16x8 et38 w 225/45/16 on 2nd gen?
Jan 11, 2019 | 06:34 PM
My number crunching and searching tells me these should probably be fine on stock suspension. Can anyone confirm or deny?
Jan 12, 2019 | 03:41 AM
Jan 12, 2019 | 04:44 AM
Yeah I did that already. It doesn't actually tell you if it fits it not, just how it is different from the stock setup.
Jan 12, 2019 | 08:51 AM
If you take 15 minutes to measure your car, you can compare the current wheel-tire set up to the one you would like to run.
Jan 13, 2019 | 04:51 PM
How do you recommend I measure clearance with the suspension compressed or clearance with the steering wheel turned full lock or both at the same time?
Quote:
Originally Posted by
njaremka
Jun 15, 2021 | 09:43 PM
jiggersplat
so did u get 225/45/16 tires?
Jun 16, 2021 | 07:18 AM
I ended up with a set of 215/40/17s on Enkei RPF1's. No issues.
Jun 16, 2021 | 10:17 AM
[QUOTE=jiggersplat;4589550]I ended up with a set of 215/40/17s on Enkei RPF1's. No issues.[
oh ok thanks
MiniJayhawk
Tires, Wheels, & Brakes
Feb 27, 2008 08:06 PM
newyork08
14
Feb 18, 2008 11:16 AM
johnD
Aug 18, 2005 08:17 AM
andy@ross-tech.com
Dec 8, 2004 01:47 PM
Skottoman
Nov 3, 2004 06:38 AM
