Cooper (non S) Modifications specific to the MINI Cooper (R56).
SprintBooster / CEL / OBDII
Old Nov 2, 2015 | 08:25 AM
mikbau's Avatar
mikbau
Hello all
I received my SprintBooster from Way earlier this week (and I've also sent him a note, but I know he is out this week) - I am having a similar issue to the post here: https://www.northamericanmotoring.co...ch-assist.html
1) I left my door open for about 10 mins
2) Installed the SprintBooster
3) Upon start, I get the check engine light and the indicator my cruise control is having an issue
4) If I turn off/turn on, I still get the CEL, but it drives fine.
I have an Innova 3100e, and I was able to pull the codes P11CE and P11EE - however, it will not let me erase them.
Anyone have any thoughts? I've thought about heading to Autozone to see if their tool can at least clear the codes, but I"m wondering if something is up with the SprintBoost unit.
Thanks!
~m
Old Nov 2, 2015 | 12:05 PM
mikbau's Avatar
mikbau
Update:
Unhooked the battery for about an hour to see if the codes would reset - they did not - same codes for first on/off and subsequent on/off above
I may remove and see if the codes clear - Way is going to check with the SB folks...I'm wondering if I have a bad unit
Old Nov 2, 2015 | 04:31 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Double check that you have the right model for your car. That's all I got. Good luck.
Old Nov 2, 2015 | 04:32 PM
mikbau's Avatar
mikbau
Thanks...from what I've seen online, it looks to be the correct one - I'm having the folks at Way Motor Works verify...removing it appears to have solved the CEL....
~m
Old Nov 30, 2016 | 08:13 PM
Scott Delaney's Avatar
Scott Delaney
I know for sure that autozone will not clear any codes for you.
Old Dec 9, 2016 | 01:03 PM
Phocine's Avatar
Phocine
I got mine from Way pretty much the day he got them in and he mentioned it might throw a CEL upon installation, he said to just turn the car off and on again a couple times. Sure enough after I installed I got a CEL and turned my car on and off a few times and it cleared itself, I've had it for a couple weeks now and haven't had a single code since the day I installed.
Old Dec 9, 2016 | 03:51 PM
Mini Mania's Avatar
Sprint Booster
Glad to hear the problem cleared up. BTW, is yours version 2 or 3?
https://www.sprintboostersales.com/H...rks.cfm#V2vsV3
Old Jan 5, 2017 | 04:50 PM
Scott Delaney
Sprint booster vs Remus Responder
Mini mania...can you give me the ups and downs of each of these. I am trying to decide which one to get.
Old Jan 8, 2017 | 10:37 PM
Mini Mania's Avatar
Sprint Booster
Not aware of any downside to the Sprint Booser. V3 has a great many more programmable functions whether you are in sport or race mode. There are 9 adjustments for each which adjusts throttle response from 3 to 6% each step.
Here's a good video:
http://new.minimania.com/What-is-Sprint-Booster
This page describes the additional features of Version 3:
http://new.minimania.com/part/SPRMI0...55-F56-F54-F57
30-Day money back guarantee. Any other questions, please ask!
Old Jan 19, 2017 | 07:44 PM
Scott Delaney
Same problem
I am having the exact same issue. I have turned the car off and on again multiple times. It gets rid of the code but, as soon as the car sits for a while I get the engine malfunction message and car goes into limp mode. Any suggestions?
Old Jan 20, 2017 | 01:09 PM
Phocine's Avatar
Phocine
Before you installed did you open your door and let your car sit for 10+ minutes to let the computer shut off? Or is the connector from the sprint booster flipped around?
Old Jan 20, 2017 | 03:28 PM
Scott Delaney
Tried again
I installed again today only this time I opened the door for at least 30 minutes and took the key well over 100ft away from car and put in a lockbox. After the install I then used the key and inserted it into the car and waited until the computer reset. I removed the key and left the door open another 30 minutes to reset (per Sprntbooster). I called them this morning and that was their suggestion. And when I started up the car. Engine fault, reduced power and cruise control fault messages came back on. I am at a loss... I wasn't aware you could plug in the sprint booster backwards as it has a male and female end on it so it plugs inline?
ej
Nov 13, 2015 07:39 AM
Nikkielynn
Oct 12, 2015 07:33 PM
Chippawaguy
General Mini related Ads
Oct 12, 2015 06:50 AM
wrecked him
Oct 8, 2015 06:43 PM
Bhouston13
Oct 7, 2015 09:44 AM
