Suspension phot of my setup
phot of my setup
I uploaded a bunch of photos, but I cannot find these...The Wilwoods are the 12.2" kit - if you look close enough you will the safety wire thru the floating rotor. I did safety wire all the nuts. I'm a safety dork, sorry.
Michael
Originally Posted by meb
Honestly, I don't know how to get photos uploaded. I've used the browser, but I cannot find the 10 or 12 photos I (thought) I uploaded. I've emailed one of our coordinators - no response.
Email them to me and I'll post them if you want...
I know! I can't help it. My son gets so disgusted with me he won't even help.
Okay, I'll email them to you tonight...how do I do that
... I have what I think is a permanent fix...we'll see.
sign me up for the fix
...just messin with you.
It's actually working! The Megans are flush mounted to the underside of the strut tower. When the M7 SB arrives, this will create a sandwich with the strut tower between. The ride feels a little more composed up front with these flush mounted. I'll need to keep an eye on the Megan perches...for potential cracking.
I also installed two layers of sticky, foil coated flashing on top of the Megan perches. When these were torqued to 27ft/lbs, the flashing squeezed out a bit. I did this to create a little cushion, as well as for filling in any contour differences bwteen the two surfaces.
side benefit; the studs now protrude a 1/4" higher above the top of the strut tower - a good thing for strut bars.
I wish the calipers were red, oh well.
Thanks for turning the photo...wasn't me
I have more photos to try to load this weekend...Onasled will hopefully help me out
The brakes were very easy to install - very straightforward. Safety wiring the nuts behind the rotors took a fair amount of time; made easier with special safety wire plyers. I cannot imagine going thru this process with any other tool.
Once the calipers were attached, simply bleed the calipers from the top two pistions - finsihed. Thankfully I did not read the bed-in instructions. I followed a time-honored method and potentially saved myself some aggivation; Onasled informed me that he warped his rotors following the instructions...which required super heating the rotors - high speed bed-in.
May 6th will be the first time I use these on a track. They are waaay better than stock. I suspect I'll need to begin my damping in a different place.
IQRaceworks
53
Jun 28, 2024 07:29 AM
I need some cookies and lemonade.
