Drivetrain Stock bypass valve/check engine light
Old Apr 6, 2009 | 10:48 AM
Cawtou's Avatar
Cawtou
I have a r56 MCS that has several modifications: Alta FMIC, Alta CAI, Greddy Type-rs blow off valve.
Ever since I installed them they have been running fine until..
Yesterday, I was driving around and pushed the MINI to about 6000 rpm, when I heard this loud pop. then the engine seemed to become sluggish and the stock bypass valve could no longer be heard. After parking and restarting the engine, the check engine light came on.
Im assuming the car's stock bypass valve blew or something.
Btw, the car runs normal (no stalling or awkward engine idling) after this event. Just the CEL is on. Also, no strange sounds or boost leaks seem to be heard.
Has this ever happened to anyone? anyone know of a solution or what the problem may be?
Old Apr 6, 2009 | 10:51 AM
a96bimmerm3's Avatar
a96bimmerm3
I seriously doubt that. You probably blew off a pipe or coupler. If your car isn't making boost you won't hear the stock dv.
Old Apr 6, 2009 | 10:56 AM
Cawtou's Avatar
Cawtou
I see. I also for got to add that when I push it to around 3000 rpm, I can hear the installed greddy but still cant hear the stock dv
Old Apr 6, 2009 | 10:59 AM
a96bimmerm3
Greddy valves are notorious for leaking if they're not set quite right. Get the car scanned and look over all of your pipes, I really don't think you blew up your stock dv.
Old Apr 6, 2009 | 11:06 AM
Cawtou's Avatar
Cawtou
either way. something isnt right, since the stock dv is suppose to operate in normal boost conditions. I rechecked my pipes and seems like no leaks. idk. what do you think?
Old Apr 6, 2009 | 11:28 AM
AkFarina's Avatar
AkFarina
sounds like you blew off or almost blew off one of your intercooler tubes.
Old Apr 6, 2009 | 12:01 PM
Cawtou's Avatar
Cawtou
just checked and seems like the tubes are fine. and sounds like there are no leaks when engine is running
Old Apr 6, 2009 | 12:29 PM
a96bimmerm3
Does the car seem slower than normal?
Old Apr 6, 2009 | 01:16 PM
Cawtou's Avatar
Cawtou
yea. the throttle response is not as it was before the incident.
Old Apr 6, 2009 | 01:33 PM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
POP = hose blowing off.
Old Apr 6, 2009 | 01:36 PM
Cawtou's Avatar
Cawtou
do you know which one it might be?
Old Apr 6, 2009 | 03:01 PM
Exhaust Depot
LOL. Yes. TUrbo to hotpipe, hotpipe to fmic, fmic to cold pipe, cold pipe to throttle body. Its one of those.
Old Apr 6, 2009 | 03:08 PM
richi0207's Avatar
richi0207
Yeaa sounds like a boost tube popped off, happend to me a long time ago. Its nothing to worry about, just find the piece thats loose and tighten that clamp! Motor on
Old Apr 6, 2009 | 04:17 PM
Cawtou's Avatar
Cawtou
sweet, all fixed. thanks to everyone that helped. i wouldnt have known what to do since im new to minis.
Old Apr 6, 2009 | 04:24 PM
Exhaust Depot
Check the hose coming off the turbo that goes to the intercooler. Chances are the clamp came loose from under it. It looks ok up top but under the silicon it comes off if you dont install it correctly.
Old Apr 7, 2009 | 01:39 AM
AkFarina's Avatar
AkFarina
what hose came off?
Old Apr 7, 2009 | 11:03 AM
Cawtou's Avatar
Cawtou
what hose came off?
the hot side of the intercooler where in connects to turbo ouput.
Old Apr 9, 2009 | 12:37 AM
Noegel's Avatar
Noegel
Yeah, it took me a couple of tries to really get that tube suckered on. It was a terribly tight fit!
wkp1219
Nov 13, 2015 07:52 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
