Official F56 Wheel Fitment Thread
Old Jun 17, 2022 | 08:57 AM
  #1151
bradstyle's Avatar
bradstyle
Yipes, jetlag/no coffee strike again. I believe I meant 225/45/17. Yes, that's it. I did have a tiny bit of rubbing with my A052s so I'll give the 225 Falkens a go, and I'll report back here after I give them hell. THANKS
Old Jul 30, 2022 | 09:10 PM
  #1152
resolute's Avatar
resolute
Originally Posted by jamesdean
17x7.5 ET45. 225/45/17
Attachment 146042
Attachment 146043
This is what I really wanted to see. Thanks!
Old Sep 2, 2022 | 11:50 AM
  #1153
entropic_nic's Avatar
entropic_nic
2016 F56 JCW
Enkei TS9 17x8 ET45 Grey (~19lbs)
Continental ExtremeContact DWS06 Plus 225/45ZR17
BC Racing BR Coilovers with DDC, near highest setting
Using the included BC Racing 4mm spacer up front due to 1.5 degree camber setting (this can be adjusted).
On stock suspension the wheels/tires fit without spacers.
Fronts poke out just a bit but it suits the car nicely IMO. Rears are a bit more flush, so I think I'll get either a 5 or 8mm spacer for them.
Gotta tell the wheel alignment people to be careful with placing the wheel weights as there is a millimeter or two clearance from the front brake caliper, and my original set of weights impacted the caliper.
Yes I know the car is filthy in the pics :/
Old Sep 3, 2022 | 04:55 AM
  #1154
Eddie07S's Avatar
Eddie07S
Nice!
I had a similar issue with the wheel weights on my Sparco wheels, with the weights hitting the brake pads. I just had the shop put the weights on the wheels inboard of the caliper.
Old Sep 4, 2022 | 06:59 AM
  #1155
MikeMJCW's Avatar
MikeMJCW
O.Z. Ultraleggera 18x8 45et. The online calculators put the rim 1mm from the strut however the backspacing is almost the same as the stock 17x7 54et go figure. Hankook Ventus V12 EVO2 215/40-18
Wheel = 18.8 lbs. With tire TPMS, valve etc. 38.8 lbs (Stock 17x7 wheel & Pirelli RF = 43.6 lbs)
Old Feb 10, 2023 | 07:22 AM
  #1156
Harmini_MN's Avatar
Harmini_MN
I just picked up a 2020 JCW and have the opportunity to pick up a set of Sparco FF-1 wheels with Firehawk Indy 500 tires. Will these wheels clear the Brembos? I'm have trouble finding info..
Thanks in advance for the wisdom!
Old Feb 10, 2023 | 10:25 AM
  #1157
Eddie07S's Avatar
Eddie07S
Need to know the wheel and tire sizes. The wheel diameter, width and offset (the ET)
And congrats on the JCW. Great Car
Old Feb 10, 2023 | 10:32 AM
  #1158
Harmini_MN's Avatar
Harmini_MN
Thank you, it is one sweet ride. I've been working up to this one my whole life. LOL. Anyway, here's the wheels I'm interested in: Sparco FF-1 and Firestone Indy Tires
Old Feb 11, 2023 | 04:53 AM
  #1159
Eddie07S's Avatar
Eddie07S
Nice wheels…
The 45ET, 8” wide wheels will fit a 225 tire nicely, which makes for a nice autocross setup. However, that size tire on these wheels is tight in the rear wheel wells with a bit of rubbing on the plastic liner…. These wheels with the 215 tires will fit the wells with no issues.
But I digress.
I can’t say for sure that they will clear the calipers. They look a lot like the Sparco Trofeo wheels I have (link) but with a little less depth to the spokes. Diameter wise, the 17” wheels will clear the calipers, but you may need to limit where the wheel weights are placed to clear the tangs on the brake pads, as I had to do (see link). The issue that I ran into was clearance to the spokes. There was only about 2mm of clearance between the spokes and caliper. I opted to add a 3mm thick spacer up front to ensure wheel flex would not cause any contact. I run my JCW on the track, so this was an important consideration for me.
As for the wheels you are looking at… I wish I could say that I have them and that they fit. But, no. I can say that they should fit on the diameter. But I can’t say for sure that they will clear the spokes. If that is tight, a spacer would be needed.
