Show pics of wheels with low offset
Old Jan 25, 2013 | 11:05 PM
aytch1's Avatar
aytch1
Seeking help from wheel knowledgeable people, Im looking to get a set of wheels with low offset, what would be the lowest i can go without having stick too far out. would like to see some pics and some feedback
Old Jan 25, 2013 | 11:10 PM
RobMuntean's Avatar
RobMuntean
Perfect, this is what I was hoping to see. Good thread start!
Old Jan 26, 2013 | 05:49 AM
Creeve's Avatar
Creeve
What is too far out?
Also what kind or width are you trying to run? A 9" wide wheel at et30 pokes the same as a 7 with et5. The 7 has a lower offset but you might not want such a skinny wheel sticking so far out.
You should look here, might give you some ideas: https://www.northamericanmotoring.co...de-wheels.html
Old Feb 5, 2013 | 12:37 PM
aytch1's Avatar
aytch1
Can someone please help me... wil 17x9 et22 work on 2010 mimi clubman.. what size tires should be used.
THANKS
Old Feb 5, 2013 | 12:47 PM
MinMin2010's Avatar
MinMin2010
I am posting this for comparison reasons.
These are NM Engineering RSe05 wheels (17"x7.5", +45 offset) with 215/45-17 BFGoodrich g-Force Comp2 tires. Drop is 1.4". Camber is about -1. You will also notice that a BBK is installed. There ar no spacers used with this setup.
Old Feb 5, 2013 | 12:57 PM
Creeve's Avatar
Creeve
THANKS
It could be made to work. There is an example very similar to this in the link I already posted.
Old Feb 5, 2013 | 01:03 PM
6000pounds's Avatar
6000pounds
what springs did you use? I plan on ordering these same wheels in a week and a half and ordered the NM engineering springs today.
Old Feb 5, 2013 | 01:22 PM
MinMin2010's Avatar
MinMin2010
I used the H&R springs since they gave me the 1.4" drop. NM springs are currently designed to give a 1.2" drop. Either way, there is no need for camber plates. I would recommend replacing the lower control arms when you lower the car. Sometime soon, I will be ordering a set of NM springs for my wife's 2010 MCS. I just want to close the wheelwell/tire gap a little bit. You cannot go wrong with NM. Good people and good stuff.
Old Feb 5, 2013 | 03:35 PM
aytch1's Avatar
aytch1
Help!!!
Old Feb 6, 2013 | 02:19 PM
Melangell's Avatar
Melangell
Help!!!
Old Feb 8, 2013 | 02:43 PM
aytch1's Avatar
aytch1
Still seeking help.... looking to get wheels soon but dont want to get them and i cant ues them, so CAN someone please HELP!!!!!
Old Feb 8, 2013 | 03:02 PM
MinMin2010's Avatar
MinMin2010
I cannot understand the fascination with a low offset. Let me ask you this, are you just wanting a big lip on the wheel and slamming the car to the ground, or do you want an appropriate wheel/tire combo (w/ proper offset) so the car will still handle like a MINI should? The reason I ask is that I abhor a MINI that is slammed with wheels that are too wide for the tires and camber is way out of spec. You can get a nice dropped (not slammed) look on a MINI with proper camber adjustment and still have nice wheels (w/ +40-+45 offset and 7.5"-8" wheel width) and properly sized tires. If you look at the stance of my car that I posted above, where are you headed with yours in comparison?
Old Feb 8, 2013 | 09:08 PM
Creeve's Avatar
Creeve
Would it also be "proper" for the OP to put many carbon fiber parts on his car that provide no weight or structural advantage? Please tell us more about what you think he should do with his car.
The OP has already stated pretty clearly what he wants. Wide wheels with low offset. I have not given a yes or no answer to that question because really its not that straight forward. There are many factors and a lot of information that would go into a well thought out decision to run 17x9 et22's. Much of it is discussed in the thread I posted.
I would never put 9" wide et22 wheels on my car but I'm certainly not going to try to tell him what to do with his.
Old Feb 9, 2013 | 04:09 AM
MinMin2010's Avatar
MinMin2010
I debated on whether to respond to your post or not. I lost and here it goes. I will only address the subject at hand and not your remarks about my car. The OP is searching for answers to something of which he has no clue about. He may be looking for something that will be more trouble than it is worth. That is why I am asking him to make a comparison to the setup on my car versus where he wants to be with his. If you noticed, nobody has posted pics of anything alse and I only posted mine for comparison purposes only. I want to give him something to think about. I am waiting to see where he leads us from here.
Old Feb 9, 2013 | 07:06 PM
aytch1's Avatar
aytch1
Thanks for the help. i did a test fit today and that setup will not, I should have known because my last set was 18x7.5 with et38 and they were right at the fender.
Old Feb 9, 2013 | 07:45 PM
MinMin2010's Avatar
MinMin2010
Here is an older pic of my MINI when I had 18x8 wheels (+45 offset) and 215/35-18 tires. The stance is nearly identical to my current setup with 17s.
Old Feb 9, 2013 | 07:46 PM
Porthos's Avatar
Porthos
What suspension set up are you running?
Old Feb 9, 2013 | 08:01 PM
MinMin2010's Avatar
MinMin2010
H&R Sport Springs (1.4" drop) w/ factory Sport Suspension shocks
NM Engineering Titanium Lower Control Arms
NM Engineering Adjustable 22mm Rear Sway Bar
NM Engineering Adjustable Rear Sway bar links
The overall handling of the car is superb.
Old Feb 9, 2013 | 08:04 PM
Porthos's Avatar
Porthos
Damn I was hoping you were running coilovers because I am about to put some KW V2s on my MINI and am thinking about getting those NM wheels and wanted to see if I might need spacers.
Old Feb 10, 2013 | 05:06 AM
MinMin2010's Avatar
MinMin2010
You should not need spacers. The +45 offset is ideal. However, I would call NM and talk to Jerry to confirm.
1-800-423-3623 then press 1
Bear in mind, these wheels were engineered just for the MINI. One thing they did was provide more than ample room for a BBK.
Old Feb 10, 2013 | 11:23 AM
Porthos's Avatar
Porthos
I am going to go ahead and get them because I am about 2hr from them and can just go and pick them up.
Old Feb 10, 2013 | 11:49 AM
Creeve's Avatar
Creeve
From everything I have read you will probably need a 10mm spacer with KWs and a 7.5" et45. The KW shock bodies are a larger diameter then the stock shocks.
Some info here: https://www.northamericanmotoring.co...you-using.html
Old Feb 10, 2013 | 12:35 PM
MinMin2010's Avatar
MinMin2010
See Jerry when you get there and tell him that you saw the wheels on "Tackleberry" on NAM. He would be glad to know that.
James
Old Feb 10, 2013 | 07:38 PM
07R56MINI's Avatar
07R56MINI
Also would like to see some wheels with some low offset.......
Alkaidovich
Jan 30, 2021 01:35 AM
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
JamJam43087
Aug 16, 2015 02:02 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
