Drivetrain Radiator Reserve Tank - spilling its guts
Old Dec 29, 2007 | 07:59 AM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Well, my plastic radiator reserve tank has been spilling its guts for too long. Every day there's dried coolant around the outside of the tank and on occasion on the heat shield below. Tired of it.
I remember this being a problem with 2002-03 MCS in the past and maybe mine is just catching up now.
Sources for these tanks?
Aluminum tanks instead? I seem to remember someone selling one but can't find it.
Paul
Old Dec 29, 2007 | 08:09 AM
mr. jim's Avatar
mr. jim
Have you tried a new cap? Maybe more concerning is why is it boiling over?
naffets's Avatar
naffets
http://www.mossmini.com/Shop/ViewPro...21&SortOrder=1
pretty cheap imo.
Old Dec 29, 2007 | 09:00 AM
jimz68's Avatar
jimz68
Originally Posted by naffets
Hmmm.....That page says the tank is Not Available.
Here's the one I have:
http://www.forgemotorsport.com/conte...roduct=FMMINHT
Works great, looks cool!
Jim
Old Dec 29, 2007 | 09:17 AM
Ryephile's Avatar
Ryephile
Get a new coolant tank [comes with new cap], and most importantly, TIGHTEN THE CAP!
Old Dec 29, 2007 | 09:38 AM
cycleguru's Avatar
cycleguru
I have the Forge motorsports on my 2003. Had it waiting in my garage even before i recieved my car because of all the splitting issues on the OEM tanks. Check out my Gallery for pics of tank.
Old Dec 29, 2007 | 02:53 PM
scolburn79's Avatar
scolburn79
Forge Over flow tank and Power Steering Tank
I bout these 2 items about 3 weeks ago from www.minspeed.net . Check it out and they are a good price and add some look to your engine bay
Old Dec 29, 2007 | 03:08 PM
cycleguru's Avatar
cycleguru
Peter at Minspeed ROCKS. Your gonna love both tanks. They are both made very well.
Old Dec 29, 2007 | 04:17 PM
MINIdave's Avatar
MINIdave
My '03 was well out of warranty when the tank started leaking, but MINI took care of it No charge. I understand the new ones are supposed to be made better
Old Dec 29, 2007 | 04:22 PM
cycleguru's Avatar
cycleguru
Yep, They fixed the problem. Your new OEM tank should be fine.
Old Dec 29, 2007 | 04:26 PM
COR BLMY's Avatar
COR BLMY
I have had the CANTON alum tank for over 2 years.
Avaliable from LIVERMORE PERFORMANCE
Great price and don't forget the cap
Mini > Engine > Coolant Tanks
MODEL SPECIFIC COOLANT EXPANSION AND RECOVERY TANKS
Canton model specific coolant expansion and recovery tanks are designed to fit in the same location as the stock tank. Built out of .100" aluminum, these tanks provide a stronger more reliable and better looking replacement for the stock plastic tanks.MINI COOPER COOLANT EXPANSION TANK
#80-272 '02-up Mini Cooper & Cooper S coolant expansion / fill tank. Features billet radiator style neck, which accepts Canton part #81-030 pressure cap or any standard 30 psi radiator style cap..EXPANSION TANK PRESSURE CAPS
These pressure caps are for use with our aluminum expansion tanks or any other application that requires a high pressure radiator style cap. Two different pressure settings are available.#81-030 30 psi. Radiator Style Cap.Canton - MiniYearsDescriptionP/NPriceMini Cooper/Cooper S02 +Coolant / Expansion Tank80-272$108Mini Cooper/Cooper S02 +Expansion Tank Pressure Caps, 30 PSI81-030$25
Old Dec 29, 2007 | 06:28 PM
pberry51mini
No Fear Gear
Not a boiling over situation, more of a slow leak, seeping.
Old Dec 29, 2007 | 06:47 PM
pberry51mini
No Fear Gear
Went there, bought it, everything should be allright soon. Thanks.
Paul
Old Jan 2, 2008 | 07:29 AM
turboaz2's Avatar
turboaz2
The Canton tank is a nice piece.
I've got one on mine.
http://www.ampperformance.com/xcart/...roductid=12292
http://www.cantonracingproducts.com/...ion_tanks.html
At the bottom.
Old Jan 2, 2008 | 05:26 PM
pberry51mini
No Fear Gear
At the bottom.
Ease of installation?
Old Jan 2, 2008 | 06:36 PM
COR BLMY's Avatar
COR BLMY
1 bolt , 2 clamps
I have seen some bracket differences in different ones that I have installed.
An easy bend or just a washer size spacer was needed to keep the tank away from a potentoal rub issue.
Old Jan 2, 2008 | 07:47 PM
turboaz2's Avatar
turboaz2
The Canton Piece works great, and allows you to use a commonly available cap.
Old Jan 2, 2008 | 10:20 PM
COR BLMY's Avatar
COR BLMY
Please be careful this is NOT a standard cap !!!
(as far as pressure rate goes)
It should be 26 to 30 LBS
Usually only avaliable fron "speed" and HP auto shops
Old Jan 2, 2008 | 10:24 PM
pberry51mini
No Fear Gear
A Stant from Pep Boys with the same pressure rating won't work?
Old Jan 2, 2008 | 10:26 PM
COR BLMY's Avatar
COR BLMY
Yes it will work ...
I just wanted to be sure folks understood that this is not a STD 14 lb cap.
Old Jan 2, 2008 | 10:28 PM
pberry51mini
No Fear Gear
OK, cool.
Old Jan 2, 2008 | 10:36 PM
pberry51mini
No Fear Gear
Stant cap won't fit MINSPEED tank, only a stock cap.
Does anyone make a stock-style cap that's beefier like this new aluminum tank I'm installing?
Thanks,
Paul
Old Jan 3, 2008 | 12:15 PM
turboaz2's Avatar
turboaz2
http://www.partsamerica.com/productd...rtNumber=10393
Stant part number 10393 or 10373
These are for the Canton tank.
OutMotoring
Mar 3, 2017 06:29 AM
JAB 67
Sep 29, 2015 01:34 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
silence2-38554
Sep 28, 2015 12:19 PM
rt808
Sep 25, 2015 01:59 PM
