Drivetrain Why have a resonator?
Old Apr 26, 2008 | 03:54 AM
FLKeith's Avatar
FLKeith
The resonator on the Alta cat-back I have just installed looks just like a muffler - is there any functional difference between a resonator and a muffler? How much louder would the car be without a resonator? Would it have more or less power? Just trying to understand what that big shiny can is for!
Thanks, Keith
Old Apr 26, 2008 | 04:10 AM
cmt52663's Avatar
cmt52663
try this?
http://auto.howstuffworks.com/muffler4.htm
Old Apr 26, 2008 | 06:22 AM
FLKeith's Avatar
FLKeith
Thanks. That article makes it sound as though the resonator is really there to reduce noise: "Some cars, especially luxury cars where quiet operation is a key feature, have another component in the exhaust that looks like a muffler, but is called a resonator".
That begs the question - if a cat-back is being added to maximize power - why have a resonator?
Old Apr 26, 2008 | 06:24 AM
ImolaS54's Avatar
ImolaS54
to reduce noise.
Old Apr 26, 2008 | 06:30 AM
cmt52663's Avatar
cmt52663
i've the Works stainless exhaust, circa 2004. Still looking pretty and working fine, but I've a bit of a rattle in the resonator at 2,800 rpm.
i intended to have Turners replace it with a straight pipe earlier this spring, but didn't - i'd still like to
i expect the result will not be significant for power, will be louder, will be a little lighter, and WON'T rattle...
has anyone done this? am i thinking straight here?
Old Apr 26, 2008 | 06:39 AM
AstroBlackS's Avatar
AstroBlackS
It's essentially just to reduce noise. Many people on here have had the resonators removed from their factory or aftermarket exhausts. It won't do much, if anything, for power, but it wil make it louder... which is always a plus!
Old Apr 26, 2008 | 07:20 AM
Oxybluecoop's Avatar
Oxybluecoop
I had my stock resonator and second cat replaced with 3" pipe.Deeper sound and about 20lbs less weight.
Old Apr 26, 2008 | 07:31 AM
Dr Obnxs's Avatar
Dr Obnxs
It can also supress drone...
so hack it out if you will, but be prepared for some unexpected consiquences.
Matt
Old Apr 26, 2008 | 04:49 PM
JCR1960's Avatar
JCR1960
Matt
I know this is off topic.
I knew your screen name looked familiar as I just read your article on page 22 in the March-April 2008 MC 2 Magazine.
Old Apr 26, 2008 | 07:44 PM
sailorliz23's Avatar
sailorliz23
just makes the mini a lot louder. i wouldnt say it drones though. i have a custom made cat back without a resonator and mine doesnt drone at all. we have another mini that has no 2nd cat and that one DRONES!!!!! but if you intend on keeping the alta cat back and just removing the resonator it shouldnt drone.
Old Apr 27, 2008 | 12:32 AM
ghosthound's Avatar
ghosthound
same here! lovin the custom magnaflow catback!
Old Apr 27, 2008 | 05:17 AM
cmt52663's Avatar
cmt52663
Matt
that sounds like good advice based on experience - could i get you to elaborate a bit? should i expect a drone at one particular rpm range, or will i have a "pipe organ" that will drone at varying speeds d'ya think?
you might be sparing me a real headache with this insight - i thank you
Old Apr 27, 2008 | 06:32 AM
Dr Obnxs's Avatar
Dr Obnxs
It really depends....
there is no one answer for all exhausts. Ressonator placement and design (along with the rest of the exhaust system) really determin how it sounds as a function of load and RPM. As many who have rolled thier own exhaust have found, it's not as easy as just getting some parts and welding them together.
So, sorry, I can't get specific cause there are too many cases. Just keep in mind that for some exhausts, just taking out the resonator makes things a bit louder (like the one ball) and some it really effs things up!
Matt
Old Apr 27, 2008 | 06:35 AM
cmt52663's Avatar
cmt52663
thanks Matt - i will approach with caution
knbond1
Sep 4, 2016 02:30 PM
vulkandino
Oct 31, 2015 08:29 PM
deputydog95
12
Sep 12, 2015 06:49 PM
rob&JCW
Sep 10, 2015 12:06 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
