Cooper (non S) Modifications specific to the MINI Cooper (R50).
Addressing the Electrical System after swapping CVT for a 6 Speed Getrag
Old May 31, 2011 | 05:24 PM
matthew1619's Avatar
matthew1619
I have a 2003 Mini with a catastrophic CVT. I bought everything that I needed and successfully over the Memorial Day weekend swapped the transmission and upgraded to a 2005 Getrag 6 Speed. I have 2 wires that are from the transmission and I need to know if I have to swap out the ECM and the wiring harness, or can I have the ECM flashed. If flashed, do all the wires that are currently unplugged become inoperable in the ECM loop??
Pictured are the two sensor plugs that are left. Outside of that it was a very simple conversion!!
Any help on the electrical side would be appreciated. After I get the electrical side figured out, I will post the procedure to NAM so that everyone can remove that lame CVT from their Mini - Blessings
Attached Thumbnails Addressing the Electrical System after swapping CVT for a 6 Speed Getrag-imagejpeg_2_6.jpg   Addressing the Electrical System after swapping CVT for a 6 Speed Getrag-imagejpeg_2_7.jpg
Old May 31, 2011 | 05:25 PM
matthew1619
Additional Note
Right now I have power to the dash and ECM, but no start.
Old May 31, 2011 | 05:31 PM
HRM's Avatar
HRM
I wanted to help so I googled this. Seems like you need an ECU set up for your car... Way can reprogram them he says in the thread.
https://www.northamericanmotoring.co...o-5-speed.html
Old May 31, 2011 | 06:03 PM
matthew1619
Awesome - I will contact him!!
Old Jun 2, 2011 | 08:16 PM
Densmini's Avatar
Densmini
Matthew- my 2002 Getrag 6 spd had only the back-up light switch to wire in...a two-hole plug. No speed sensors at all.
Old Jun 2, 2011 | 10:37 PM
firehawk618's Avatar
firehawk618
This is purely my experience of cars talking, not experience in the swap you're doing.
You'll need to have your DME re-flashed to auto trans, as well as maybe the BCM and Kombi.
Another issue you may have is the anti-theft system in our cars also sends the signal to crank the starter, and if it's expecting an input from your auto trans gear selector you may have to have that changed to a manual trans one or reflashed if that's even possible on those.
Old Jun 9, 2011 | 01:24 PM
gknorr's Avatar
gknorr
Looking forward to seeing this!
Old Jun 10, 2011 | 09:31 AM
matthew1619
I will put the new brakes on tonight. After jumping the wires on the silver box to the left of the clutch pedal, I have fired the motor up and everything is in working order with the exception of the service engine soon light. I will be contacting Way Motor Works to get the ECM flashed. But, before that happens, I will be taking it out on the road tonight. Everything seems to be fully operational at this point and I am not finding that anything so far has been disabled. I will update this post tommorow, after my initial test drive!
minicoclub
Nov 11, 2015 07:25 AM
theblackfalcon
Oct 11, 2015 09:49 AM
xpunisherx
Aug 10, 2015 10:50 PM