Sorry I can’t help more.
Old Feb 11, 2023 | 07:47 AM
  #1160
Harmini_MN's Avatar
Harmini_MN
Nice wheels…
But I digress.
You've been great - between you and Tire King (who says 'no' on the fit) I've decided to pass - but my husband with his very own 2022 MCS wants them now. LOL. Thanks again!
Old Feb 11, 2023 | 08:39 AM
  #1161
Eddie07S's Avatar
Eddie07S
When (if?) he gets them, try them on your car and let us know what you think… I'd be interested, probably along with a bunch of others. ET45, 8" wide 17" wheels that fit the JCW are hard to find.
Old Feb 11, 2023 | 08:43 AM
  #1162
Harmini_MN's Avatar
Harmini_MN
GMTA - will do. There may be a fight in the garage -
Old Feb 12, 2023 | 05:08 PM
  #1163
Mash's Avatar
Mash
Originally Posted by F56-JCDub
Thanks to all that helped me settle on the 215s. They fit perfectly on my F56 JCW.
NVM - found a post where you mentioned the brand/model.
What wheels are these - BBS?
Thanks!
Jim
Old Mar 27, 2023 | 11:10 AM
  #1164
Trakwagn's Avatar
Trakwagn
Cross post from the JCW wheel thread
Just got my new wheels sorted, they needed a bit more work to get the fitment right then I expected but I think the end result was worth it.
2023 JCW Hardtop
18x8.5" +43 König Ampliforms
225/40r18 Continental DWS 06 Plus tires front and rear
10mm spacer in the front for brake caliper clearance, no spacer in the rear
Silver project camber plates to add 1.5 degrees of additional camber up front so they don't poke out from under the fenders
The car is lowered on NM springs
No rubbing on this set up and it clears the front caliper by about 2.5mm.
Old May 4, 2023 | 07:29 PM
  #1165
trandz23's Avatar
trandz23
Originally Posted by LOLOLIVER
I ran this sam setup for quite some time. Work perfectly fine but your suspension setup needs to be done correctly. this will 100% rub if youre lowered.
I used the RSE11 wheels however the specs are the same.
sorry, but this is incorrect as proven by ppl posting before you. Someone is on coils with 18x8 225/40/18 just fine
Old May 6, 2023 | 12:14 AM
  #1166
rs_t's Avatar
rs_t
Hi. Will Countryman JCW Thrill Spoke 7,5 x 18 ET51 fit on a 2020 F56 Cooper S, and if yes, what tyre size? Anyone done 18 Countryman wheels on 3 door?
Old May 6, 2023 | 05:04 AM
  #1167
Eddie07S's Avatar
Eddie07S
Welcome to NAM, rs_t from Norway
I’ll say right up front…. I have not.
However, looking at the specs for the two cars, it should fits. We have access to Tire Rack which has a wealth of tire and wheel information. Not sure if you can access Tire Rack from there, but this is just an example of a wheel that they list as fitting the 2020 F56 Cooper S:
https://www.tirerack.com/wheels/Whee...dClar=Cooper+S
It is basically the same size (7.5 x 18, ET50 and same bolt pattern) as the Thrill Spoke you are looking at. So, based on that, the wheel should fit.
As for tire size - The diameter of the stock MINI 17” tire that came on the Cooper S is about 24.3 inches. A matching tire size with that diameter in an 18” would be a 205-40x18. However, the 215-40x18 would be a good match at about 24.8 inches and is a typical up-size. As noted in the above post and other previous posts, the 225-40x18 should fit.
Hope that helps.
Maybe someone will chime in and say they have actually done this.
Old May 27, 2023 | 09:54 AM
  #1168
James1980's Avatar
James1980
Finally got some new wheels for my '23 Resolute edition. The 18s were a little harsh for our crappy roads so I went down to 17s.
They're 17x7.5 BBS XR +45
Tires are 215/45/17 Continental extreme contact sport
Car is lowered on H&R Sport springs
Old May 29, 2023 | 01:56 PM
  #1169
mdtran's Avatar
mdtran
I dedicated much time to reading this thread from post #1. As a result, I feel it is now my turn to contribute and give back to the community. I wanted to go with an OEM+ look so pulled the trigger on classic split-spoke/mesh wheels that were light.
