Drivetrain Historic dyno moment 24.1.09
Old Feb 2, 2009 | 08:45 PM
  #326
BigShow's Avatar
BigShow
Originally Posted by big howe
What is really amazing is the comparisons from the same day.
Ruskins car looks basically stock and full weight except for a cam, header and tune. He has a stock head and 11% pulley.
Ruskins runs two tenths slower and 1mph less than Paul's car. Paul's car has a head, 17% and everything else you can imagine and it is gutted down to nothing.
Either Ruskins driving defies the laws of physics, or Paul has a serious issue. Paul's car was faster with the stock head. How can that be?
Why did your car make only 242 whp on the dynapack?
Old Feb 2, 2009 | 08:48 PM
  #327
Revolution Mini Works's Avatar
Originally Posted by BigShow
LOL...the only what that was repeatable? 1/4 mile time? Dyno graph? vBox figure?
Physics - which bit, classical mechanics, thermodynamics, electromagnetism, relativity, quantum mechanics???
You seem to think I'm junking your head here... I'm not, remember when your only goal was to beat GTT in the horsepower race in the UK, well how did we do that??? Your head mixed with a shed load of other quality parts and then we backed it up on th drag strip so Roland couldn't counter... drag racing times were good enough for you then so whats changed.
if the drag racing is the end all be all then a gutted car on slicks with a 17% pulley , the Thumper head and semi pro driver is only 1mph than stock JCW car with header and cam on street tires.
You cannot make excuses if this is your argument.........
Old Feb 2, 2009 | 08:56 PM
  #328
big howe's Avatar
big howe
Well Mr. Physics, if you could read a dyno plot you'll notice that the runs were only to 7000rpm because of everyones whining about comparable numbers at stock rev limits. My car will make power all the way to 8000, we usually cut the runs at 7600.
Next question.
  #329
Paul Webster's Avatar
Paul Webster
Look out the experts are out I have two things to pull off the car now which are the following 1; The Apexi Safc2; The engine wiring loomAs I've said in a previous post I've only averaged 2-4 hrs sleep a night on project which I hope to get the contract for, work first play later.I knew the car wasn't right on the way home Sat night, on the 4th acceleration test it went really well so I knew I still had gremlins, but guess what I still turned up and was so proud off Jove running what he did, just means I have to go 109 now.There has been some weird **** happening just lately with the AFC so I presume its that. Dont forget I've only had the head on for two weeks, how long did it take for you do Longboards Rotrex before you were happy with it or the water metk kit? I found if you use 240 in the horepower drag racing formula, based from Ruskins acheivng 101.9 and weighing in at 2750 (guesstimate) his come out at 210 exactly the same as he made on the dynapack hub dyno.So based on that, Jove made 229 (230 hub horsepower on dyno) and I made 210 (227 hub horsepower on dynapack) So it was quite obvious I had problems, even a 9 year old worked it out and i behaved myself quite well by not doing what he suggested."just switch the nitrous on Dad"
Old Feb 2, 2009 | 08:59 PM
  #330
Paul Webster
Sorry about the above but it keeps bunching the text up for some unkown reason
Old Feb 2, 2009 | 09:02 PM
  #331
BigShow's Avatar
BigShow
As I've already said... dyno, drag strip and on road performance testing is IMO the most accurate way to measure a cars performance.... All I'm asking for is one of the latter from the one of the RMW cars in the US to compare to the RMW cars in the UK.
I'll repeat what I've said before... Paul's car was not running right on the day, the issue seemed to be electrical but until he's had a chance to look at the car properly I'm none the wiser and am only speculating. Once he has I'm sure he'll be on here giving everyone the diagnosis. However, it didn't perform on the day, just as mine didn't at the AMD RR day when it made only 263 bhp... but you have to live with it, work the problem and come back bigger and stronger to prove the maximum the car can offer.
Jove's car did this on Sunday... there is no way he can go quicker than 13.1 with his current set-up, there is no more to give and I'm sure Pauls car with the Thumper head will get to that point soon enough. Afterall it took Jove the best part of 3 months to prove what an RMW car can do in the UK, so I think it's only fair to allow Paul to do the same with the Thumper head.
Old Feb 2, 2009 | 09:03 PM
  #332
big howe's Avatar
big howe
Originally Posted by Paul Webster
Look out the experts are outI have two things to pull off th ecra now which are the following1; The Apexi Safc2; The engine wiring loomAs I've said in a previous post I've only averaged 2-4 hrs sleep a night on project which I hope to get the contract for, work first play later.I knew the car wasn't right on as on the 4th acceleration test it went really well so I knew I still had gremlins, but guess what I still turned up and was so proud off Jove running what he did, just means I have to go 109 now.There has been some weird **** happening just lately with the AFC so I presume its that.Dont forget I've only had the head on for two weeks, how long did it take for you do Longboards Rotrex before you were happy with it or the water metk kit?I found if you use 240 in the horepower drag racing formula based from Ruskins acheivng 101.9 and weighing in at 2750 (guesstimate) his come out at 210 exactly the same as he made on the dynapack hub dyno.So based on that, Jove made 229 (230 hub horsepower on dyno) and I made 210 (227 hub horsepower on dynapack) So it was quite obvious I had problems, even a 9 year old worked it out and i behaved myself quite well by not doing what he suggested."just switch the nitrous on Dad"
Why would a "pro" tuner with a full Dimsport package be running a AFC on his car? This is even more baffling than the stock head going faster. I really cannot believe you are running an Apexi on your car as a tuner
Changing a head is a bit different than developing a completely new system like the Rotrex. Do you think you are breaking new ground installing a head?
