Drivetrain 450cc injectors
it's a valid question. From talking to many tuners there seems to be an agreement. Quantity vs. Quality of spray.
Basically quantity is typically needed over stock to run a raised rev limit. However, if you have to give up spray pattern and spray quality to get it you're going to negate all the gains you would have gotten from the larger injectors. That's why you see rmw sourcing his own upsized injectors for his head or using jcw injectors for cars which are running the jcw or stock head.
also.....keep in mind, before you re-use an injector you should get the service RC offers to clean and calibrate them. Spending that $100 can save you 50x that down the road when it comes time to tuning. It's not unheard of for the injectors to be unmatched.....one producing less pressure/flow. Heck, we've seen it on Perrin injectors for the Subaru's a bunch...brand new. Usually, it's not their fault, but a bad injector from the start (since most are drilling out OEM for better flow)
IQRaceworks
51
10-10-2015 03:54 PM
dutchhome
09-30-2015 07:17 AM
