F55/F56 Turn Signal LED Bulb replacement
Old Jan 12, 2016 | 07:39 PM
pppdxx's Avatar
pppdxx
I have the LED headlights, but I believe the turn signals in those headlights are still halogen.
ECU do you have any LED PWY24W bulbs?
Old Jan 14, 2016 | 11:20 AM
siriuszero's Avatar
siriuszero
Yep, still halogen. Make sure if you do replace them with LEDs though, grab CANBUS LEDs or you will get bulb out warnings all the time and/or hyperflashing or strobing. Alternatively, if you get into ESYS and coding, you can code the bulb checks out. That's the route I took.
I grabbed some CREE LED bulbs off eBay that do the trick. Brightest ones I could find.
Old Jan 14, 2016 | 08:43 PM
pppdxx's Avatar
pppdxx
I have some side blinker leds installed that are advertised as CANBUS. The right blinker hyperblinks, the seller is sending me a replacement bulb, we'll see if that fixes it.
Is hyperblinking something that I can code out?
Old Jan 15, 2016 | 12:16 PM
siriuszero's Avatar
siriuszero
Yes. ESYS has a parameter for calling out LED lights that will eliminate strobing or hyperflashing.
Old Jan 15, 2016 | 09:27 PM
pppdxx's Avatar
pppdxx
Want! Can you please share with me the parameters to code please?
Old Jan 16, 2016 | 10:24 AM
siriuszero's Avatar
siriuszero
I don't have the cheat sheet I used to have but it's in the FRM or BDC module.
I think these are the parameters for the front turn signals. There are three for each bulb. One to turn off cold check, one to turn off warm checks, and one to specify LEDs. I don't know if all three are required, but I know I switched all three and I don't get strobing or bulb out warnings with non-CANBUS LED bulbs.
AUSG_22_FRA_VL_IS_LED - Change to aktiv
AUSG_22_FRA_VL_KALTUEBERWACHUNG - Change to nicht_aktiv
AUSG_22_FRA_VL_WARMUEBERWACHUNG - Change to nicht_aktiv
AUSG_23_FRA_VR_IS_LED - Change to aktiv
AUSG_23_FRA_VR_KALTUEBERWACHUNG - Change to nicht_aktiv
AUSG_23_FRA_VR_WARMUEBERWACHUNG - Change to nicht_aktiv
Old Jan 16, 2016 | 10:59 AM
pppdxx's Avatar
pppdxx
Thanks for the help. I just did the following, hopefully it'll solve the hyper-blink on my drive today.
## Blinkers to LED
BDC Body
FRA_V_L_KALTUEBERWACHUNG -> nicht_aktiv
FRA_V_L_WARMUEBERWACHUNG -> nicht_aktiv
FRA_V_L_IS_LED -> aktiv
FRA_V_R_KALTUEBERWACHUNG -> nicht_aktiv
FRA_V_R_WARMUEBERWACHUNG -> nicht_aktiv
FRA_V_R_IS_LED -> aktiv
FRA_Z_L_KALTUEBERWACHUNG -> nicht_aktiv
FRA_Z_L_WARMUEBERWACHUNG -> nicht_aktiv
FRA_Z_L_IS_LED -> aktiv
FRA_Z_R_KALTUEBERWACHUNG -> nicht_aktiv
FRA_Z_R_WARMUEBERWACHUNG -> nicht_aktiv
FRA_Z_R_IS_LED -> aktiv
FRA_H_L_KALTUEBERWACHUNG -> nicht_aktiv
FRA_H_L_WARMUEBERWACHUNG -> nicht_aktiv
FRA_H_L_IS_LED -> aktiv
FRA_H_R_KALTUEBERWACHUNG -> nicht_aktiv
FRA_H_R_WARMUEBERWACHUNG -> nicht_aktiv
FRA_H_R_IS_LED -> aktiv
Old Jan 16, 2016 | 12:17 PM
siriuszero's Avatar
siriuszero
Yeah, those parameters look more familiar - the ones I posted must be from a BMW.
Old Jan 16, 2016 | 01:51 PM
pppdxx's Avatar
pppdxx
Worked like a charm. Hyperblink is eliminated.
Old Jan 16, 2016 | 02:05 PM
siriuszero's Avatar
siriuszero
Old Jun 2, 2019 | 05:32 PM
cub4bearindiana's Avatar
cub4bearindiana
how the heck do You even get to that indicator bulb? I have the LED headlights too... is that mean I have to take out the whole light out to get access to that bulb?
Old Sep 5, 2019 | 02:34 PM
15MCSJCW's Avatar
15MCSJCW
I'd like to know as well!
Old Jul 23, 2020 | 03:42 PM
minideucecoop's Avatar
minideucecoop
Change your front turn signal bulb
Since I don't think anyone has answered. Let's say your replacing the front drivers side turn signal bulb. It's inside the headlight housing. Turn the steering wheel all the way to the right. (If lowered, you might have to jack the car, or take off the front wheel.) Looking at the drivers side front wheel, there is a round panel at the 10 o'clock position. Twist that a quarter turn (Lefty loosy) and if you look in, you will be looking at another twist cap cover which is located at the bottom of the headlight assembly. Unscrew the bottom cover of the headlight assembly, and then you can reach in and pull out the turn signal bulb.
Old Jul 25, 2020 | 03:16 PM
shmandrew's Avatar
shmandrew
## Blinkers to LED
BDC Body
Since this thread is back from the dead.... can you please clarify if this is for the turn signals in the headlights or if this is for the side scuttle turn signals. I'm having hyperflash issues with supposedly CANBUS LED side scuttle indicators. Pretty sure I already tried the above and the hyperflashing didn't stop.
Old Jul 25, 2020 | 05:40 PM
minideucecoop
This is to set all the bulbs to led and turns off the warming checks. This is auf Deutsch, but it's the same settings listed in the bimmercode body domain controller, bdc menu.
Old Jul 27, 2020 | 06:25 PM
jpsjr1970's Avatar
jpsjr1970
I too put LED Turn Signal Bulbs in from LASFIT with Canbus and unfortunately still get the strobing effect with the coding. Anyone? Thoughts?
NathanMckee
Jan 23, 2016 11:25 AM
I_drive_slow
Jan 20, 2016 10:28 AM
Minifan85
Jan 13, 2016 05:59 AM
carltdh
Jan 12, 2016 12:59 AM
rob.james.arias@gmail.com
Jan 8, 2016 09:27 AM
