Warped rotors - replacment questions
Old May 18, 2006 | 06:45 PM
Bugs's Avatar
Bugs
Hey guys, got some vibration in the wheel under braking. Pretty sure my front rotors are a bit warped.
I do not track the car at all. Just some aggresive street driving. Is it worth the extra money to go to aftermarket cross drilled/slotted rotors ? or just get the oem pieces?
And also brake pads. Stock replacments, or something else which will stop good. Last a long while and put out less dust.
What should I expect for prices for stock front rotors?
And how much price difference is there between stock and upgraded low dust pads?
Old May 18, 2006 | 06:51 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
I just got new rotors (plain-faced Brembos on the fronts and OEMs on the rears) and pads before the Dragon a few weeks ago. Went with the Hawk ceramic street-race pads and they are great! Waaaaaay less brake dust! My wheels look clean, even after being at the Dragon!!!!
Motor On's Avatar
Motor On
I would reccomed ceramic pads available for the local auto parts shop. They stop better, and have less than 10% the dust output, cost $50 and wear much much slower, and don't squeak. Form what I heard on WRR a "set" of stock rotors run about $90, I know the Nuzzo race team unly upgrades fluid and pads and leaves stock calipers and rotors, so they are capable.
Old May 18, 2006 | 06:58 PM
not-so-rednwhitecooper
Cross drilled calipers are not good for street use.
if your going to upgrade, get powerslots or a comparable slotted rotor.
cross drilled + daily driver = cracked rotors.
Old May 18, 2006 | 07:12 PM
Bugs's Avatar
Bugs
Brembo stock replacements + Hawk ceramic pads sound like a good combo to me
Not paying BMW price for parts + i know both names from my VW days.
Anyone have part numbers for front Brembo rotors and the hawk pads?
The local shop i order from is great for prices, but none to bright. Part numbers ensure they dont screw up the order
Old May 19, 2006 | 01:24 AM
BFG9000's Avatar
BFG9000
Maybe if you get matching cross drilled brake lines?
Be aware that some of the slotted or drilled rotors make a "pumping" or whooshing sound when using the brakes, so may be a good idea to search for reviews first. And warped rotors are frequently from improperly torqued lugs.
Old May 19, 2006 | 01:51 AM
MINIclo's Avatar
MINIclo
7th Gear Gal
Bugs, I'll try to find the part numbers for you, and will post them here in this thread.
Old May 19, 2006 | 05:34 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Bugs, PM me and I'll sell you my OEM rotors and Hawk Ceramics for $100 the lot plus shipping. I have a BBK and they are just sitting there in a box in my garage. Maybe they have 7k on them, and the Hawk pads have 5k on them.
cheers, phil
Old May 19, 2006 | 09:59 AM
Shea's Avatar
Shea
I think the stock rotors are the cheapest. If I'm correct it's like under $70 for a pair.
Old May 19, 2006 | 01:38 PM
Bugs's Avatar
Bugs
wow. I just called MINI Oakville (closest mini dealer)... 126$ a piece!!
Local parts house has Raybestos rotors for about 70$ for the PAIR..
And ceramic pads for another 40$.
Now the question is, for a daily driver, non tracker, is it worth the extra money to get the Brembos from Helix13 (ends up close to 70$ each after exchange etc) and the additional price for the Hawk pads?
Old May 19, 2006 | 04:27 PM
moreorless's Avatar
moreorless
I like the red ones....plus the added benefit of "air brakes".
....Les
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
ShadyCoop
Aug 24, 2015 06:05 AM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
nomar116
Aug 10, 2015 11:24 PM
