R60 Removing rear MINI emblem/hatch "button"
Old Jul 6, 2018 | 01:25 PM
CalsonicSE's Avatar
CalsonicSE
Has anyone ever replaced/removed the rear MINI emblem (i.e., the "button" for the rear hatch)? There was some bird poop that I neglected to remove, and that crap ate into the finish. =(
As you tilt the button to open the hatch, you can see two tiny slots at the bottom of the emblem. Do you simply insert a small screwdriver and pry it off?
Old Jul 6, 2018 | 01:31 PM
phh06's Avatar
phh06
https://www.northamericanmotoring.co...o-replace.html
Old Jul 6, 2018 | 01:42 PM
CalsonicSE's Avatar
CalsonicSE
The link you posted refers to non-R60 Countryman MINIs, where the MINI wings emblem is affixed via adhesive. I was referring to the R60 Countryman circular MINI emblem, which comprises the outer face of the tilting rear hatch lock.
Old Jul 6, 2018 | 03:19 PM
MiniToBe's Avatar
MiniToBe
i think you have to remove the hatch panel. just pull it out gently one tab at a time. then the assembly is right there.
Old Jul 6, 2018 | 03:26 PM
MiniToBe's Avatar
MiniToBe
Old Jul 6, 2018 | 03:40 PM
DenisMcG's Avatar
DenisMcG
If you are talking about the round handle that says “MINI” just gently pry it off with a screwdriver. Go slow. I removed mine, sanded it, and painted it black, then used some aluminum tape and duplicated the MINI portion.
Old Jul 6, 2018 | 03:54 PM
CalsonicSE's Avatar
CalsonicSE
Thanks! Yes, I'm talking about the round handle. Just to clarify, did you pry off the MINI cover with the entire assembly still on the car?
Old Jul 6, 2018 | 06:47 PM
DenisMcG's Avatar
DenisMcG
Yes, just tilt the handle and insert a pry tool between the base and the badge. Do a google search for R60 trunk emblem and you will see a few pics. There are two small tabs each at the 12,3,6,9 O’clock positions. It is pretty easy to get off.
Phantom
Feb 4, 2009 10:22 AM
k_h_d
Want to Buy - All Other Items (archive)
Feb 14, 2008 08:44 PM
k_h_d
Feb 11, 2008 09:00 PM
kevinminict
Jan 7, 2008 08:56 AM
LordOfTheFlies
Aug 17, 2007 07:49 PM
