Drivetrain M7 vs Alta intercooler, what one and why?
Old Jun 12, 2008 | 11:26 AM
  #351
Intense's Avatar
Intense
252whp 200trq RMW style
Here is something that I don't understand at all. I hope that someone can please explain it to me.
I read this contradiction allot on this board.
"You don't need a intercooler upgrade until further down the mod list"
then in the same thread I will read from the same user
"I have over 250hp and the stock IC is by far the best"
If someone can explain that too me I would much appreciate it, what am I missing here. Or is it a tactic so people won't buy from a vendor?
Always been baffled by that one
Old Jun 12, 2008 | 11:28 AM
  #352
Intense's Avatar
Intense
Originally Posted by Revolution Mini Works
I have an extra set of horns.... we can drill them and install them and then Rob can go back to stock.... what's the point of using shoddy equipment if we are going to go through the process to find out?
Are probes that stick into the airflow from the ic boots going to be that much more inaccurate than ones that drilled into the horns?
Just asking the question, I don't know
Old Jun 12, 2008 | 12:51 PM
  #353
Longboard Mini's Avatar
Longboard Mini
The guy who has done more testing of IC's then even the people who make them comes in here explaining it all very clear and non of you here him
Thanks Doc! I always look forward to you killing a thread with basic reasoning. You always make it sound simple which it isn't.
And Happy Fathers Day to you in advance .
Bryan
Originally Posted by Dr Obnxs
is the fact that extreme conditions really illustrate the differences. If you're not in a stressed environment, then there is really little or no benefit to be found. Here's an example. You do testing at a constant freeway speed of 70 mph and measure IATs. One shows a bit lower than the other. What good is this? What does it mean for power production? I'll tell you what it means, it means close to nothing. The reason is that the car isn't on boost, and you're not flowing that much air through the IC, so pressure issues (poor vs good conductance) don't show up. Then the aftermarket ICs are show pieces.
Really, there are two ways to really test ICs. One is with lap times at a track, preferably a windy one with lots of speed changes, the other is with a set of very controlled experiments (like weight, bench airflow, or what I used to to,second gear 20-redline tests). And then, the very controlled experiments still don't tell you how things will be in all environments. BUT they will provide insights into what you have to deal with. Increased mass leads to longer temp time constants, higher pressure drops make whatever is compressing the air work harder (can be a big issue with Eaton SCs).
Basically, you test in extreme conditions to really make the differences show up, then you hope that part of the measured difference actually provides benefit on the street.
Matt
Old Jun 12, 2008 | 02:03 PM
  #354
Intense's Avatar
Intense
Bryan
I have actually been reading his post trying to wrap my head around it.
I do have some comments/responses broken out after the quotes.
Believe me when I say I respect everything you have to offer us Dr.O None of my questions are intended to be derogatory at all. (More risk of the noob in me coming out than anything I'm guessing)
I can see your point here and I agree that just freeway driving will prove nothing. Just running air over IC's will be pointless for everyone. I do plan on a little of everything, freeway, canyon, onramps and normal city driving. My car will be driven with boost believe me in some instances.
I understand the benefit of using a controlled environment for testing. But I have to disagree with you when you say there are only two ways to test. Dyno runs do not take into consideration hood scoop design, air diverters etc. I think these things will play an Integral part in this testing
I think that there is benefit to real world testing as well. Now everyone doesn't live in Utah at 4000ft elevation with canyon roads so the tests I do would certainly have to be taken with a grain of salt.
I guess I'm "hoping" that what I do will show some benefit to users as well
Old Jun 12, 2008 | 02:09 PM
  #355
BlimeyCabrio's Avatar
BlimeyCabrio
The guy who has done more testing of IC's then even the people who make them comes in here explaining it all very clear and none of you hear him
Au contrare... I heard him loud and clear... and have MASSIVE respect for the good Dr...just trying to understand if track torture testing can REALLY reliably identify the best performing part for significantly different street/canyon conditions and corresponding driving patterns... I KNOW that there are street conditions that can't be simulated on the track or skidpad for suspension testing... unless your track has washboard pavement.
