No one can figure this out
Old May 27, 2011 | 08:12 AM
lozapiggy's Avatar
lozapiggy
Hi everyone. It's my first time posting. I have a 06 MCS with 60k miles on it. I have had a rubbing/grinding noise in my driver side front tire for months now and it's getting worse. From outside of the car it sounds like a dry rubbing sound on the tire but from inside the car it seems to have a more grindy sound. I have taken it to the shop to have the cv joint checked and they said it was fine. They cleaned up the crud around the wheel which made it better but only for a few days. It is now worse than ever! It's only when I turn to the right while in drive. It doesn't happen when I am turning left or when I am in reverse.
Any advice would be appreciated. I'm afraid this might be serious.
Thanks MC friends.
Lozapiggy :@)
Old May 27, 2011 | 10:27 AM
moreorless's Avatar
moreorless
More than likely it's the wheel hub bearing.
#7 in this image.......
....Les
Oh, and find a new mechanic.
Old May 27, 2011 | 10:32 AM
HRM's Avatar
HRM
....Les
That's it...what kind of mechanic you bring it to? Classic symptoms for a common issue (in all cars I know of)
Old May 27, 2011 | 03:49 PM
lozapiggy's Avatar
lozapiggy
I just switched the front tires and the noise is now on the other side. Loose at 3 and 9 o'clock but not at 12 and 6. Thinking bad tie rod just wore the tire. Thoughts?
Old May 27, 2011 | 05:02 PM
Mike@Tech Division's Avatar
Mike@Tech Division
Tie rod is a possibility. You also should check the rear bushing and the ball joint on the front LCA . They are known to go bad at higher mileage and can let the control arm move around.
Old May 28, 2011 | 09:49 AM
HRM's Avatar
HRM
Well if it moves with the tire, it isn't the bearing.
I just got new tires and they are so much more quiet than the old ones.
Old May 28, 2011 | 10:32 AM
mrjasey's Avatar
mrjasey
how is your treadwear? if you have cupping on your tire, it can make it sound like a bad wheel bearing, though that would not explain the grinding sounds. have you experience the sound under any braking?
Old May 28, 2011 | 04:28 PM
moreorless's Avatar
moreorless
Well done!
You should be the mechanic!
....Les
Old May 30, 2011 | 11:33 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Oh and Welcome to NAM too
shadtree
Cooper (non S)
Sep 8, 2016 12:02 PM
randeez
Oct 5, 2015 09:23 AM
potterstein
Oct 2, 2015 09:30 AM
dutchhome
Sep 30, 2015 07:17 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
