Drivetrain Fuel Injector Question
Old Feb 8, 2008 | 10:41 AM
Mistir's Avatar
Mistir
How much would upgrading my fuel injectors really help? I'm planning on keeping the engine mods simple since I still use it as a daily driver, just want a bit more power. So intake, one ball mod, smaller pulley(haven't decided on size yet), colder plugs, spark plug wires, coil, fuel injectors, and finally a custom tune. The fuel injectors are looking a bit expensive right now, and just wanted some input. Thanks!
Old Feb 8, 2008 | 10:58 AM
JIMINNI's Avatar
JIMINNI
You might take a look at this thread: https://www.northamericanmotoring.co...d.php?t=128031
It talks about most of what your asking. Just read most of it, it gets into injectors and other stuff. Hope it helps .
Old Feb 8, 2008 | 01:39 PM
MINIMM's Avatar
MINIMM
With a good tune (Jan's) with a 15% pulley, intake and exhaust it helps the top end of the RPM range.
Not a big change, but it does help some.
Old Feb 8, 2008 | 04:16 PM
Larry Clemens's Avatar
Larry Clemens
I have a 2005 MCS w/ basic mods (15%, CAI, exhaust, JCW 380s) and still ran out of fuel above 6500 rpm w/ Jan's tune. IMO, 380 injectors are a must to maximize the benefits of the awesome RMW tune.
Old Feb 8, 2008 | 04:59 PM
jhiggs26's Avatar
jhiggs26
How lean were you running the last 500 rpm or so Larry?
Jeremy
Old Feb 9, 2008 | 07:00 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Damn lean after 6500 with 380's? What did you have on the car?
Old Feb 9, 2008 | 09:36 AM
Larry Clemens
Jeremy
High 12s
Old Feb 9, 2008 | 09:42 AM
jhiggs26's Avatar
jhiggs26
What A/F did you and Jan want to produce that high up? Did you upsize your injectors over the JCW then?
Jeremy
Old Feb 9, 2008 | 09:49 AM
Larry Clemens
Jeremy
I'll let Jan speak to this issue but I believe he wanted the A/F in the mid to high 11s. The A/F only went into the 12s at the very top (above 6500). I do 99% of my driving below 6,000 rpm and the TQ and HP curve were so good, we did not want to change anything. The car has never run better and I have thrown no lean codes. Check out how flat the TQ curve is. The car is an entirely different animal after Jan's tune. The green curves are a prior RMW tune, not baseline.
Another Great RMW Tune w/ Dyno Graph-rmw-tune.jpg
Old Feb 9, 2008 | 09:53 AM
Larry Clemens
2005 MCS w/ Alta CAI, 15% pulley, 62 mm TB (waste of $$), Milltek CB, and Viagra in the gas tank) Seriously, Jan mentioned that I had a very, very strong car. My peak WHP and TQ are 219.4 and 193.4 respectively and the area under the TQ curve is awesome.
Old Feb 9, 2008 | 10:03 AM
jhiggs26's Avatar
jhiggs26
Very impressive!
When would we throw a lean code that high in the rev band: 13, 14, 15, A/F ratios?
Now back to finishing my S-lite end tables..... .
Jeremy
Old Feb 9, 2008 | 06:17 PM
Mistir's Avatar
Mistir
Thanks JIMINNI for that link, and everyone else for the responses. It definitely sounds like injectors are a good idea since I want a custom tune. Would it still be worth getting the tune if it's not done by Jan? Who in the San Diego area can do it? I would even drive to LA if it's worth it.
Old Feb 9, 2008 | 09:33 PM
batrugger's Avatar
batrugger
Drive to LA, it's worth it.
Old Feb 10, 2008 | 11:38 AM
Mistir's Avatar
Mistir
Thanks, I never really looked up where he is. Didn't know he was in Irvine! Well, his business is anyway. So when I'm ready I just call him and setup a date and time? Also, it would still be about an hour and 10 minute drive, so would it be best to install the fuel injectors once I get there?
Old Feb 10, 2008 | 11:43 AM
lanevomr's Avatar
lanevomr
what size is our stock injector?
Old Feb 10, 2008 | 12:21 PM
HighLife4136's Avatar
HighLife4136
340cc
Old Feb 11, 2008 | 07:20 AM
JIMINNI's Avatar
JIMINNI
Best thing would be to call him. He may not have a extra mechanic there to install your injectors at that time. Here is his link:https://www.northamericanmotoring.co...lutionmini.com
Old Feb 11, 2008 | 08:14 AM
minimarks's Avatar
minimarks
Drove mine with the JCW injectors for a few days before getting the JCW flash and it ran just fine.
Old Feb 11, 2008 | 08:58 AM
littlehandegan
Shouldnt it run fine with 380's and a pulley until its tuned? Or is it dangerous?
Jack
Old Feb 11, 2008 | 09:02 AM
JIMINNI's Avatar
JIMINNI
Jack
I was told it is not dangerous, but I have a flat spot at 3000 rpm since I installed them. Can't wait to get my car into Jan's hands.
Old Feb 11, 2008 | 10:04 AM
littlehandegan
Yes me to. Going to get it re-tuned next month in Florida...Pulled 197 last month....
Jack
iggi
18
Feb 9, 2026 01:00 AM
bobbiemartin
Jan 20, 2016 05:28 PM
David.R53
Sep 1, 2015 06:49 PM
vanhick
Aug 19, 2015 09:03 AM
Getrieben
Aug 15, 2015 09:09 PM
