Drivetrain Camshaft Re-Grind
Old Sep 11, 2009 | 11:37 AM
  #401
Revolution Mini Works's Avatar
Paul was with slicks
big differnce with Jove on street tires
Old Sep 11, 2009 | 01:11 PM
  #402
Supercoop55's Avatar
Supercoop55
Wow, my brain hurts. This thread is too much (entertaining, though). Couple of questions; Any CA folks out there having smog failures using these cams, or are you swapping for the test every two years? The PTFE coating was an interesting proposition- I could not find the upper end heat distortion limit on that coating, anyone have any ideas how long it will last before it breaks down or wears off? Finally, what I have found particularly disheartening is the badmouthing of this forum as a source of misinformation by unqualified people. Why do those who are above this site continue to dwell in here? Move on or up, if that sounds better. I have learned volumes in my quiet observations of NAM, and find it's charactors very interesting. Sure you have to sift for facts, but I dare say that one learns as much from the unqualified folks here as from the pros (especially when you put the whole picture together, and of course do your homework!) I, for one, am grateful for the wealth of knowledge I have obtained at the generous expense of other member's R&D. Thanks for sharing! If there is a more comprehensive forum where facts are shared without squabble, can some one please share? I would love to have a place to bounce back and forth to for facting/comparing notes. To those who are actually vested in this thread, nice work, and great posts!
Old Sep 11, 2009 | 01:26 PM
  #403
Thumper460's Avatar
Thumper460
Just an up date.. I got a Text from Paul in the UK..
11.16 et @123 mph!! just cause you brought it up Naz!!
Just me.................................
Thumper
(and that would be on the Newman cam as part of his combo)
Old Sep 11, 2009 | 01:47 PM
  #404
Nazrin's Avatar
Nazrin
LOL, i knew that time but they didnt want a Nitrous time...
But saying that, that has to be some kinda record! Well done to Mike n 1320s
Old Sep 11, 2009 | 04:47 PM
  #405
k-huevo's Avatar
k-huevo
Originally Posted by Supercoop55
...I could not find the upper end heat distortion limit on that coating...
500F steady, 600F peak, but it wouldn't go away completely due to substrate impregnation.
Old Sep 11, 2009 | 06:35 PM
  #406
Supercoop55
Great to know, thanks k-huevo! That coating has some great potential in other apps as well.
Old Sep 11, 2009 | 09:03 PM
  #407
Hippie's Avatar
Hippie
Also K- huevo has a great install instruction on his site - he gave me info/advice/help even though I did not go with his cam . The only thing his install forgets to tell you is to remove the spark plug wires
Old Sep 11, 2009 | 10:07 PM
  #408
Paul Webster's Avatar
Paul Webster
Originally Posted by xr3i_alloys
Jove 13.1
13.1919
Old Sep 11, 2009 | 11:42 PM
  #409
xr3i_alloys's Avatar
xr3i_alloys
Originally Posted by Paul Webster
13.1919
11.16@123
Old Sep 13, 2009 | 12:00 PM
  #410
dustinhxc's Avatar
dustinhxc
How much hp/torque would i get from a ns1 cam? I have:
Magnaflow 2.5" Custom Exhaust
ALTA 17% v2.0 Pulley
ALTA v2.0 Cold Air Intake
ALTA Red Silicone Tube
ALTA Tensioner Stop
NAPA 535 Belt
MSD Ignition Coil
JCW BKR7EQUP Spark Plugs
Kingsborne 8MM Red Spark Plug Wires
Detroit Tuned ByPass Valve
180F Thermostat
Old Sep 13, 2009 | 02:48 PM
  #411
ninjlao's Avatar
ninjlao
Ninja Mini
All this talk of "camps" and character assassination makes me think I'm in a camp of my own when it comes to my cam.
Old Sep 13, 2009 | 07:11 PM
  #412
Longboard Mini's Avatar
Longboard Mini
11.16@123
And a big shot of phantom power .
LB
Old Sep 13, 2009 | 07:37 PM
  #413
Thumper460's Avatar
Thumper460
Yep.. and stock rods.. stock pistons.. stock rings.. stock bearings.. oh and 70,000 miles on the short block!! AND not a BVH!! amazing what a bit of the "Phantom" power can do... 11.16 @ 123!! Good job ..Paul!
check it....
Super Street!
http://www.eurodragster.com/santapod...s/thursday.asp
Just me............