Old Jun 12, 2008 | 03:49 PM
  #356
Paul Webster's Avatar
Paul Webster
Drag Racing is the worlds worst place for a top mount IAT, a road course is next.
You have to treat IAT as the God of horsepower off a Mini, I know some of you think that its Jan , Peter or Adam, but you wrong because they dont sit on top of your engine every day deciding what IAT you have today and thus what hp you're allowed.
Old Jun 12, 2008 | 04:02 PM
  #357
Larry Clemens's Avatar
Larry Clemens
Correct me if I'm wrong but I thought Dr O's IC tests showed that the M7 DFIC was a good IC for the street and had fast heat-soak recovery. I think he referred to it as the "cats meow" for the streeet. At high RPMs the DFIC is not so good. Therefore how can testing the DFIC under extreme track conditions, where we know it sorta sucks, tell us about its street behavior which apparently is pretty damn good???
Old Jun 12, 2008 | 06:03 PM
  #358
ALTA2's Avatar
ALTA2
Manufacturer
Good point, i would like to see that, Adam Jan, and Peter all sitting on the engine! This is only because of how aggressive the ECU is programmed. Keep that in mind, as this plays into why we choose what we chose.
I got very busy today with things, but a full report will be posted tomorrow.
Old Jun 12, 2008 | 06:54 PM
  #359
big howe's Avatar
big howe
Originally Posted by Intense
Again, this is perception. The data/information gathering that I do will provide helpful information to part of this community .
Well, I will respectfully disagree. It is your perception, and maybe that of many others on this board, that your test will actually give any data that means anything. It unequivocally will not.
I cannot, in any way, understand how Physicist's, Scientists, and people who do this for a living can come on and explain how how these things work, and everyone will continue to believe what they "feel" or "like" blindly. There is no use continuing to argue over this. As I said before, this is yours and Peter's party, do what ever you please.
P.S. This as absolutely nothing against you Intense, just against the propagation of bad information
P.S.S. Longboard, I feel your pain.
Old Jun 12, 2008 | 09:15 PM
  #360
JIMINNI's Avatar
JIMINNI
You are one positive person.......NOT! P.S. Who are the physicist's, scientists and people that do this for a living that your talking about? I haven't seen any IC manufactures in this thread? Ala, Bell.www.bellintercoolers.com
Old Jun 12, 2008 | 09:21 PM
  #361
big howe's Avatar
big howe
If you haven't figured it out already, me explaining it again won't help.
Old Jun 12, 2008 | 09:25 PM
  #362
JIMINNI's Avatar
JIMINNI
you haven't helped this thread at all.
  #363
Revolution Mini Works's Avatar
you have learned well grasshopper
Old Jun 12, 2008 | 09:27 PM
  #364
believe me... those people who you seek are reading this thread
Old Jun 12, 2008 | 09:35 PM
  #365
Intense's Avatar
Intense
Well man, to be honest with you the last thing that I want to bring to this community is bad information.
If the community feels like its a waste of time then certainly I won't want to waste mine. To do these tests is hours of time swapping, driving, computer and sensor set up. The ONLY reason that I want to do this is for the community. I have no affiliation with Peter or M7 other than I purchased and stand behind some of his parts. I'm not getting paid for this or receiving anything in trade just fyi.
I appreciate every vendor and every member ( yes even you Scottinbend ) out there. I think for the most part everyone is sincerely trying to help each other. Anyway, thats all I was looking to do for you guys. I've made my purchases and I'm content with them. ( Well except for that damn head and header Jan keeps tempting me with ) I just want to help others make their choices.
I respect and value the opinions of Jan at RMW and all you high horsepower racers out there. You guys bring a ton of excellent info, knowledge and parts to this community. I think that the track has inspired the majority of mods that we enjoy today.
I respect and value the opinions of Peter at M7. I have spent hours on the phone with him trouble shooting things that weren't related to any parts of his. He still offered his time to help me. I value the parts I have purchased from him, I think he offers excellent performance products for all of us.
