Drivetrain Official ALTA™ Q&A thread PART TWO 2nd Generation MINI
Old Oct 11, 2007 | 07:59 PM
  #276
Msteadman's Avatar
Msteadman
Originally Posted by scott48
have you guys seen the "stage 2" kit that Mini Mania is now selling...comes with air filter, exhaust, uni chip ecu.....they claim 30% increase in hp and torque; but not much other info.
Hmmmm, I can only find the 'stage 1' kit which comes with air filter + exhaust = 15hp.
Old Oct 11, 2007 | 08:13 PM
  #277
scott48's Avatar
scott48
the "stage 2" is on there when you click on 2007 parts....under the oil filter kit, in the 2nd row.....Alta stuff is/will be waaay better anyway.
Old Oct 11, 2007 | 08:23 PM
  #278
Msteadman's Avatar
Msteadman
Okay thanks, found it. No doubt at all that ALTA is better; just can't help checking out the competition.
Old Oct 11, 2007 | 08:27 PM
  #279
byhsu's Avatar
byhsu
Now we know the Mini Mania increases 30% HP and Torque with an ECU, Air Intake and Exhaust. and just the Intake and Exhaust is 15HP. I would like to know how much ALTA gets with just the Intake and Turbo Back Exhaust.
Old Oct 11, 2007 | 09:21 PM
  #280
scott48's Avatar
scott48
Alta has those results in their "Alta test and tune" thread in this section....hard to believe the 30% gains without really any description or dyno charts, or anything...either the gains aren't true, or it shows how much the ecu tune is worth....I know once Alta releases their ecu tune, it's gonna put out some pretty serious power; I bet highest hp with stock turbo.
Old Oct 11, 2007 | 09:24 PM
  #281
jascooper's Avatar
jascooper
Almost as hard to believe as installing a swaybar in 10 minutes.
Old Oct 11, 2007 | 09:30 PM
  #282
scott48's Avatar
scott48
....I didn't count taking back wheels off and putting car up on lift, which is only a few minutes anyway.....so my car on the lift as I was doing all the suspension, and yes it took like 10min to swap rear sway bars...why should it take long...just lowered the subframe enough to clear the sway bars' diameter and then put the new one in....the rear bar is straight, so you don't have to do a bunch of twisting to get it out....attach sway bar to subframe, and then reattach upper sway bar endlink bolt...done.
Old Oct 12, 2007 | 06:58 AM
  #283
ALTAPerformance's Avatar
ALTAPerformance
Good Question:
Originally Posted by old81
Adam,
Yes the water temp and oil pressure combo is high on my list since I'm so old school.
How will 4 gauges work with the pod setup, this I have to see in your setup?
Lots of pictures, please. Thanks.
I plan on putting the Water Temp and Boost up by the tach, and then oil temp and EGT under the switch panel. (The later is NOT using our new pods.) But I may change it up. I have been a bit under the weather the past day or so, so I got the sensors all mounted, but need to complete the wiring to then light things up and show the clients how this will all work. Thanks for your patience!
adam@altaminiperformance.com
Old Oct 15, 2007 | 09:25 PM
  #284
scott48's Avatar
scott48
Patiently waiting for boost gauge.
Old Oct 16, 2007 | 06:44 AM
  #285
ALTAPerformance
So close!
I completed the installation last night. Trying to edit photos etc to use for instructions, as well as verify wiring connections. Sorry as always for the delay!
Adam@altaminiperformance.com
Old Oct 16, 2007 | 09:35 PM
  #286
scott48's Avatar
scott48
Is getting the Alta BOV to replace the oem BOV a necessary thing to do or recommended, that I do that with my current mods and once I get the upcoming ecu tune?
Old Oct 17, 2007 | 06:46 AM
  #287
Candyman's Avatar
Candyman
Wait until you see how much it fluctuates
Old Oct 17, 2007 | 06:54 AM
  #288
ALTAPerformance
It will become FAR more important once the boost level is raised and maintained as the OEM unit will only vent a fixed amount of pressure and air.
Thanks for asking!
Old Oct 17, 2007 | 07:57 AM
  #289
scott48's Avatar
scott48
Thanks for asking!
So it's not necessary, but recommended?
Old Oct 17, 2007 | 08:07 AM
  #290
ALTAPerformance
True! ALL ALTA Products are recommended!-)
Old Oct 17, 2007 | 09:24 AM
  #291
scott48's Avatar
scott48
what would the advantages be?
Old Oct 17, 2007 | 09:36 AM
  #292
a96bimmerm3's Avatar
a96bimmerm3
coming from the vw fsi world the diverter valves sometimes crap out at high boost. When the boost starts upping we'll see if they leak. If so a block off plate and bov will do the trick.
Old Oct 17, 2007 | 03:33 PM
  #293
ALTAPerformance
scott48: It comes down to volume of air expelled, not volume in terms of sound. The OEM valve is only designed to vent up to x amount. We are now putting y amount through the motor and valve. As such it isn't able to remove the amount of air needed. Also, the ECU uses the valve to regulate boost. When we remove that ability, we need to have another valve elsewhere.
Hope that helps?!
Old Oct 17, 2007 | 05:04 PM
  #294
scott48's Avatar
scott48
That all makes sense, but so when I get the ecu tune, will I need to get the Alta BOV, or can the new ecu tune work with the oem BOV?
Old Oct 17, 2007 | 09:45 PM
  #295
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Both!
Old Oct 17, 2007 | 10:00 PM
  #296
scott48's Avatar
scott48
Originally Posted by ADAMSALTAMINI
Both!
Ok, that's cool that you guys made the ecu tune to work with either the oem BOV or the upgraded BOV, so it leaves us with some options
Old Oct 18, 2007 | 11:39 AM
  #297
jascooper's Avatar
jascooper
Was looking at my engine and noticed that the intake tube (?) doesn't look fully seated. Does this look right to you? Lip showing at center of photo. Since Alta makes replacements, thought this would be the thread to ask.
Thanks,
Old Oct 18, 2007 | 11:56 AM
  #298
MotorMouth's Avatar
MotorMouth
pics don't show...
Old Oct 18, 2007 | 12:08 PM
  #299
jascooper's Avatar
jascooper
Does this work?
http://picasaweb.google.com/jasel52/...46751537190034
Old Oct 18, 2007 | 01:05 PM
  #300
MotorMouth's Avatar
MotorMouth
yep, can see the pic when I click the link. I was going to host and post it for you but it is over 2meg in size.
Gimme a couple minutes and I'll resize and post it.
edit: yours is NOT seated fully although it may not be leaking.
back to your regularly scheduled thread...