Old Feb 2, 2009 | 09:05 PM
  #333
can you not understand that different tracks show different times? Shawn has shown you this repeatedly........... at what point does it sink in?
by the looks of all of these threads.... I would say....NEVER
Old Feb 2, 2009 | 09:08 PM
  #334
BigShow's Avatar
BigShow
Next question.
Ah ok thanks for explaining, so without meth it makes how much at 7600?
Old Feb 2, 2009 | 09:09 PM
  #335
Paul Webster
Originally Posted by Churchautotest
Is it in Wellingborough? If so, the temp and humidity for this last weekend put the DA at about -1200 to -1500 ft depending on time, etc. So you would have to multiply your ETs by 1.012-1.02 to get an equivalent time on a normal day (and multiply trap speeds by .98 to .988 to get equivalent traps.
Sounds like you guys get some decent atmospherics, even if the temps are too cold for good traction. Kind of like Englishtown which will see DAs as low -2000 ft or more during the right time of year. By comparison, our west coast tracks are lucky to see DAs of less than +1000 ft and will often go over +2000 ft (Palmdale used to see +5000 ft in the summer).
I use this calculator for Density Altitude and then just look up NHRA Density Altitude correction and you'll find tables all over the net.
http://wahiduddin.net/calc/calc_da_rh.htm
Long story short, a day like you guys had last week would be about 3% faster than a solid day at a track like Pomona (800 ft, 59F, 0% humidity - and Pomona rarely gets that cool).
p.s. - turbo cars need not apply since they can make up for atmospheric changes with more boost - to a point
Nice post Shawn, I did remind people several times on the day that this was a one off and they might not see these times again all year.
Old Feb 2, 2009 | 09:11 PM
  #336
so thanks again Paul for proving my point that drag racing is variable based on conditions...... drivers...... equipment......... blah blah blah
Old Feb 2, 2009 | 09:13 PM
  #337
Paul Webster
As we pointed out in the other thread we only have 3 tracks in the UK and they are all at sea level.You're not going to believe this but we dont have a SOW here either.But hey Shawn has a performance box just waiting for you to use on teh TVS when its done, do you know when that'll be?
  #338
big howe's Avatar
big howe
Doesn't matter, at 7000 without meth it still made more than any of you. Why do you care, I won't post any times so it doesn't matter anyway right? But thanks for asking. I enjoy going and dusting the 262 off the mantle for your questions.
Old Feb 2, 2009 | 09:14 PM
  #339
as I told you before..........I will go sub 2 at Buttonwillow
  #340
BigShow's Avatar
BigShow
Oh ok so I get your thinking here... so your saying Churches Dyno will read exactly the same as the Thor dyno i.e if I run my car at Thor then ship it to Churches it'll give the same hp reading?
Old Feb 2, 2009 | 09:16 PM
  #341
Paul Webster
Dont you know nothing??? I cant believ you called yourself a drag racer.2 differnt drivers same car 101.9 mph: 1 x Pro driver: 1 x Owner
Old Feb 2, 2009 | 09:17 PM
  #342
based on what I saw for the lesser modded cars
yes....
Old Feb 2, 2009 | 09:23 PM
  #343
BigShow's Avatar
BigShow
Nope, just proves you cant answer a straight forward question so any future argument you put forward is based on nothing but conjecture. Congrats!
  #344
Paul Webster
Hey big howe I've sussed out why you're so angry, you still dont know what a sub 13 sec 0-100 feels like rotflmao
Old Feb 2, 2009 | 09:24 PM
  #345
big howe's Avatar
big howe
If thats the best you have.........
Old Feb 2, 2009 | 09:26 PM
  #346
Paul Webster
In fact big howe I bet you cant show any ET difference with the W/M on in any gear?
  #347
BigShow's Avatar
BigShow
yes....
Interesting... so you'll stand by this statement if I drive from one dynapack to another on the same day and get 2 different readings?
I'll happily take 'You'd need to take the average of the 2 readings' as your answer
Old Feb 2, 2009 | 09:29 PM
  #348
BigShow's Avatar
BigShow
See post 343
Old Feb 2, 2009 | 09:32 PM
  #349
big howe's Avatar
big howe
That would mean I would have to actually go to the dragstrip to show an ET, which I have no desire to do. The dragstrip is your area, not mine. I go to useless dynos, remember?
1mph and an AFC, Paul I just don't understand?
Old Feb 2, 2009 | 09:37 PM
  #350
Paul Webster
but you have the innovate data logger fitted so you dont have to go to the dragstrip, 30 -70 30 -100. ...Shows you're a newbie to Mini tuning if you dont have an AFC fitted
