Aggressive fitment MINIs? Post pics!
Old Jan 29, 2009 | 10:25 AM
  #26
mini_racer's Avatar
mini_racer
I have the RE01s at 215/45R17 size, they are on some 17 X 7 et45 wheels. I have the stock S suspension and the only rubbing I have is very rarely in the back with a heavy load and a big bump.
The outside of the rear wheel will slightly rub the plastic wheel liner. No big deal, this happened to me only once in 5K miles.
BTW the RE01 is a very wide 215 width. I think measured at around 8.4 inch wide tread
Old Jan 29, 2009 | 02:02 PM
  #27
pearlwrx's Avatar
pearlwrx
thread jackers.
Old Jan 29, 2009 | 02:13 PM
  #28
Mach V Dan's Avatar
Mach V Dan
I've run some bigger tires...
This is Rota MC, 18x8 +45, with 225/35R18. (I would have run 235/35R18, but they were too expensive!)
This one is Rota RB, 17x7.5 +45 with 235/40R17.
The 235 is really tight. The factory struts have good clearance, but aftermarket coilovers are not as good, and would need spacers to move the wheel/tire away. Then you'd start to run into the plastic fender arches...
--Dan
Mach V
Old Jan 29, 2009 | 08:40 PM
  #29
MrCooperS's Avatar
MrCooperS
Moderator
Originally Posted by mini_racer
I have the RE01s at 25/45R17 size, they are on some 17 X 7 et45 wheels. I have the stock S suspension and the only rubbing I have is very rarely in the back with a heavy load and a big bump.
Hey mini_racer,
I got a quote from Adam from Alta saying that he could do 235/40/17 on some 17x7 et 40 without problems with rubbing or anything. What's your take on this?
"This car:
http://www.flickr.com/photos/3146829...7609284789709/
uses another Konig wheel, but same offset etc. and I run 235/40/17 with no rubbing even on an AGGRESSIVE drop. You can use 225 as well, but I like the wider look of the 235's."
Old Jan 29, 2009 | 08:43 PM
  #30
Rally@StanceDesign's Avatar
Rally@StanceDesign
not tucking huge sidewall tires like 235/40 is NOT "aggressive drop"
Old Jan 29, 2009 | 08:45 PM
  #31
MrCooperS's Avatar
MrCooperS
Moderator
well...i'm not looking for an aggressive drop...more of aggressive meat on wheels to create a aggressive wide stance.
Old Jan 29, 2009 | 08:48 PM
  #32
Rally@StanceDesign
I know, I'm just commenting on the terminology given and the fact that that's a pretty conservative drop.
235/40/17 is a larger diameter than stock even, so it raises the car and decreases the wheel gap....so to still have wheel gap after the drop with a larger tire would mean that it's really only a 1"-1.5" drop.
Old Jan 30, 2009 | 08:45 AM
  #33
Mach V Dan's Avatar
Mach V Dan
I have read that 17 X 7.5 et 45 will fit the 235/40s on an R56 with stock ride height, and even some small lowering, maybe half inch.
It fits okay with more lowering than that. See my car above.
I have also read that that same combo will not fit the R53 at any height, nor will any other offset. Unless, you do some significant fender trimming, etc. (plastic liner at least, maybe even sheet metal)
Hmm. I'm not convinced on this, but I'll have to do some more testing.
235/40/17 is a larger diameter than stock even...
It's 0.2% smaller diameter than the factory 195/55R16, and 0.6% larger than the factory 205/45R17.
--Dan
Mach V
Old Jan 30, 2009 | 08:57 AM
  #34
Rally@StanceDesign
Yah, it's not much, but it's still larger. So, if you aren't tucking a tire even a little larger than stock....that's not an "aggressive" drop. That's a conservative drop at best.
Old Jan 30, 2009 | 06:24 PM
  #35
Mini Fireman's Avatar
Mini Fireman
QFT.
Old Jan 30, 2009 | 07:54 PM
  #36
mini_racer's Avatar
mini_racer
The stock 205/45/17 diameter = 24.3 inches
235/40/17 diameter = 24.4 inches
Technically, yes larger, but with a delta of 0.6% that would be insignificant. Impossible to see a change in wheel gap or ride height.
Oops, just saw Dan's post, so yeah...............what he said.
Old Jan 30, 2009 | 08:03 PM
  #37
mini_racer's Avatar
mini_racer
Originally Posted by itsminidrmer
Hey mini_racer,
"This car:
Yes this is absolutely possible for an R56, and that car on flickr is an R56.
This is not possible on an R53 without plenty of trimming, and not much drop will be possible. Well, you can drop on an R53, but the more you do the more you will have to trim plastic and metal to tuck it in. The main problem is the rear.
Old Jan 30, 2009 | 08:05 PM
  #38
MrCooperS's Avatar
MrCooperS
Moderator
Stock springs should do it for the r53...or so I've heard.
Old Jan 30, 2009 | 08:08 PM
  #39
chuckt's Avatar
chuckt
OK Jurrell, tell about those cars. Do we have to play 20 questions?
More of the first on here... 275's
Old Jan 30, 2009 | 08:17 PM
  #40
Rally@StanceDesign
I know how to use the tire calculator. My point still stands, if you're not tucking tire, you don't have an "aggressive" drop. That was the only point I was trying to make.
On a real aggressive drop, that tire and wheel combo would most likely rub unless you dialed in some negative camber.
Old Jan 30, 2009 | 08:43 PM
  #41
mini_racer's Avatar
mini_racer
No arguments there...........
Old Jan 30, 2009 | 08:55 PM
  #42
Oxybluecoop's Avatar
Oxybluecoop
I'm running 225/40/18's on the front with H&R coils.Real tight tolerances with my current adjustments with some rubbing up front.As for the rear I have 225/45/18's. I had to remove the liners and bump up the - camber but I still rubbed off my fender arch lights. IMO a 45 sidewall is too tall but hey they were 20 bucks new on craigslist.
Picture136.jpg?t=1233377552
Old Jan 30, 2009 | 09:54 PM
  #43
Rally@StanceDesign
Old Jan 30, 2009 | 10:04 PM
  #44
TurboMini's Avatar
TurboMini
WARNING:Some trimming required
Old Jan 30, 2009 | 11:14 PM
  #45
MrCooperS's Avatar
MrCooperS
Moderator
Trimming plastic? The under side of the fenders?
Old Feb 1, 2009 | 10:29 AM
  #46
Woodys09's Avatar
Woodys09
Best looking set of wheels I have seen on a MINI. Classics rock!!!!
Old Feb 1, 2009 | 10:38 AM
  #47
Rally@StanceDesign
No, check out his rear flares. They're carved away on the outside as well.
Old Feb 1, 2009 | 10:39 PM
  #48
TurboMini's Avatar
TurboMini
Yeah, the car isn't actually very low. The wheels poke a bit so the plastic inner fender wasn't a problem, but like rally points out the trim has been trimmed quite a bit giving the appearance of a rear rake while the car is actually level. The mini has somewhat of a rake "built in" so the wheel wells in the back are little lower than those in the front..
kinda like this vdub. The rear wheels are tucked way more than the front even though the actual car is level..
Old Feb 2, 2009 | 10:50 PM
  #49
mini_macky's Avatar
mini_macky
anyone running 17x7.5 +38 wth 215/40R17 tires? this is the only spec of rims available (cheap) also planning to lower the Mini on BC Racing coilovers
Old Mar 3, 2009 | 02:55 PM
  #50
bbm's Avatar
bbm
Anyone have 215/45/17 on 17x7.5 +38 wheels without any rubbing on a R56 lowered in HR Springs?
