R60 HK Audio System - Something Wrong?
Old Dec 14, 2014 | 02:31 PM
DWooderson's Avatar
DWooderson
There seem to be several discussions about audio lately. Coincidentally, this is the biggest question/issue that I have with my new (used) 2011 R60s.
The HK system sounds ok, but barley ok. It's not as good as the base audio in my old 2006 Volvo. It's not even half as good as the HK audio in our 2007 Mercedes, which has rich full sound and very strong bass that never cracks.
My R60 has almost no bass, and the overall quality of the sound degrades when I turn the bass up past the middle level.
The subs below the seats seem to be working, I put my hand on the grill, and can feel some some vibrations. But it certainly isn't solid bass or loud bass. I've tried all sorts of music from various sources (radio, sat, usb). I'm not looking for boomy bass, just decent bass at volume.
Is this the way all HK systems sound in R60s, or do I have an issue?
Would this be an improvement?
http://www.bavauto.com/fland.asp?part=SWS-8XK
Old Dec 14, 2014 | 03:00 PM
percymon's Avatar
percymon
If its anything like the set up in the R56 then the HK speakers are 2Ohm units - there are very few aftermarket speakers rated at 2Ohms - something to check before you buy.
Old Dec 14, 2014 | 08:04 PM
flav's Avatar
flav
I just got my 2015 with HK and its barely better than the stock in my 128i...its honestly like there is zero base. audio is clear but not very dynamic and at full volume isnt very loud...id HATE to see what the standard audio system sounds like if this is what the $750 upgrade sounds like :/
I also think there is something wrong with mine, its THAT much of a letdown
Old Dec 14, 2014 | 09:42 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
My 2011 sounds fine. Is it the best audio system I've ever heard, no . . . but it is pretty good except for playing quiet passages when the run flat tires are wailing on the highway. Obvious question, did you check the settings to make sure the bass was not set at the lowest position? Could be an amp problem otherwise.
Old Dec 15, 2014 | 07:43 AM
The X Men's Avatar
The X Men
We bought our test CD to the dealer to decide if the HK is worth it. It was very disappointing, like the OP said, no bass and no power. Its $50 less than the HK system in my BMW and honestly, the CM's HK system sounds like it has half of the power and the clarity is also not as good as BMW's HK system. I just don't see how Mini can charge $750 for this so called upgrade.
Old Dec 15, 2014 | 08:17 AM
DWooderson's Avatar
DWooderson
So my system is working as expected. How disappointing. What I can do to make it sound better on a budget?
I think the factory subwoofers are rated at 4 Ohms, based on the picture in this thread. So still wondering if the earthquake sub drivers would be an improvement, or a waste of money.
Another online store:
http://www.onlinecarstereo.com/CarAu...ke_SWS-12.aspx
This retailer has a few reviews, most people recommend using an aftermarket amp:
http://www.sonicelectronix.com/item_...nd-SWS-8X.html
What do you use for input to the aftermarket amp; the amplified output from the factory amp? Do you need a line-level adapter? It's been 15 years since I've messed with car audio. Rephrased: It's been 15 years since I've had to mess with car audio just to make it serviceable.
Old Dec 15, 2014 | 09:10 AM
DWooderson's Avatar
DWooderson
Ok, I'm about to order the earthquake subs and a cheap amp:
http://www.sonicelectronix.com/item_...SL-F2.200.html
And finding a local installer (North Dallas). Thoughts?
Hardware Cost: $120 + $120 + $20 = $260
Installation: ~ $100 ?
Total: ~$350
Will this be an improvement?
Old Dec 15, 2014 | 11:05 AM
Katherine.mc's Avatar
Katherine.mc
My HK system was quite the disappointment as well. Absolutely no bass, the speakers seem to rattle at times. I can only imagine how the standard system must sound if this is an 'upgrade'.
Old Dec 15, 2014 | 01:44 PM
bratling's Avatar
bratling
Super Moderator
The base audio system is utter *****. The R56 series have decent audio; not great but okay, you can hear the music well. The R60 has horrible audio: muddy middles, missing highs, sluggish bass. Music sounds just awful.
Ordered new speakers for my wife's R60 for Christmas. Selfish present; I can't take the sound of music in her car anymore.
However, the R60 base audio would pair well with AM talk radio. :-)
Old Dec 16, 2014 | 09:16 AM
Jason Garrett's Avatar
Jason Garrett
I guess I'm just not an audiophile but I think the base system sounds fine. I tested the HK system and didn't think it was worth $750, the bass sounded messy. When I do listen to music loud I like tight/punchy bass. But honestly I think it's fine as is for now. Maybe (big maybe) I'll add a high quality flat 10" subwoofer under the seat and an amp under the other seat, but who knows.
Old Dec 16, 2014 | 09:25 AM
bratling's Avatar
bratling
Super Moderator
So… the HK in the R53 (up to 2006) was superb. It may not have had the most power out there, but it was easily loud enough to hurt my ears well before hitting max volume. The bass was strong and tight. It shook the rear view mirror enough to blur my view out the rear when listening to bass-heavy music. And it won some awards for quality of OEM systems.
So I guess my question is: what went wrong with the R56 Harmon Kardon system? The HiFi was well documented in its shortcomings. I've never listened to the Gen 2 HK so I don't really know if it's that much worse than the original, or if it merely isn't up to highly discerning ears.
Can someone with direct experience of the R53 HK and the R56 LCI Harmon Kardon system chime in?
Old Dec 16, 2014 | 09:48 AM
y8s's Avatar
y8s
Total: ~$350
That amp will do nothing for you. It's 200W max. 50WRMS per channel into those speakers. And at $20, I suspect you'd be lucky to get half the rated power out of it without much distortion.
