Drivetrain uh oh, water/meth injection...
Old Dec 22, 2008 | 10:23 PM
scott48's Avatar
scott48
installed a system on my car...details to come
Old Dec 23, 2008 | 05:28 AM
BlimeyCabrio's Avatar
BlimeyCabrio
This is as bad as one of Jan's threads.
Old Dec 23, 2008 | 12:23 PM
fernflex's Avatar
fernflex
Let me know I want that for mine.
Hey Scott have you ever gone to the dyno, you and I have pretty much the same stuff on our cars.
Where did you buy this?
Old Dec 23, 2008 | 01:13 PM
got.pho?'s Avatar
got.pho?
did u use a universal kit? justin from jscspeed put one on but never any details. let us know!
Old Dec 24, 2008 | 09:28 AM
scott48's Avatar
scott48
Well after seein what was systems were available and what I could get my hands on, and after talkin to some people, I went with the kit from AEM...It's progressively controlled based on boost, it has a couple of safety features and warnings, checkvalve, etc, and overall I gotta say it's a pretty nice setup, and runnin 50/50 mix....The hardest part bout the install was just plumbing the wiring, etc thru the car cuz I mounted the tank and pump in the trunk...I think it took like 3.5hrs to install...And so next week I'm gonna get it re-tuned for the w/m on the dyno at a local tuning place, so we'll see what kinda power she makes.
Old Dec 24, 2008 | 09:38 AM
fernflex's Avatar
fernflex
Before the kit was installed do you know your whp and tq at th wheel?
Old Dec 24, 2008 | 09:40 AM
scott48's Avatar
scott48
no cuz i didn't dyno it yet, but I'd say she's definitely one of the stronger ones out there...but when i do, I can just turn the w/m off and dyno it, then turn it on and dyno again......I'd hope like 240whp with w/m based off a approx. 220whp start point, and make a ton of torque, we'll see
Old Dec 24, 2008 | 09:48 AM
fernflex's Avatar
fernflex
Right know our Mini's must be running very simillar. I have been looking at those kit's but I ordered some new Enkei wheels so the kit will have to wait. a little longer...
Please keep us informed to see the progress.
I think you are going to be around 235 -245 whp with the kit installed and almost 250-260 of torque.
Merry X-mas to all of you!!!!
Old Dec 24, 2008 | 09:55 AM
scott48's Avatar
scott48
^^what peak boost do you see tho??
Old Dec 24, 2008 | 09:59 AM
JAceMin's Avatar
JAceMin
how are you tuning? What did I miss, I thought you were running an Alta Unichip... Did you find a real solution?
Old Dec 24, 2008 | 10:00 AM
fernflex's Avatar
fernflex
Im seeing between 20 and 21 peak and stays at 15 -17.
I have to record a video, let me see if I can do it today.
Old Dec 24, 2008 | 10:04 AM
scott48's Avatar
scott48
yeah that's what I have, but I met a local tuner who does protuning for unichips, and that's what I'm gonna do
Old Dec 24, 2008 | 10:59 AM
SlowB00st's Avatar
SlowB00st
Check is he can input a signal from the wi to the unichip so that when its on it has a different timing table . simple mod to do if the wi kit has this option.
BTW the unichip has what they call a "High resolution 02 channel" & "Lambda sensor Manipulation" you should check with him if this is wideband compatible or just regular narrow band setup since this will give us control of fueling to a certain point, meaning on stock turbo since i doubt the ecu will be happy to add fuel for a turbo setup unless someone checks if the injector outputs are 12v somewhere since I know the injectors see 85v.
Old Dec 24, 2008 | 02:05 PM
scott48's Avatar
scott48
yeah map 0 will remain what i have, and then map 1 will be for the w/m injection with the boost, fueling, timing adjusted.
Old Dec 24, 2008 | 02:59 PM
big howe's Avatar
big howe
Just my 2 cents
Be careful when running different maps for the WM. Most kits don't provide any confirmation that they are actually spraying. I know a few of the big names in WM show flow based on pump speed, which means they show they are injecting even if the pump is dry or the line is pluged........
SemperMini
Oct 17, 2014 10:52 AM
miniforozzie
Apr 4, 2014 02:48 PM
dunphyj
Jan 25, 2010 09:57 PM
Malcon
Nov 28, 2008 12:44 PM
D-MAN
Jun 22, 2008 07:17 PM
