i-off" appears, press again. You are now in the system.
5. You can (if you wish) start the ignition any time from now.
6. Scroll through to test 7.0 (or whichever from the list below) and wait a moment, after a pause you will enter the test 7.* range of information.
7. You can scroll through now (7.1,7.2,7.3 etc.) using the reset button.
8. You can exit each menu by pressing, holding for a few seconds, then releasing the reset button.
9. To leave the system scroll to 19 and leave it for a few moments.
Switching off the ignition also exits the system.
Test:
1.0 Chassis number
1.1 Kilometer count
1.2 Parts number
1.3 Coding-, Diagnostic- and Bus-index
1.4 Production Date (Calender week/year)
1.5 Hard- and Software status
1.6 Injectorstatus, Cylinder count, Engine factor.
2.0 Combisystem Test
3.0 Service interval counter
4.0 Actual fuel consumption in l/100km. eg.0154 = 15,4 liters/100kms.
4.1 Consumption in liters/100kms.
5.0 Distance consumption in l/100kms.
5.1 Actual rest distance with available fuel in Kms.
6.0 Actual amount of fuel in tank. eg. 123321 =12,3liters left 32,1 liters right
6.1 Total amount of fuel in tank.
6.2 Show value of Fuel guage. 1= both senders OK, 2= sender failure, 3=ti signal unplausible (no reading)
7.0 Actual coolant temp.
7.1 Actual outside temp.
7.2 Actual engine revs.
7.3 Actual speed
8.0 Hexadecimal readings of menu 7.0 to 7.3
9.0 Actual on board voltage (Battery)
10.0 Land codes
11.0 Unit codes
12.0 No function
13.0 Gong test
14.0 - 14.4 On board diagnostic codes. eg 000000 = no failures
15.0 - 18.0 No function
19.0 On/Off for Test menu.
20.0 Correction factor for Fuel consumption
Formula for correction:
Shown consumption x 1000 / user defined consumption
Push the trip reset button to begin the correction. Numbers count up from 0-9, when correct number shows push trip reset button.
20.1 Sets 10ths. for consumption factor
20.2 Sets 100ths. and 1000ths. for consumption factor
20.3 Saves the new consumption factor and shows new value
21.0 Software reset. (Same as disconnecting battery)
Enjoy your MINI....
Old Jun 9, 2009 | 04:21 PM
O.C.abrio's Avatar
O.C.abrio
ideas anyone?
I contacted my tuner (Mynes) and they recommended contacting my MINI dealer.
Old Jun 15, 2009 | 12:32 PM
Mike@Mynes's Avatar
Mike@Mynes
Originally Posted by O.C.abrio
ideas anyone?
the fuel consumption is controlled by the OBC (not the DME)... in order to get it reset, you can either try the method listed above or take it and have the dealers reset the OBC.
mike
Old Jul 2, 2009 | 01:18 PM
O.C.abrio's Avatar
O.C.abrio
update:
I'm still seeing up to 42 mpg avg and 500+ mile range at fill-up.
I've called a couple of MINI dealers and they only offerred a cluster reset, but did not know if that would correct things.
Anyone have luck with correcting MPG readout after installing these larger injectors?
Old Aug 5, 2009 | 05:56 PM
Mike@Mynes's Avatar
Mike@Mynes
update:
Just sent you an email.... give me a shout when u get a chance... Mike
Old Aug 5, 2009 | 07:46 PM
M3NTAL's Avatar
M3NTAL
how the hell are you getting 500+ miles to a tank with a Cooper S???
Old Sep 8, 2009 | 07:55 PM
O.C.abrio's Avatar
O.C.abrio
for those wondering
UPDATE:
Mynes can and has corrected this!
Old Sep 9, 2009 | 08:20 AM
SweetPeaBlue's Avatar
SweetPeaBlue
Originally Posted by Kavs
I don't have a menu number 20. :(
??? this is too cryptic for me... what meaning?
Old Sep 11, 2009 | 09:23 PM
Hippie's Avatar
Hippie
Honestly - If you are at the point of Modding your Mini to the level of changing injectors how concerned are you about the computers MPG read out - After all the computer is not that accurate to begin with.
Old Sep 13, 2009 | 08:58 AM
Tony@epl's Avatar
Tony@epl
This is very easily fixed in the DME.
Figure out either the % change of injector size or the % that the mpg is off on the dash and let your tuner know.
There are 2 ways to correct this....
Old Apr 15, 2011 | 12:06 PM
CORNERS's Avatar
CORNERS
Originally Posted by MOTORN
Has anyone successfully installed this? Is there a discrete injector duty signal that can be connected to this device?
Old Apr 15, 2011 | 02:57 PM
HRM's Avatar
HRM
Dude, save your money and buy a pencil. It will do the job.
Old Apr 15, 2011 | 03:20 PM
CORNERS's Avatar
CORNERS
I am not asking whether or not I should try to fix this. I am a perfectionist when it comes to my MINI and I can afford a few bucks. I am looking for an elegant solution. Thanks.
Old Apr 17, 2011 | 01:33 PM
ggcadc's Avatar
ggcadc
it seems to me, the system is set up to take changes into account, if your readings are that far off, use the above mentioned function 20 to correct it, I'm sure that's exactly what Mynes did. I went from stock 340s to 450cc injectors, no real problems with accurate mileage...
Old Apr 17, 2011 | 06:04 PM
CORNERS's Avatar
CORNERS
I don't have an option 20. The method Mynes uses to tune the cars has access to this value anyway, but I don't have a Mynes tune.
Thanks anyway.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Herleman
Aug 16, 2015 06:41 PM
Minibeagle
Aug 13, 2015 10:00 AM
