18x7.5 ET40 and lowering??
Hi!!
I have found a set of rims with deminsion 18x7.5 ET40 to my MCS -04... Planing to use 215/35/18 tires..
Anybody know if it will fit with 30mm lowering springs??
Please help me... Have looked aurond in the forum but haven't found any answers...
Best regards Fredde (Sweden)
Hi!!
If you need more clearance in the rear you can use more rear negative camber- add adjustable lower control arms.
how much do adjustable lower control arms cost?? do you got any sites??
Using 215/35-18 or 225/35-18 tires you should be fine with moderate lowering 1" front and rear.
Again, more negative rear camber will increase clearance if needed.
Don't use tires that are taller than stock 24.3" tire diameter.
Rear lower control arms-
Various vendors:
http://www.helix13.com/mini/products/suspension-chasis $229 for pair.
or
http://www.outmotoring.com/mini-coop...es/suspension/
From $190 to $247 per pair. Weights and appearance vary, they are functional, only lower control arms need upgrade to adjust for rear negative camber.
Various vendors:
or
smdmini
Oct 7, 2019 06:05 AM
massmini03
Sep 18, 2015 05:40 PM
