Cooper (non S) Modifications specific to the MINI Cooper (R50).
cvt swap to 5 speed
Old Apr 12, 2011 | 05:07 AM
victorgoforth's Avatar
victorgoforth
cvt swap to 5 speed
well it was hell but well worth it so far no problems i never could get a anwswer from anyone but now i now that it can be done
Old Apr 12, 2011 | 10:44 AM
dannyhavok's Avatar
dannyhavok
Nice, congratulations! I'm sure others would love to know more details, cost, time, etc.
Old Apr 12, 2011 | 11:09 AM
Densmini's Avatar
Densmini
There are several threads on here by people who have done it. I went for the 6-speed.
Old Apr 13, 2011 | 06:52 AM
FlzRider's Avatar
FlzRider
How did you two get past the software side of the swap? As in DSC, ABS, cruise control, etc.
Old Apr 13, 2011 | 07:15 AM
Densmini's Avatar
Densmini
You'll need a manual trans ECU reconfigured for your car by RPM Motorsport in Canada. Somewhere in the $400 range plus shipping.
Old Apr 19, 2011 | 07:27 PM
victorgoforth
used all cvt ecu, harrness, yeh i have trans codes but no problems running. tried ecu and harrness out of manule but no run to much work to change inside harrness. getting ready to put 6 speed in
Old Apr 19, 2011 | 07:36 PM
Densmini's Avatar
Densmini
Good for you! Make sure you get the right halfshafts- I think they are different from the 5-speed, but I could be wrong.
Old Apr 19, 2011 | 07:49 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the Axles from a CVT and a 5spd are different.
As for the software, I have the ability to reprogram the ECU to convert it to a manual trans.
Old May 31, 2011 | 06:10 PM
matthew1619's Avatar
matthew1619
Hey Way - I just did the swap from CVT to 6 Speed Getrag!!! I have everything done and I need to have the ECU reprogrammed - can you do that for me and what is the cost??? Also, will I need to change out the harness, or will it work with the reprogrammed ECU and CVT harness??
Thanks in Advance and the swap was amazingly simple - it was just a matter of having the correct parts..
Old Jun 1, 2011 | 04:48 AM
Densmini's Avatar
Densmini
Matthew- your best option at the moment may be to buy a used Man. trans. ECU and have it programmed for your car. That way, you should be able to keep cruise control and it'll get rid of your "EP" light on the speedo, and the check engine light on the tach. With the current ECU, you MAY run into immobilizer sync issues after a few months, unless some of the vendors who do software work have cracked that nut!
Old Jun 1, 2011 | 07:10 AM
matthew1619
Thanks Densmini - Currently it will not start, which I am assuming is the ECU saying there is no transmission so dont engage the starter. When you say have the ECU programmed for the car, are you talking about the ignition and key control??
Old Jun 1, 2011 | 11:17 AM
Densmini's Avatar
Densmini
Matthew- you are correct that the EWS (immobilizer- grey box on firewall near clutch pedal) isn't receiving a transmission input so it denies a signal to the starter. However, if you jump the two thick black wires coming out of the EWS, you should be able to crank the engine. NOTE: this means it will crank regardless of clutch pedal depressed or not, so make sure it is in neutral or you have your foot on the clutch.
As to DME (ECU) programming, the continued lack of a CVT signal MAY result in the EWS/DME going out of sync- mine does every 60-90 days and so I have to reset it. The fix is a man. trans DME configured with your VIN, or there are other software gurus trying to find a way around the EWS problem.
Old Jun 2, 2011 | 10:40 PM
firehawk618's Avatar
firehawk618
Since it seems that pretty much all the modules in our cars are tied together via vin, I think the real fix is to have your existing EWS re-flashed to manual trans spec "if possible" or buy a new EWS for a manual trans and have it married to your car.
The other problem you may have is look at the schematic for the EWS, you will likely have to re-configure or add a couple wires for the clutch position sensor.
Old Jun 3, 2011 | 05:15 AM
matthew1619
Awesome Info - Any intel on who does the flashing. I think I would like to go Manual EWS and have it married to the car!!
Old Aug 18, 2011 | 09:26 PM
trw92a's Avatar
trw92a
the 5 speed is manual right? was it hard to install the clutch pedal?
Old Aug 19, 2011 | 05:10 AM
Densmini's Avatar
Densmini
No, the pedal cluster under the dash is "universal"- just buy a clutch pedal and spring from a salvage yard (ask them to through in the washer and c-clip to hold it on or go down to the hardware store and get 'em.) The rest is plumbing- master cylinder, etc. And depending on your EWS, a clutch position switch.
Old Aug 20, 2011 | 02:35 PM
trw92a's Avatar
trw92a
Do you know if dealerships will do the install?
Old Oct 6, 2025 | 06:34 PM
aydmini's Avatar
aydmini
Any other reason why no crank no start after jumping these 2 wires?
BRracing
Oct 24, 2015 10:07 PM
Gremothra
Sep 9, 2015 08:42 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
SneedSpeed
Sep 2, 2015 05:34 AM
