R60 Brighter fog lights on CMS
Old Jan 16, 2016 | 10:06 PM
CountryS's Avatar
CountryS
The original light bulbs in the fogs are not as bright as I would like, wondering if any one has replaced them with brighter bulbs, if so which bulbs can replace the originals ones.
Old Jan 16, 2016 | 11:23 PM
minicountry's Avatar
minicountry
Hid
Old Jan 16, 2016 | 11:43 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Haven't done it yet, but a search "h11 fog light bulbs" should give you a start. Then decide yellow, LED, etc.
Old Jan 17, 2016 | 04:30 AM
CountryS's Avatar
CountryS
Great thanks for the info
Old Jan 17, 2016 | 09:35 AM
Zephyr1's Avatar
Zephyr1
Check out this thread:
https://www.northamericanmotoring.co...og-lights.html
It's a post on how to replace the 35W H8 bulbs with 55W H11 bulbs.
Old Jan 17, 2016 | 06:33 PM
bmwr606's Avatar
bmwr606
every auto parts store near me sells both 35 watt and 55 watt h8 bulbs in yellow and several different white tints
my dealer says the heat of 55 watt bulbs will damage the housings
Old Jan 18, 2016 | 01:26 PM
https://www.northamericanmotoring.co...s-r60-r61.html
I used the yellow for areas of high snow or fog. Some people like the platinum as it matches the factory xenon. And there H8 bulbs will not burn out the housing like other higher wattage bulbs/
The Ziza postions add some light also.
The option for people without factory fogs is the Ziza Postion light leds. Its in the link above.
https://www.northamericanmotoring.co...tonight-3.html
Ziza Front Position Light LEDs ES2684738
http://www.ecstuning.com/Search/SiteSearch/ES2684738/ES2684738/
449524_x600_29265aa467aa7e98fb8d631cb1b0a7ca93d788 cc.jpg[/IMG]
Otherwise you have the Factory DRL / Fog kit : 63122338554
https://www.northamericanmotoring.co...-w-o-fogs.html
Thanks and hope that helps.
Old Jan 18, 2016 | 02:32 PM
nkfry's Avatar
nkfry
If you're looking to keep the factory housings I've had good luck with the Sylvania ZXE bulbs in previous vehicles, no HID conversion required.
If you want better light output, an HID setup from retro-solutions.com would be a great setup at a reasonable price.
But if you want the awesome looks as well as the added light output, I highly recommend the MINI Driving Lights that replace your lower marker/fog light housings.
MINI Driving Lights
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 18, 2016 | 03:13 PM
CountryS's Avatar
CountryS
I will be going with these, thanks for the great info
https://www.ecstuning.com/News/MINI_...mpaign=newpost
Old Jan 19, 2016 | 04:45 AM
You are welcome.
pppdxx
Jul 27, 2020 06:25 PM
DivineXtacy
Oct 1, 2016 04:24 PM
09JCWClubman
Jan 21, 2016 06:09 AM
banyan
Jan 13, 2016 07:01 PM
DaGriz
Jan 13, 2016 02:06 PM
