Driver's School Discuss tips, techniques, and schools for enhancing the driver portion of the performance driving equation.
SCDA HPDE Schedule
Old Oct 3, 2011 | 06:00 PM
  #876
Eddie07S's Avatar
Eddie07S
Originally Posted by veggivet
Watkins Glen recap. This event was run by NASA/PDA. The weather was the major issue. Fortunately, Friday held out with just cloudy conditions/dry track with temps in the upper 50's, so the R-comps warmed up nicely. Tons of track time that day, starting off with an hour session, followed by two 45 minute sessions, and then a 30 minute session to wind up. The car was handling beautifully, and I was playing with a couple of Porsches and Miatas. Couldn't quite keep up with the Ferrari Scuderia 430...Then my car lost power along the back straight, the service engine light came on along with the yellow triangle in the speedo. The car felt like someone put a giant rubber band around it. I limped back into the pits, cut the engine and popped the hood to see if I lost a belt or something else that would be obvious to me. Everything looked/smelled normal, so I restarted and the car felt back to normal. Went out again and took it relatively easy for the rest of the session. During lunch break I had the code read out: 304, which is a misfire in cylinder #4. So I pulled the spark plug from 4, and also from 1 just for comparison. The #4 plug had some carbon buildup on the tip that the #1 plug didn't have, so I bought a new plug and installed it. Same thing happened during the afternoon session, so I concluded it wasn't the plug that was at fault. Car was fine after restarting the engine, so I finished the day driving 6/10. Saturday was a complete waste, with a long fog delay in the morning, and steady rain throughout the day. Only got out twice, and one of those sessions was under yellow the entire time. Sunday started off wet and cool, but by the afternoon, things were drying up nicely, so the R-comps went back on for the last two sessions. No codes thrown at all, but I wasn't pushing the car that much, trying to keep it under 100 on the back straight. My plan is to have the compression checked, and maybe switch wires 3 and 4 and see what codes it throws at Lime Rock. After that, I'll have all winter to figure it out. Other than the crappy weather and the misfires, I had a decent time, but there were no other MINI's there to keep me company. Any other customers for Lime Rock on the 29th?
Lime Rock...Nah...I'll give it some time for that special dent in the guard rail to rust into obscurity....
New car soon. Already have snow tires for it...the "new performance" tire for minis
Glad to hear your car was handling well, would have like to have seen it running in the crowd. Sorry to hear about the engine.
As for that...my suggestion is to buy a new set of wires and plugs for the whole engine. You were driving in a high humidity day and sometimes the wires can fail under those conditions. The humidity makes it easier for a weak wire to fail and once it does, the only thing you can do is replace it. Get some silicon dielectric to put in the boots at both ends. That will cut out any arc trails that may be left behind. It is a cheap and easy fix; try it for LRP and enjoy. Switching wires may just leave you fustrated.
Old Oct 3, 2011 | 06:12 PM
  #877
veggivet's Avatar
veggivet
Plugs have less than 2k on them. Wires were replaced last year. I'm thinking it may be the coil. Sorry I don't have any video, but maybe someone else in my run group will post up on youtube. Did Lime Rock make you pay for repairs to the guardrail?
Old Oct 3, 2011 | 06:34 PM
  #878
Eddie07S's Avatar
Eddie07S
Not that I have heard. The Ins Co. did write them but I guess I will never hear whether they did or not. My guess is "not". The guard rail in that area is backed by dirt and it didn't look damaged but maybe I am not remembering too well.
So replace the coil and put some dielectic on the wire boots. Moisture can cause problems even with new stuff. The dielectic can help. You can get it at any NAPA store or your mechanic.
Old Oct 3, 2011 | 07:30 PM
  #879
slinger688's Avatar
slinger688
VV, sorry to hear about your car troubles. Mine is still in the shop getting repaired.
I am done for the year since I will be traveling until next year.
Old Oct 4, 2011 | 06:48 AM
  #880
S-Driver's Avatar
S-Driver
My neighbor will be running at LRP on the 29th.
As for me - my studs should be replaced tomorrow and if so ill be running the PDA event at T- bolt that day.
Did not notice any new guardrail at lrp last weekend at "the" spot...
Old Oct 4, 2011 | 08:49 AM
  #881
gkp's Avatar
gkp
Wha' happened Slinger?
Old Oct 4, 2011 | 09:06 AM
  #882
gkp's Avatar
gkp
Watkins Glen recap. This event was run by NASA/PDA. After that, I'll have all winter to figure it out. Other than the crappy weather and the misfires, I had a decent time, but there were no other MINI's there to keep me company. Any other customers for Lime Rock on the 29th?
VV:
Also try cleaning the MAF, if you haven't already. I had all sorts of weird codes and engine cut-outs this year. (Remember when you were all laughing about my AccessPort??) The MAF cleaning helped. Also, I had two ignition coils go at less than 40k miles. Now it's running great again, with or without the AP.
