Drivetrain Official ALTA™ Q&A thread PART TWO 2nd Generation MINI
Old Oct 30, 2007 | 08:18 PM
  #401
chili_red07's Avatar
chili_red07
Not in the immediate future, but at some point. No offense to ALTA but I would feel more comfortable once its been out and people have it on their MINIs.
Old Oct 30, 2007 | 08:20 PM
  #402
Msteadman's Avatar
Msteadman
Agree completely with you on that. Thankfully (in a sense) it's not yet out for us MCSa drivers anyway, so I have no choice but to exercise patience.
Old Oct 30, 2007 | 08:40 PM
  #403
scott48's Avatar
scott48
I'm sure you'll be answering this with install stuff in the coming days, but here goes: what part of the unichip setup stays in the car?....the actual little unichip computer box, the wiring, both?
Old Oct 31, 2007 | 07:09 AM
  #404
ALTAPerformance's Avatar
ALTAPerformance
The whole kit and caboodle stays in the car all the time. (Well anytime you want additional HP!) Since it intercepts the signals and outputs modded ones, it has to be in the car at all times. Good question! Thanks for asking!
Old Oct 31, 2007 | 09:46 AM
  #405
byhsu's Avatar
byhsu
ALTA:
Forgot to ask if the ECU takes out the limiter and if you have tested your car's top speed? Just curious, I don't really go over 90mph now. Maybe that will change with the MINI.
Old Oct 31, 2007 | 12:48 PM
  #406
DarthJader's Avatar
DarthJader
ALTA guys,
Question regarding ECU PnP:
I am getting my new MCS with a JCW tuning kit. How does your unit work in conjunction with the reprogrammed ECU?
Also, if I were to install a FMIC with the JCW kit, what sort of gains would I get without another ECU reprogram?
Thanks in advance
Old Oct 31, 2007 | 12:57 PM
  #407
chili_red07
^ Why go JCW if you want an ECU anyways... Its probably cheaper to do an aftermarket intake/ cat-back/ Alta ECU. My $0.02.
Old Oct 31, 2007 | 12:59 PM
  #408
DarthJader's Avatar
DarthJader
Well, I appreciate your 2 cents, but it really doesn't help me at all. Thanks.
DJ
Old Oct 31, 2007 | 01:12 PM
  #409
chili_red07
Your welcome (I hope you didn't take offense, as that wasn't my intention)
Good luck
Old Oct 31, 2007 | 01:16 PM
  #410
ALTAPerformance
Agreed that the ALTA combo with (or even without) the ECU makes more power than the JCW for less money (not a poke at JCW guys member I have a GP myself!) but it is a better value per HP.
Now back to Darth's concern. Until I have a R56 JCW car on my dyno and test it, I can NOt say if it works properly with the existing mapping. What I can say is it SHOULD work, but we will need to change the values/mapping for the best result as well as maintain durability.
So more info coming. I have ONE local client that I need to try to get in here to work with on both subjects!
Thank you!
Old Oct 31, 2007 | 03:17 PM
  #411
rattmobbins's Avatar
rattmobbins
100% agree with that.
DJ
Nice 'tude man.
Old Oct 31, 2007 | 03:34 PM
  #412
chili_red07
Originally Posted by rattmobbins
Nice 'tude man.
Ok... so that wasn't just me
I'm not gonna loose sleep over it
AND now back to ALTA Q&A (my apologies for thread-hijacking)
Old Oct 31, 2007 | 03:55 PM
  #413
rockridge's Avatar
rockridge
Question for the Alta folks, How can I determine if the turbo-back system is legal in my state? (Mass)
Old Oct 31, 2007 | 04:47 PM
  #414
DarthJader's Avatar
DarthJader
Thanks for the response, Alta.
DJ
Old Oct 31, 2007 | 04:54 PM
  #415
DarthJader's Avatar
DarthJader
chili, ratt
I'm sure you are good people, but I don't even know why you guys are involved. I didn't ask for a JCW vs ALTA comparison. I asked a reasonable question directed specifically to an Alta rep. So your response to my initial question was pointless and a waste of the 20 seconds it took for you to write and me to read.
And if you thought I took offense to your response, I wasn't offended until ratt didn't like my attitude. Though like you I will not lose any sleep over it.
Cheers!
DJ
Old Oct 31, 2007 | 05:48 PM
  #416
r56mini's Avatar
r56mini
Alta mods will kick JCW kit's butt for sure. But will Alta+JCW kick Alta's butt?
Old Oct 31, 2007 | 07:44 PM
  #417
KNTRKTOR's Avatar
KNTRKTOR
Hey Adam/Jeff, How about some pics of the ECU Kit and caboodle in place inside the car.
Old Nov 1, 2007 | 07:09 AM
  #418
rattmobbins
chili, ratt
Cheers!
DJ
Wow, you're bound to fit right in here on NAM. Welcome!
Old Nov 1, 2007 | 07:12 AM
  #419
rattmobbins
You mean will the JCW intake and exhaust + Alta ECU beat all Alta parts? Or do you mean will the Alta intake and exhaust + JCW ECU beat all Alta parts? Either way I say all Alta wins hands down, regardless of the Alta + JCW combo you choose.
Old Nov 1, 2007 | 07:24 AM
  #420
jascooper's Avatar
jascooper
If I had two cents for every time someone posted their two cents, I'd be ahead of Gates and Buffet on Forbe's list.
Old Nov 1, 2007 | 07:45 AM
  #421
chili_red07
I think we all would
Old Nov 1, 2007 | 07:53 AM
  #422
ALTAPerformance
This is a good question. Does your state require aftermarket components to meet CARB standards? If not then yes it should be legal in that state. If it requires CARB then no dice! Hope that helps! Thanks for asking! Adam@altaminiperformance.com
Old Nov 1, 2007 | 09:10 AM
  #423
byhsu's Avatar
byhsu
How do you find out if your state needs CARB certification? I am in California. I think you mentioned that your Cat-Back is legal in CA but not your Down Pipe. Is that still the case?
Old Nov 1, 2007 | 09:20 AM
  #424
ALTAPerformance
California requires (as well as started) CARB (California Air Resources Board) The cat-back sit outside of their restrictions (ends at rear most catalyst). The Downpipe would have to be CARB approved to be legal in CA.
Sorry for the confusion!
Old Nov 1, 2007 | 09:22 AM
  #425
r56mini's Avatar
r56mini
Naaaaah, I just wanted to say butt a couple of times.