What I guess I'm trying to say is my car has been put together with parts from many vendors. I'm proud of them all, the names in my sig represent hours of research and hours of fun installation time. I like to wear them like a badge. Call me crazy or a nutjob but at the end of the day I'm just a Mini enthusiast like the rest of you. I love my car and I love researching and testing products. I thought it would be a fun challenge for me and that the data could help the NAM community. Thats all... anyway. Its allot of time and effort that will be spent for nothing if thats the general consensus
Old Jun 12, 2008 | 09:46 PM
  #366
look Rob.... you are the luckiest man on the earth....
as I told you before... it's a win/win for you
your wife get's what she wants and you get your toys for your car too
Old Jun 12, 2008 | 09:56 PM
  #367
Intense's Avatar
Intense
hahaHAHA! I hear ya! The part of this you don't know is she's talking Dr 90120 style man, youve seen his lifestyle right? Whole different price range my friend
Old Jun 12, 2008 | 09:58 PM
  #368
think quality man... quality
Old Jun 12, 2008 | 10:15 PM
  #369
Intense's Avatar
Intense
Quality parts in hand, and quality parts to drive.... Ah yes, the perfect combo! Back in reality I'm waiting on a financial deal to come thru. Its only a matter of time for both purchases
Last edited by Intense; Jun 12, 2008 at 10:18 PM. Reason: spelling is hard on an iPhone at times....
Old Jun 12, 2008 | 10:23 PM
  #370
ScottinBend's Avatar
ScottinBend
from the man of few emoticons
Old Jun 12, 2008 | 10:38 PM
  #371
roggenmini's Avatar
roggenmini
I guess I still have to say that I think the testing will be worth while even if it is just for Intense' piece of mind. Plus being the computer geek that I am, I am looking forward to seeing how this whole system comes together. After all when it comes to Mini I love it all, my wife thinks that I am crazy but I guess I can't understand her quest for new yarn or a new cake design.
I can't wait to see what comes next in this forum. Which valve stems are better? Should I run air in my tires or should I swap it out for Nitrogen? What will the next battle be?
Old Jun 12, 2008 | 10:40 PM
  #372
JIMINNI's Avatar
JIMINNI
Different scoops?
Old Jun 12, 2008 | 10:43 PM
  #373
roggenmini's Avatar
roggenmini
I like 31 flavors!
Old Jun 13, 2008 | 12:46 AM
  #374
billzcat1's Avatar
billzcat1
Nah... different tires. Since there are dozens of tires available and certainly no one has tried them all, I'm sure we can argue about which one our experience tells us is far better than those we have not tried.
On that note, I must say that stock is better than aftermarket....
Here's one vote for Eagle RS-A runflats!
Old Jun 13, 2008 | 05:47 AM
  #375
Bahamabart's Avatar
Bahamabart
The reason many (including myself) say that IC replacement is further down the mod list is because there are better ways to direct the money in pursuit of performance gains. ICs are tempting, for they are a center piece of the engine bay. For moders its a magnet - having a big bad looking IC when you pop the hood is awesome. I know I have had 4 ICs !!! SO this is why its also further down the list - I.e. do the mods that give you the real HP gains and once done if you still got funds and need that awesome looking engine bay - buy an Ic.
LB has 250 hp and has not found an after market IC to give him anything over the stock IC so logically why change it and spend $$ for no benefit.
The stock IC has proven to do the job very well. No after market IC has delivered better thermal efficiency vs pressure. Some after market ICs have better thermal efficiency but at a cost of pressure drop. Others less pressure drop but at a cost of thermal efficiency. The after market ICs trade one quality for another. Is this BAD? No depending on application.
But its not just HP, its driving (stop and go traffice or a constant 70mph) as well as location (temps and humidity - Canada or Florida).
If your gonna do testing, I would encourage you to talk w/ DocObnoxious who has tested 4 IC units. I would replicate his testing and merge your data w/ his for I think it would give the community the best picture. He already did the M7 DFIC ver1 so adding ver 2 would show us the direction M7 has gone w/ their DFIC development.
