Drivetrain OCC, The correct install?
Old Nov 5, 2007 | 08:51 AM
MiniS AZ's Avatar
MiniS AZ
I know there are some long threads out there talking OCC. But there are two stickys on how to install. My head was spinning trying to decipher. I am a not a techie so be gentle...Which is the better/correct way to install?
(1) this one:
https://www.northamericanmotoring.co...ad.php?t=88605
(2) or in the easier install:
https://www.northamericanmotoring.co...ad.php?t=75360
Old Nov 5, 2007 | 12:39 PM
MiNi_MaC's Avatar
MiNi_MaC
Ok, from what ive read the first is the mfg's way to do.. the second one, is what most namers have.
Old Nov 6, 2007 | 05:37 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
This has always been the correct installation:
Old Nov 6, 2007 | 10:01 AM
MiniS AZ's Avatar
MiniS AZ
ah cool. the only thing i dont have is the optional attachment. Is there a big difference that additional makes??
Thanks!!
Old Nov 6, 2007 | 10:06 AM
UKSUV's Avatar
UKSUV
Which OCC did you finally go with?
Old Nov 6, 2007 | 01:13 PM
MiniS AZ's Avatar
MiniS AZ
ebay baby!! ebay!
http://cgi.ebay.com/ebaymotors/ws/eB...177966178&rd=1
Old Nov 6, 2007 | 01:39 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Inline with the PCV valve as shown in the above hi-res sketch is the proper way. Some methods have you blocking off the PCV system and routing both the PCV and breather ports on the engine to the breather inlet before the throttle body. Doing this defeats the positive crankcase ventilation and can often cause problems with sludge buildup down the road. Since the main source for the oily mist is via the PCV valve port, that's the position for the OCC. If oil shows up at the breather port, either the PCV system is non functional for some reason, or the engine has excessive blow-by due to piston ring failure (or maybe worse).
Old Nov 6, 2007 | 02:51 PM
UKSUV's Avatar
UKSUV
Originally Posted by MiniS AZ
Good man...we will see how it holds up!
Old Nov 6, 2007 | 05:55 PM
ScottinBend's Avatar
ScottinBend
I went with the 2 OCC. I had the Alta first and then added the eBay one for the PVC side.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Minibeagle
Aug 13, 2015 10:00 AM
