So what if it's cheap?
Old Jan 10, 2009 | 07:09 AM
IzzyG's Avatar
IzzyG
So can someone tell me the issue with cheap wheels? Is the integrity of the structure an issue with cheaper wheels? I found a cheap set of black wheels on ebay from a "wholeseller" but it seems TOO cheap. $200 for a set of 4 rims(add $155 for flat rate shipping).
However, I don't wanna go dirt cheap and later find myself with broken wheels. 0.o So wheel gurus, tell me what the problem is with cheap wheels.
Old Jan 10, 2009 | 08:21 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
The one most people will notice is the finish. There is just no denying that the finish of cheaper wheels is both weaker and less attractive visually. They often come with a VERY thin layer of paint that is prone to chipping. My first wheels (before I knew anything about wheels) was a set of flik's. They were a really low price so I thought I should definitely buy them. After a year of moderate driving the paint was already chipping, and after half a year more the clearcoat was spidering (and I wash my wheels regularly with no chemicals).
Strength will also be an issue. Cheaper wheels are often more likely to bend and in some cases break. Some cheap wheel advocates will make the argument that even HRE's (an example of extremely expensive wheels) break. That's entirely true, in extreme enough situations, all wheels will break. It's just that it's far more likely on wheels that have not been properly produced.
With wheels the philosophy that "you get what you pay for" is entirely true.Just think to yourself. The $155 is a legitimate shipping rate so it's not them just tacking on an added cost to trick you on ebay. So you're looking at $50 per wheel. We have to assume the seller is atleast making SOME profit so let's assume his cost is $30 or $35 a wheel. That almost scares me to think what corners were cut to get the price that low. The cost of metal materials alone should have the wheels costing more than that to produce (even if it is a wholeseller) not to mention paint, clearcoat, machine time, labor, etc.
You drive a nice car, I think it's worth a bit of patience to save up your money a while longer and just buy quality wheels. $50 wheel are a downgrade from OEM wheels in quality. You'll be much happier if you save up for a few more months and buy some nicer wheels. They'll look better and will probably hold up better in the long run. "Buy nice or pay twice". The last thing you would want is to have your ebay wheels all chipped and bent so that you're out $200 and in need of new wheels already.
And besides, cheap wheels look ugly
Old Jan 10, 2009 | 08:55 AM
IzzyG's Avatar
IzzyG
Rally: I am looking for some all black wheels without the red lip around it(like the ones tirerack carry). I'm having a hard time finding any that fits the description.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
At the same time, $200 a wheel is my ceiling(with quality tires, the set will cost about $1200-that's not including the $200 TPMS sensors). What's the estimated cost per wheel for a good quality set?
Old Jan 10, 2009 | 09:02 AM
Rally@StanceDesign
Is there a design that you're looking for beyond being all black? 5 spoke, mesh, etc? What size? 17"?
There are lots out there and finding an all black wheel should be pretty easy. Estimated cost per quality wheel is pretty hard to say because the range is massive, but it should be pretty simple to find some good/decent quality wheels under your $200/wheel bargain. $50 per wheel just scares me though
Old Jan 10, 2009 | 09:16 AM
IzzyG's Avatar
IzzyG
It'd be nice to have the webbed spokes ala JCW wheels but I know those will be above the $200 each. But yea you pretty much summed it up on the design part.
And where about are you looking for wheels? I've only checked locally and on tirerack.
Crashton's Avatar
Crashton
I think Mr fleaBay tire wholesaler is sticking it folks with that shipping quote. A pretty common thing on fleaBay. I've shipped wheels with tires mounted for $100.
Old Jan 10, 2009 | 09:30 AM
faster,Tobias!'s Avatar
faster,Tobias!
You do know that you don't need the TPMS sensors, right? The MINI's TPM works off of the ABS system, by monitoring rotational speed of the wheel.
Old Jan 10, 2009 | 09:31 AM
IzzyG's Avatar
IzzyG
You don't NEED it but I don't like the light glaring at me. And I'm not gonna put a black tape over it. If there's a way to switch it off, then I won't care but there isn't(not to my knowledge anyways)
Old Jan 10, 2009 | 09:33 AM
Rally@StanceDesign
There are literally hundreds of wheel manufacturers. Tire Rack is really only the tip of the iceberg. Just looking around on google you'll find some other well known wheel dealers. Check out Konig wheels and see if they have anything that fits your personal taste. They are pretty low prices but their finish is much better than the stuff you find on ebay.
Check here. I saw a few all black wheels while I quickly browsed through that might suit your interest. http://shopping.netsuite.com/s.nl/c....gory.799949/.f
you can usually pick up konig wheels locally or find them cheap at some wholesellers.
You're probably right. I've paid anywhere from 75- 180 to have wheels shipped from/to various parts of the country. He may have tacked on some extra dollars, but the wheels are still too cheap to feel comfortable.
Old Jan 10, 2009 | 09:57 AM
Crashton's Avatar
Crashton
This saying comes to mind.... Cheap & worth every penny.
Caveat emptor...
Old Jan 13, 2009 | 05:54 PM
Q-4000's Avatar
Q-4000
did MINI add sensors to the 2nd gen?? I know on the 1st gen the light only comes on if the ABS system scenes a change in wheel speed from one wheel to the other suggesting one tire is low on air. if it does have the sensors I know at least with Chrysler you can get the dealer to turn it off! (did that on my 300C)
Old Jan 13, 2009 | 08:02 PM
IzzyG's Avatar
IzzyG
I believe it's now federal law to include the ability of TPMS sensors and wheels equipped with them for any new vehicle sold after 2008.
mni928
Nov 9, 2015 07:38 PM
Winston46
Nov 9, 2015 06:18 AM
vulkandino
Oct 31, 2015 08:29 PM
mni928
Oct 11, 2015 07:37 PM
BMC_Kid
Sep 27, 2015 04:31 PM
