215/45 or 215/40 ???
Old Mar 22, 2011 | 03:08 PM
davisflyer's Avatar
davisflyer
It's getting near time to replace my 17'ers and was thinking of going wider. Which size is more correct, 215/45 or 215/40? I think one of them is supposed to help correct the speedometer inaccuracy.
Also, for those that have these sizes, any opinions as to drawbacks or benefits of either size. I would think that turn-in might be slightly effected, but might be outweighed by the additional grip.
Old Mar 22, 2011 | 03:46 PM
BlueToy's Avatar
BlueToy
Hello Davis,
I recently replaced my runflats with 215/40/R17 Conti Extreme DW. The 40 series is slightly smaller in diameter and as you stated, the 215 gives a wider contact patch. I really happy with this set-up. I'm lowered on KW 2's and no problems with rubbing. From what I've read, the smaller diameter works well, gearing wise with our cars. My speedo reads about 2-3mph faster than actual as veryified by my GPS. I'm also effectively running ET35 offset, ET 40 wheel and 5mm spacer. Let me know if you need a pic of that set-up, hope this helps.
Old Mar 22, 2011 | 03:49 PM
BlckJCWGhst's Avatar
BlckJCWGhst
I Think He Only Was Asking About Tires Not Rims And And Offsets and What Not, But Yes 21540 Is Closer To The Stock Diameter Tires
Old Mar 22, 2011 | 04:35 PM
DAVESTER's Avatar
DAVESTER
go with the 215/45 and you will be closer to OE . see this tire calculator ---
http://www.miata.net/garage/tirecalc.html
Old Mar 22, 2011 | 04:54 PM
fishey72's Avatar
fishey72
I went 215/40 and they are more comfortable of a ride than 205/45 runflats.
Old Mar 22, 2011 | 04:57 PM
NightFlyR's Avatar
NightFlyR
Originally Posted by BlueToy
Hello Davis,
I recently replaced my runflats with 215/40/R17 Conti Extreme DW. The 40 series is slightly smaller in diameter and as you stated, the 215 gives a wider contact patch. I really happy with this set-up. I'm lowered on KW 2's and no problems with rubbing. From what I've read, the smaller diameter works well, gearing wise with our cars. My speedo reads about 2-3mph slower than actual as veryified by my GPS. I'm also effectively running ET35 offset, ET 40 wheel and 5mm spacer. Let me know if you need a pic of that set-up, hope this helps.
I believe what you meant to say is you are traveling 2 to 3 MPH slower then your speedo says?
http://www.discounttiredirect.com/di...foTireMath.jsp
here is a link to another tire size calculator
I have run at least 4 different sizes on my car, so far the best one is a 215 45 17, if I decide to go with a 40 series i would do a 235 40 17, but not many tires in that size. Good luck to you
Old Mar 22, 2011 | 05:32 PM
thulchatt's Avatar
thulchatt
I had 215/40 when I got my car. But after 2 bent wheels from pot-holes I went with 215/45's. No more bent wheels.
Your damage may very.
Old Mar 22, 2011 | 05:41 PM
BlueToy's Avatar
BlueToy
That is what I meant to say, thanks Fixed my original post
Old Mar 22, 2011 | 05:51 PM
Mini_berger21's Avatar
Mini_berger21
215/45/17 is no prob. I was running Hankook Ventus V12 Evos slammed on Bilstein Coilovers and I had no rubbing issues whatsoever. Was very happy with the ride quality.
Old Mar 22, 2011 | 07:10 PM
davisflyer's Avatar
davisflyer
Any pics of the 215/45's?
Old Mar 22, 2011 | 07:54 PM
Mini_berger21
Hrmmm don't have any closeups, but here are some old pictures of the 215/45/17 Hankook V12s
The rims I had were 40 offset, so anything between 40 and 48 offset I'm sure would be fine.
If you are lowered, I would want to watch out with 35 or lower offset with 215/45/17 tire.
Old Mar 25, 2011 | 06:56 PM
howsoonisnow1985's Avatar
howsoonisnow1985
With the Bilstein PSS9s I would go with 15s or 16s. Those 17s lowered kinda look like 19s.
Old Mar 26, 2011 | 06:51 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Hey stranger!
I've been running 215/45's for 70,000 miles.
This size made my speedo almost perfect.
I'm about to order new summer wheels and leaning toward 16" for lower weight and more rim protection with a bit higher profile tire on a light wheel. Might even look better with the amount I'm lowered.
Old Mar 26, 2011 | 07:14 AM
agranger's Avatar
agranger
My first tires after leaving the runflats behind were 215x40. They felt wonderful, but the low profile made for problems with potholes (and Dallas has pretty good streets). I bubbled the sidewalls on 2 tires.
If you do get the 40 profile, buy the extended tire warranty.
I buy 45 profile now unless it is for track only.
Old Mar 26, 2011 | 10:26 AM
dmyer's Avatar
dmyer
If I was going to go with a 40 versus a 45 in my area - I think I would just ding all the rims with a 5lb sledge hammer first to pre-disaster them - that way I won't feel so bad later when the potholes do their thing!!! A 45 has marginal cushion IMO for protection of the rims for my area.
DAn
Old Mar 26, 2011 | 12:36 PM
Mini_berger21
If you thought those lowered Konigs look like 19s...
Then my 17" OZ rims REALLY look like 19s when lowered lol.
Old Mar 28, 2011 | 09:18 AM
davisflyer's Avatar
davisflyer
OK, thanks guys. Decided to stick with the stock 17" size for now. Just ordered a set of Continental ExtremeContact DW's from Alex at the Tire Rack.
Old Mar 28, 2011 | 12:44 PM
Neufusion's Avatar
Neufusion
215/45/17 non-runflat. Never had a problem and they ride nice. WAY nicer than the OEM runflats. Ack!
Old Mar 28, 2011 | 01:53 PM
davisflyer's Avatar
davisflyer
Originally Posted by BlimeyCabrio
Hey stranger!
Hey Paul! Are you going to the Dragon this year??
Gabe3
Tires, Wheels, & Brakes
16
Apr 16, 2016 07:55 AM
zack_S_moore
18
Nov 6, 2006 08:46 PM
zrwon
Sep 5, 2005 11:43 PM
danielg
Jul 6, 2005 02:56 PM
minhi
Sep 29, 2003 12:08 PM