Thumper
Old Sep 13, 2009 | 08:08 PM
  #414
Chase's Avatar
Chase
that is awesome
Old Sep 15, 2009 | 09:45 PM
  #415
Nazrin's Avatar
Nazrin
Has the new Cam arrived? have you installed it? reviews dude
Old Sep 19, 2009 | 04:35 PM
  #416
k-huevo's Avatar
k-huevo
Originally Posted by #Dragon#
Can anyone post a picture of the ns 1 and newman cam side by side to compare size and quality
Newman/RMW camshaft on the left, Crower NS1 on the right. Notice the rough as cast sand features on the Newman camshaft (left), which leaves burrs on the lobe edge, cuts on the mold line are potential stress risers. What can't be seen in the photo is the Crower/NS1's (right) micro-polished surface on journals and lobes. The Newman/RMW bearing surfaces have a brushed finish. Forget the size BS; the only thing a visual “size” comparison will come close to telling is how hard it will be on the valve train. In actuality the Newman/RMW looks square compared to the NS1.
Old Sep 19, 2009 | 05:47 PM
  #417
Thumper460's Avatar
Thumper460
LOL.. 418 Posts and we are down to being able to "see" the difference?? My Eyes must be out of calibration?? I just can NOT see the difference of .009 or .023 of cam Lobe lift?? Must be an OLD thing??
I think it is time to get over this.. I can say the cams deliver!! The FASTEST BMW MINI in England ( super street class 11.16 @ 123 mph) is running the Newman cam, the guys in Germany doing 150+ on the Autobahn are running the Cat cam, and here in the US we *****!! WTF?? We have choices... the Newman quality of the casting of the cam is bad on THAT core.. the Re-grind NS cams look premo on the OEM BMW cores..but IF I lay all three ( Newman/NS1 and NS2 cams side by side that I HAVE..) It would be a bit harder to tell !! I think if it wasnt all about the "Custom Grind" statement a few months ago.. there would not be this controversy?? I can tell you that ALL the Cams do what they say.. I know cause I spent all day on the dyno in 90+ Fl heat running them!!
Get over the "shoulda - coulda-woulda" attitude!! Pick a cam for your application.. or belief on quality.. or belief of Re-grinds..or cost against performance. They all work and out power the older Schrick of past!! regardless of the "Magic Tune" or not.. they work!! More power is there.. and (so far) there are no idle issues or lights being thrown.
Stop all this junk on trying to dis any of these camshaft.. they all have their quality, and power gains and they all work!!
But then this is
Just me..............................................
Thumper
Old Sep 19, 2009 | 06:01 PM
  #418
onasled's Avatar
onasled
Good post Thumper.
When you think about it, we should just all be lucky that we now actually have choices. One's better for me and the other for you. If the vendors would just maybe understand that it's not really who's is "THE best", then we could get past all of this crap we are going through here.
Thumper, I hope that maybe sometime, sooner then later, we can see results from yours and others cam testing and just decide what's best for the individual "us" .
Tired of this stuff ......
Old Sep 19, 2009 | 09:13 PM
  #419
Hippie's Avatar
Hippie
But then this is
Thumper
Right on T I recently went through the "which cam should I get ????" and after researching and talking to the folks making and selling the cams made my choice based on what performance profile I wanted.
Your post is spot on - this board gets caught up in the camp a vs camp b vs camp c garbage and loses sight of the orignal need/want
Old Sep 19, 2009 | 10:14 PM
  #420
Supercoop55
Any Ca folks having smog issues w/ any of these aftermarket cams?
Old Sep 19, 2009 | 10:21 PM
  #421
Nazrin's Avatar
Nazrin
Mike, so you have done the testing....go on then...post the results..I think everyone in the Mini world would love to see the results..
Old Sep 19, 2009 | 10:25 PM
  #422
Hippie's Avatar
Hippie
I agree - I for one would like to see a second set of results of "the cam comparison" - of course this group will pick it apart no matter what the results and claim victory
Old Sep 19, 2009 | 10:41 PM
  #423
maxmini's Avatar
maxmini
I passed my SMOG test a few months ago . I have a Schrick cam. Some other relevant things might be a Vitesse Pro tune, 400 cc injectors and a 64mm TB.
Randy
M7 Tuning
Old Sep 20, 2009 | 04:34 PM
  #424
JIMINNI's Avatar
JIMINNI
Randy
M7 Tuning
I will be getting mine done in a few weeks. Will try and remember to post results
Old Sep 21, 2009 | 09:27 AM
  #425
jhiggs26's Avatar
jhiggs26
So Thumper what cam did you MINI love in the FL heat?
In the JCW injector/flash thread you mentioned going back to stock injection. Are you running your cammed MINI with stock map and/or stock fuel injectors now?
Jeremy