You want an amp that can easily push at least the rms power capacity of the speakers so avoid distortion. There are a bunch of amps in the 50-60 dollar range on that site with much more power. I suggest you don't cut corners here if you're trying to fix a problem with the system.
I can't speak to the subs because I don't know the arrangement of the ones in there now. Just be aware if you put the wrong type in the wrong box, you'll get a bad result (floppy deep bass, no punch, etc.). The sub and box have to be designed to both work with each other and also the size and shape of the interior of the car. Pick wrong and you'll get mediocre results.
Old Dec 23, 2014 | 06:44 PM
six82's Avatar
six82
R53 with HK
I had an '06 R53 with the HK and it was fantastic. Absolutely one of the best OEM sound systems I had ever heard.
I am currently mulling what to do with the 2014 CMS I just purchased. It does not have the HK and is really weak. I would love to go back to the HK sound from our R53.
Old Dec 27, 2014 | 02:10 PM
BlackNorton's Avatar
BlackNorton
I had the Bose system in my A6 and I think the HK system in my '12 CMS sounds great! Maybe it sounds better with '60's and '70's music than newer stuff.....
Old Jan 1, 2015 | 08:30 PM
HorseWithNoName's Avatar
HorseWithNoName
I'm thinking its something wrong with the systems that needs to be identified and addressed by Mini/BMW. The HK in our 2013 R61 sounds as good or maybe better than the 14 speaker premium Bose system in our Infiniti and it really sounds good.
Old Jan 10, 2015 | 07:18 AM
shark715's Avatar
shark715
I currently have a 2015 Countryman loaner without HK as our 2013 Countryman with HK is getting serviced. I often like to crank the tunes, and there's noticeably more distortion at higher sound levels with the base system, and less clarity at more moderate sound levels. To me the difference is definitely noticeable, but I'm not sure I would term it dramatic. If I had to do it all over again, I would spend the extra $ for the HK, but I can understand that others might not. Best if you can listen to the systems back to back at the dealer, but the problem is that you generally don't see many HK equipped Countrymen sitting on a dealers lot.
Old Jan 10, 2015 | 06:35 PM
flredmini's Avatar
flredmini
So I have a CPO 2011 CMS with the HK sound system. I don't see where I have under the seat subs. Should I?
Old Jan 11, 2015 | 10:56 AM
cooperjunkie's Avatar
cooperjunkie
I have the HK in my 12 CMS and it's certainly not amazing but I'm relatively impressed with it. It's definitely better than the base system in any MINI. I will say though, I had a 15 Cooper with HK for a loaner 2 weeks ago it I thought it had a lot clearer highs and better bass. Definitely had more thump.
Old Jan 16, 2015 | 02:03 PM
Mr_Bueno's Avatar
Mr_Bueno
This HK in my 2013 is actually really good. The only car I've owned that had a better sound was my BMW Z4 which had the BMW professional sytem upgrade and had 8 speakers and 2 subs... The bass was significantly more powerful and louder in that car... It was also a smaller area and the subs where right behind the seats and not stashed under them. So the sound was prolly louder as a result.
I should mention that I listen to all types of music and I listen to it LOUD. I also love bass in my music - no matter what I'm listening to. That being said, the bass was so loud in the Z4 that I would have to turn it down at times or it would drown out everything else. The bass in the HK in my CMSAll4 is not as powerful, but the clarity of the music is better as a result.
Old Mar 20, 2015 | 06:24 AM
JohnRausch's Avatar
JohnRausch
It's not the speakers, at least not JUST the speakers
Had a 2007 S and 2013 JCW with HK, *NO* problems. Have a 2014 with basic head & speakers and 2015 S with basic head and HK speaker upgrade. Both are terrible. Any sign of bass is muddy and overwhelms music. I've never heard such distorted mid-bass in any car, going back at least 20 years. Bass is turned down to 2-4 bars -- no help. Actually, all the way down, doesn't help much. Playing Apple Lossless (CD quality from iPhone 6 via USB and 256bps MP3 via flash drive with identical results) in both cars -- so with and w/o HK speakers! FM is less of a problem, but still a problem. Problem is more than likely in the head, maybe with the DAC -- who knows -- but, it's unlistenable except for NPR and other talk radio. Seems to be door speakers that are the worst, but maybe they are just have the loudest muddling sound.
Do those who are unhappy, have the basic radio head with or without HK, or is it all heads, Navi, Connect? I ask because some say HK is just fine, but what head are they driving them with? I don't think the speakers are the cause of the problem. Sure, sticking a cap in line with door speakers will cut down bass more and that will decrease the distortion, but I believe that is treating the symptom, not the disease.
Visiting the Mini dealer to try in many Minis soon.
Old Mar 20, 2015 | 06:40 AM
Katherine.mc
Any suggestions for audio upgrade? I just want a real high quality sound with excellent bass and none of that crackling noise that I currently get with my HK at certain pitches
Old Mar 20, 2015 | 07:45 AM
DWooderson's Avatar
DWooderson
I'm still stock. Would love to hear suggestions as well.
I don't really turn it up loud, but I like full range, and solid (not loud) bass.
Old Mar 20, 2015 | 07:50 AM
Minnie.the.Moocher
Do you have a favorite album or song that really showcases how "bad" or "good" your system sounds? Some music I play sounds great in the car and other songs don't do as well. Hard to suggest changes without music type, etc.
Old Mar 20, 2015 | 08:23 PM
Killerbee's Avatar
Killerbee
We have a 2011 Countryman S with the HK system and it sounds great...and I am a picky music kind of person. I would take your car to a good sound system shop and have it looked at.
khumpert
Nov 30, 2015 11:48 AM
theblackfalcon
Oct 11, 2015 09:49 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
tippin
Aug 5, 2015 08:43 AM