Wheel/tire specs:
Neuspeed RSE12
19lbs
18 x 7.5", ET40
Kumho PS71 215/40/18
10mm Burger Motorsports spacers in the rear, so effectively ET30
Lowered on NM engineering Alpha springs
Fronts: +20mm offset from OEM wheels
Rears: +30mm offset from OEM wheels
Front sits nice and flush with a bit of poke. I wasn't happy with the rear stance so I added 10mm spacers to the rear. Clears front BBK and both front and rear struts. Bit of rub to the rear inner plastic fender lip but that was self-correcting after a spirited run . Other mods include NM engineering 22mm rear sway bar and Powerstop carbon ceramic brake pads as well for less dust.
Old Jun 16, 2023 | 11:32 AM
  #1170
MikeMJCW's Avatar
MikeMJCW
O.Z. Indy HLT glass black 18x8 45et on F56 JCW
20.8 lbs. Test fitted these today. Liking the gloss look.
O.Z. Indy HLT Gloss Black
5mm clearance to brake caliper
5mm clearance to strut
Old Jun 16, 2023 | 01:44 PM
  #1171
That fitment!
Old Jun 18, 2023 | 07:42 PM
  #1172
starman202's Avatar
starman202
Wheels: Enkei - TS9 - 17x8 (ET45)
Tires: Continental - Extreme Contact Sport - 215/45R17
Hub Centric Rings: Wheel Connect (from Amazon) 72.56 to 66.56
TPMS: BHSens with Black Metal Valve Stems
Spacers: 2MM Dinan Spacers (for front)
WEIGHT:
OEM Style 501 17" with HANKOOK- OPTIMO H426B HRS [Run Flats]: 46.6lbs
Enkei TS9 17" with CONTINENTAL- EXTREME CONTACT SPORT: 38.6lbs
I installed these wheels on my 2022 F56 JCW. As stated by other F56 owners with this same wheel, at stock height and with 215/45 tires, it'll clear the strut and front JCW calipers without spacers. However, it is REAL CLOSE to the JCW front caliper, about 1mm. I went with 2mm spacers to give a bit more space between the caliper and spoke as I plan to track the car.
POKE:
Rears: Are 5mm inwards from the fender (however, be warned that adding a 5mm spacer or more would reduce the hub lip contact to the hub centric ring by quite a bit, so that could lead to vibration)
Fronts: WITHOUT SPACERS, it looks pretty darn flushed to the naked eye (especially with the tire curving inwards), but upon measuring from the wheel's rim, it does poke 1mm out. Adding 2mm spacers will poke out 3mm and you will see it if you look dead straight, but honestly, at any other angle looks flushed
Absolutely love the look and noticeable improvement in ride quality and steering feel.
Old Jun 19, 2023 | 03:38 AM
  #1173
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Dude, those OEM wheels are boat anchors! You’re going to love the reduced weight on those Enkeis
Old Jul 3, 2023 | 09:58 AM
  #1174
starman202's Avatar
starman202
Originally Posted by entropic_nic
2016 F56 JCW
Question, I have same wheels on my JCW but plan on lowering it. I do have 2mm spacers for the front just because I felt 1mm gap between the spoke and brake caliper was too close. I plan on lowering; I have 2 questions:
1: Was the reason for the 4mm spacer to clear the suspension?
2: With 4mm spacers, was there enough height on the hub for the wheel to rest on so that you can center it? (I know 10mm and thicker have extended centric hubs while 9mm and below do not.)
EDIT: I just installed 4mm spacers. There was probably 1mm left on the hub to allow me to center the wheel and drive without any issues. Anything that's 5mm or thicker without hub extender, you wouldn't be able to accurately center the wheel causing risk of vibration. I've only seen 12mm (maybe 10?) or thicker that have hub extenders, but never 9mm or below.
Old Aug 10, 2023 | 05:24 PM
  #1175
nodrog321's Avatar
nodrog321
Looking to fit 18x8.5 +45 on my f56 jcw stock suspension. I will need spacers to clear the strut. Would you guys recommend 5 or 10mm?
Also looking to get 225/40 tires but considering 215 also.
