&%$@ Key Won't Turn!
Old Jun 28, 2007 | 06:42 AM
Creatrix's Avatar
Creatrix
This is nothing new, actually. I will put my key in the ignition and it won't turn, and so I'll jiggle the "shifter" (and it gets quotes because it's an automatic) and then I'll try again and it's fine.
Not this morning.
I jiggled the shifter (with the key in and out of the ignition), I tried starting it in every gear, I took the brake off, I turned the wheel... I'm stuck!
Anyone have this problem and have suggestions? I'm just glad I have another car that I could take this morning.
~Melissa
(X-posted to britishcarforums)
Old Jun 28, 2007 | 08:28 AM
elprofe's Avatar
elprofe
HAVE YOU TRIED NEUTRAL?
Old Jun 28, 2007 | 09:00 AM
Creatrix's Avatar
Creatrix
of course I've tried neutral. That's what I have the car in when I'm in park as it doesn't have a "Park" state anyway.
Old Jun 28, 2007 | 12:43 PM
MaxfieldMini's Avatar
MaxfieldMini
I suspect there is a "neutral" start micro-switch in the tunnel / maybe it is loose or "shot", but I would look there first. . .
Old Jun 28, 2007 | 12:45 PM
MaxfieldMini
Uh, you said the key wouldn't turn. . . that isn't the same as not starting. . .maybe the ignition switch is just shot
Old Jun 28, 2007 | 02:29 PM
shorn's Avatar
shorn
Have you used any type of lubricant (e.g. graphite lube) on the key or in the lock? If the key won't turn, maybe its a problem with the lock innards or the link between them and the shifter interlock. It's worth a try before you start spending big $ for a switch.
Old Jun 28, 2007 | 02:33 PM
05DSMCS's Avatar
05DSMCS
I know this is pretty standard procedure, but did you try to move your steering wheel back and forth a bit while you tried to turn the key? The steering column lock may just be preventing it from turning. Just offering what might be too obvious a solution.
Old Jun 29, 2007 | 07:10 AM
Creatrix's Avatar
Creatrix
It was the wheel lock. I had tried turning my wheel and then trying the key, but I hadn't held the wheel turned and tried the key at the same time. That did it.
And she handles well in the rain too, but man, those windshield wipers are hilarious. (Okay, so I'm easily amused.)
Thanks guys!
Old Jun 29, 2007 | 01:24 PM
05DSMCS's Avatar
05DSMCS
Glad to hear everything is fine!!!
Old Jun 29, 2007 | 01:56 PM
Tall Mini's Avatar
Tall Mini
Next suggestion was going to be sacrifice a light-bulb (and maybe some Guinness) to Lucas- The Prince of Darkness. He's always lingering about.
Old Jun 29, 2007 | 02:43 PM
Madoc's Avatar
Madoc
Had a similar problem, only the ignition switch wouldn't let go of my key. Made it tough to leave on the street. Lubrication didn't help, so a new switch went in.
rikaro
Aug 7, 2021 02:33 PM
missinmyjeep
Aug 22, 2015 07:13 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
Super Coop
Aug 17, 2015 05:09 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
