R60 lip seal removal and replace
Old Jul 4, 2018 | 06:18 AM
Vinnieb's Avatar
Vinnieb
does anyone know how the pins that hold the n/s lips in, mine has split and i've got a new replacement, but i need to know how the pins are removed?
thanks
Vinnie
Old Jul 4, 2018 | 07:01 AM
MiniToBe's Avatar
MiniToBe
i have no clue what you're referring to!!! a picture will help.
maybe here? https://www.newtis.info/tisv2/a/en/
Old Jul 4, 2018 | 07:12 AM
Vinnieb's Avatar
Vinnieb
Hi, this is what I need fit, n/s/f wheel, but I can't remove the pins of the old 1, t
Old Jul 4, 2018 | 07:16 AM
MiniToBe's Avatar
MiniToBe
the plastic pins sometimes get "rusty"...spry WD-40 and try to pry on them with a flat head. once the move a bit, you could use a long nose pliers to pull it out.
In some instances, I broke the lips and pushed the pin in with a screw driver. I then recovered the pins and reused them.
I hope that helps
Old Jul 4, 2018 | 07:37 AM
Vinnieb's Avatar
Vinnieb
Great thanks, will give it a go, will send pics once changed, again much thanks
I hope that helps
Old Jul 4, 2018 | 07:39 AM
MiniToBe's Avatar
MiniToBe
Old Jul 5, 2018 | 06:32 AM
ke3ee's Avatar
ke3ee
There is an inexpensive tool for that
Amazon Amazon
Old Jul 5, 2018 | 09:46 AM
MrGrumpy's Avatar
MrGrumpy
I picked up a set of body panel removal tools from Amazon for about $15 that has the exact tool made for removing those and other plastic pins and clips, they work really well, ive been able to remove and reuse them over and over with it. Totally worth the few bucks to not have to keep buying new plastic rivets every time you break a few.
If you need to replace some, you can order OEM ones, but they are just plastic pins. They sell several different sizes replacement ones at most any AutoZone or the like. Hope this helps.
RandyBMC
How to
80
Jan 4, 2022 05:47 AM
bradyb
How to
31
Mar 3, 2019 03:45 PM
RandyBMC
How to
Feb 8, 2013 05:59 PM
RandyBMC
Aug 8, 2005 01:43 PM
DancesWithCones
SCCA Solo and ProSolo
Jun 12, 2005 09:59 AM
