Drivetrain New boost gauge
Old Jul 9, 2007 | 06:27 PM
RIPPER's Avatar
RIPPER
New boost gauge
I just installed my boost gauge tonight and went out for a short ride to see how it works.
Heres what I saw while driving.
at idle 15-20 vac
wot max 14lbs boost
on the gas and shifting through the gears 10-11lbs boost.
does this sound about right? hopefully Sid or longbord will reply as they have the same head and header.
going to the dyno tomarrow at 10am to see what Ripper is putting down
Old Jul 9, 2007 | 07:09 PM
ED955S's Avatar
ED955S
go to electrical section of the forum. I posted "Boost Expectations" and few members have numbers. I have not installed mine yet and in process of fabricating an aluminum extention to be attached to the back of the tack. I will post mine soon.
Old Jul 9, 2007 | 07:15 PM
OctaneGuy's Avatar
OctaneGuy
That sounds right. It's what I get as well. However I'm on OEM head and header. After I did the Detroit Tuned BPV I was seeing as high as 19PSI boost at times which was kind of wild.
at idle 15-20 vac
wot max 14lbs boost
Old Jul 9, 2007 | 07:21 PM
kyriian's Avatar
kyriian
mine's in different specs... but it sounds correct... im seeing about 0.8-0.9bar vaccum when the throttle is off... at WOT it goes to about 1.2 bar (about 16 psi)
its worth to note i got a 15% + 2% crank
Old Jul 9, 2007 | 07:30 PM
OctaneGuy's Avatar
OctaneGuy
oops, yeah I've got a 16% M7 Pulley and Alta Intake.
Old Jul 9, 2007 | 07:39 PM
Longboard Mini's Avatar
Longboard Mini
at idle 15-20 vac
wot max 14lbs boost
When I first got the RMW head I didn't have a gauge. Now that the Rotrex is on the car I added a Craven Speed flex pod with an Auto Meter boost gauge on one side and an Ipod on the other.
At Idle I see the same as you. At WOT I see 18lb's and an incredible sucking sound coming from the intake .
From what I have seen your's sounds about right for a 15% pulley (14-15).
Longboard
Old Jul 9, 2007 | 11:09 PM
batrugger's Avatar
batrugger
With the RMW head you will actually see a little less boost, not much, but a litttle. After ours was installed it was reading about 3-4 less than before
Old Jul 10, 2007 | 01:15 AM
Paul Webster's Avatar
Paul Webster
What build date is your car Ripper?? good luck on the dyno today.
I think the Mini community has converted me to a dyno racer as I feel like I've been cold turking the last few days without any dyno sheets to look at.
Old Jul 10, 2007 | 07:57 PM
herbie hind's Avatar
herbie hind
i got 15 lbs. vac tonight with a simple hand held . but it's cool you posted cause now i know i'm good .
Old Jul 11, 2007 | 08:05 PM
MidnightDave's Avatar
MidnightDave
I had Dan at GrassRoots put mine in the air vent, originally stock and now with just a CAI, I still only get 11lbs on full boost, that's just dropping off a rev at a stop light in the pic. The pulley must really crank it up!
Old Jul 13, 2007 | 07:21 AM
cooperdanR53's Avatar
cooperdanR53
sorry for the slightly off topic question. But i was going to install my boost guage, and was looking for the correct location for the censor
Old Jul 13, 2007 | 07:24 AM
Loony2N's Avatar
Loony2N
It's not THAT racey. I think you mean "sensor" but I have no idea where to put it.
Old Jul 13, 2007 | 07:32 AM
cooperdanR53
Ah sensor, sorry for the grammatical mistake.
Old Jul 13, 2007 | 02:11 PM
RIPPER's Avatar
RIPPER
my boost gauge didn't have a senser. mine is a mechanical one though
Doc Pain
Oct 28, 2015 07:09 PM
Oct 1, 2015 12:13 PM
papawhiskey
Sep 30, 2015 02:50 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