I was at LRP a few weeks ago (9/20) and that was my last day for this year.
Old Oct 4, 2011 | 12:51 PM
  #883
S-Driver's Avatar
S-Driver
His car has a boo boo is what happened...
Old Oct 4, 2011 | 02:05 PM
  #884
gkp's Avatar
gkp
Oh, Slinger, Slinger, Slinger. I am sorry to hear that. Did it happen at the track?
Old Oct 4, 2011 | 04:52 PM
  #885
S-Driver's Avatar
S-Driver
Not my story to tell tho...
Old Oct 4, 2011 | 06:07 PM
  #886
gkp's Avatar
gkp
GKP to Slinger. GKP to Slinger. Do you read?
Old Oct 4, 2011 | 06:59 PM
  #887
Eddie07S's Avatar
Eddie07S
Old Oct 5, 2011 | 05:08 AM
  #888
gkp's Avatar
gkp
Eddie07S:
RIP on the 07? What happened? And will you be changing your handle to Eddie12S???
Old Oct 5, 2011 | 03:51 PM
  #889
S-Driver's Avatar
S-Driver
Studs replaced! I'm signed up for NJMP on the 29th.
Old Oct 5, 2011 | 07:07 PM
  #890
Eddie07S's Avatar
Eddie07S
Eddie07S:
Just before the uphill at LRP, in that slight left hand bend of No Name Straight - Was on the outside after a pass, redline in 3rd, a 2 wheel drift off course, a sideways slide back on, and a "soft" front end kiss of the guardrail on the otherside. A disappointing end to the day and the car The instructor claims he didn't know what happened . No one was hurt, just brused. Minis are built like a brick s**thouse which is why I am getting another one
No Eddie has passed...new name coming. And as to the next question...Maybe. I have the winter to think about it.
I am hearing, though, this sort of thing goes on your permanent record and "they" won't ever let you out of the intermediate group or go solo
PS - Slinger's boo boo was the next day
Old Oct 6, 2011 | 05:06 AM
  #891
gkp's Avatar
gkp
Your right wheels went off, correct? I know the spot and, depending on the line taken by the car you're passing, I can see how that could happen. Sorry to hear.
Old Oct 6, 2011 | 06:55 PM
  #892
Eddie07S's Avatar
Eddie07S
Yup, right wheels off...can't say how far I was beyond the car I passed, but for some reason I felt I needed to stay right.
Old Oct 17, 2011 | 07:12 PM
  #893
Eddie07S's Avatar
Eddie07S
Got my new Mini on Thursday. I now have about 400 miles on it
It is everything my '07 was plus more.
More power
Better Sport button response, Pop and burble in sport mode
Better suspension (sport suspension option...liking it)
Better radio
Better seats (well not better than the Recaros but better than the stock sport seats).
And that great new car smell
Did I mention - More Power The seat of the pants feel is that it has more than the 10 hp increase they quote. This thing is going to eat tires for breakfast
The High Class Gray has a "Purple Haze" (maybe I should have named it "Jimmy" )to it and it is proving difficult to match a stripe to it, but I am working on it. Pictures to come.
"Smokey" is going to get around, so most will get a chance to see him.
Hope the end of your season goes really well.
Old Oct 18, 2011 | 03:14 AM
  #894
veggivet's Avatar
veggivet
Congrats on the new ride! Waiting for pix...
Old Oct 18, 2011 | 04:45 AM
  #895
gkp's Avatar
gkp
Congrats!
Old Oct 24, 2011 | 07:12 PM
  #896
Eddie07S's Avatar
Eddie07S
New Car
Well here are a couple of pictures of the outside of the car. So far I have kept on the road. Now have about 900 miles on it.
Attached Thumbnails SCDA HPDE Schedule-smokey_2.jpg   SCDA HPDE Schedule-smokey_1.jpg
Old Oct 25, 2011 | 05:22 AM
  #897
gkp's Avatar
gkp
Nice! Good luck with it.
Old Oct 31, 2011 | 06:21 PM
  #898
Eddie07S's Avatar
Eddie07S
Anyone make it to track days last Month (October)?
VV - thought you were going to LRP? Did it get snowed out? Looked like it might have.
OC - Did you make it to Roebling Road?
Say if anyone is planning for next year, BMW will be at WGI on 6/11 & 12
Old Oct 31, 2011 | 06:28 PM
  #899
veggivet's Avatar
veggivet
LRP got rescheduled for Monday, November 14th. Brrrr. Looks like I'm done for the season.
Old Oct 31, 2011 | 06:33 PM
  #900
orangecrush's Avatar
orangecrush
Coming up this weekend. One of my employees has been with me for 13 years and I told him as a 10 year anniversary gift, I’d pay his way for his first time to the track.
Apparently I forgot I’d had told him I’d help get his car ready... so far, I’ve bought a harddog roll bar, control arms, steering wheel and rear brake calipers.
Think it would have been cheaper to keep my mouth shut.
Anyway, leaving this Friday.
Mark
