Brakes Squeal after getting new rear pads
A couple of days after having my rear brake pads replaced (at 40K) they began to squeal when I apply the brakes. The high pitched is coming from the rear. Any thoughts?????
2008 Cooper Convertible with 40 K
1. Factory pads or what?
2. Did you replace the rotors too? Do anything to them? How smooth are they?
3. This work was done by? warranty?
4. The fronts were previously replaced? With the same pad / rotor (or not) and at the same place?
I had the brake pads replaced at a mini dealer. I did not have the rotors replaced just the pads. Yes they were under warranty...but I had also purchased the extended maintenance. I found the invoice for the rear brakes and the technician stated....inspected rear brakes and found pads at 3mm, rotors above min specs. Removed and replaced pads and sensor and reset vehicle data. Part listed. BMW 34 21 6 762 871 and BMW 34 35 6 761 448
I had the brake pads replaced at a mini dealer ... I had also purchased the extended maintenance
OK, to be clear your pads were replaced under 'extended maintenance' ... the warranty I asked about was a warranty from the place that installed the pads.
If your pads were replaced by a MINI dealer and you are not 100% happy ... go back to the dealer. Last time I was there they had a 1 year warranty on their work and parts.
{very curious isn't it that MINI says replace rotors with every pad change UNTIL you are under an extended plan????}
With my last maintenance (extended) the dealer replaced only my front pads as well stating the rotors were within spec. I haven't had any issues with them, eventhough the rotors look like courdoray. Lots of dust though. This was on my '08 MCS.
minimofo
Dec 26, 2015 11:45 AM
thebordella
Aug 31, 2015 01:37 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
